    [Plugin] Architect Tools
    119 Posts 32 Posters 176.9k Views 32 Watching
    • yitzharY
      yitzhar
      That would be posible in 5 hours from now when i finish working at the office
      but thank you i got the test and i would write you later on.
      look for us on facebook : creatioIL
      • yitzharY
        yitzhar
        wow - good job !!!
        the problem solved with the new tt_lib2 ...
        thank you very much.
          Excellent! πŸ˜„
            Version 2.0.0
            See first post for more info.
            I don't expect people to immediately work out how to use these tools. They are very specific to my workflow with modelling site plans.
            This release has been done for a long time, but I've not had time to create the videos and description for it yet. Still haven't, but it should come soon. ("Soon" is as precise as I can be.)
            • utilerU
              utiler
              Gee, that got my attention!!!! Can't wait for the videos, Thom!!!!
              Just Curious...
                matt.gordon320
                Thanks thomthom!
                • L
                  leot
                  Thanks but not working on SketchUp Mac version
                  • T
                    tulacong
                    thank you very much
                      rv1974
                      Thomthom, I love the stylish look of your scripts (both toolbars and execution).
                      P.S. May I request 'split face by grid' feature please?
                        Uploading a bunch of videos on how to use Architect Tools:
                        More to come!
                          What isn't working? No toolbar, menus? A particular function not working?
                          • utilerU
                            utiler
                            More to come!
                            Many thanks, TT!!!! It always helps enormously how the toolset functions when videoed but the author.... πŸ‘ πŸ‘
                            Just Curious...
                              This particular toolset is quite idiosyncratic to my own workflow - and not so polished - so it really needs some explanation before anyone can really use this. :s There is much that could be improved - but for the time being I'm happy I finally got around to make the videos.
                              • bobpineoB
                                bobpineo
                                Good day Thomthom,
                                Working my through this plugin, looks awesome.
                                Can you by any chance post a drawing (perhaps the base drawing for the video you posted) here?
                                I would like to see the condition of the drawing you started which allows you to run the plugin successfully.
                                Most of the CAd I get is so complicated and poorly put together that I am having trouble replicating what you do in your video. I would like to practice on a better base to see if I can modify what I am getting to work better.
                                Best
                                BP
                                Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                  The imported map datas I used as foundation to generate the models?
                                    sepo
                                    Hi Thomas
                                    Used extension warehouse to install the plugin. I can see it in plugins folder but I do not have toolbar. It is checked under toolbars but does not appear anywhere.
                                      This is a painful known issue with first version of v2013, with random problems with new toolbars seemingly 'invisible'...
                                      It is probably stuck underneath a docked toolbar or two in the top bar.
                                      Drag the top bar toolbars off so they are floating, and if you see the required toolbar below then double-click it a few times to try and 'unglue' it.
                                      Then you should be able to drag it off so it's floating, and then relocate it where you want...
                                      Then relocate the moved toolbars as desired.
                                      It that doesn't work there is a registry hack... I've posted that in a few threads... do a search...
                                        sepo
                                        thanks Tig....it worked. It was hidden behind top tool bars....how bizzare.
                                        However shadow fix toolbar is nowhere to be found....
                                          When a new plugin makes a toolbar for the first time it ought to be made floating in the top left quadrant of the screen. That is the default. Scripters can't affect how it works. But for some yet to be fathomed reason SketchUp 2013 occasionally decides to dock it in the top-bar, which would be so bad BUT it puts it under existing toolbars - which isn't allowed as docked toolbars must always have their own 'space' πŸ˜’
                                          I know Trimble are striving to fix it - it's an embarrassing glitch...
                                          • I
                                            isbelcia
                                            I use Sketchup 7 and I want to install architect tool. My question is how to install the necessary TT_lib2.rbz on sketchup version lower than 7?
                                            Thanks Iza
                                            • 5 / 6
