    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 71.6k Views 16 Watching
    • renderizaR Offline
      renderiza
      @smicha said:
      It's almost it. But selecting one component and running the plugin should also change all other components without a need of selecting them. And an option to have one selected component visible and rest in a form of frames would be so useful.
      Perfect solution (for me) would look like this: select a component, apply the plugin - frames on all components, apply it again - frames on all but selected, apply again - go back to an original view. And a dream πŸ˜„ is to assign one shortcut, eg. 'F6'.
      What do you think Rafael?
      Hey I stumbled upon this ... http://sketchucation.com/forums/viewtopic.php?f=180&t=21334
      Please tell me what you think...cheers!
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        smicha
        I saw ghostcomp yesterday - great plugin but its use is not as fast as I wanted. It introduces extra layer, wireframe is only for original component (box is with sides). Anyway ghostcomp is a great plugin.
          renderiza
          @smicha said:
          I saw ghostcomp yesterday - great plugin but its use is not as fast as I wanted. It introduces extra layer, wireframe is only for original component (box is with sides), it doesn't convert all same components unless I select them,... I think proxy component works better for me. Anyway ghostcomp is a great plugin.
          I have started to add the 'Set:: Proxy' to Gosu.
          @smicha said:
          BTW. Do you know any plugin that selects same components? This function is available in a component manager, right click on a component that is on a list, and choose 'select instances' but I cannot assign shortcut key for it.
          Here is the one I found by Confitex Architure;
          [Plugin] Select component instances on right click - http://sketchucation.com/forums/viewtopic.php?t=9810
          Note: You can add a shortcut key to that plugin under 'Edit/Item/DC Instances/Select Active
            smicha
            5 minutes ago I found the same plugin πŸ˜„
              smicha
              I am confused - I cannot find it.
                smicha
                I found it. Thanks.
                  renderiza
                  GOSU v1.0.6 Released!
                  [highlight=#bfff00:3lqn88ji]1.0.6:: 4/26/2013[/highlight:3lqn88ji]
                  • Set:: Proxy - Replaces complex component with simple one temporarily.
                  Set:: Proxy
                  Note: The Set:: Proxy feature in Gosu is a modification of a plugin called 'Bounding Box View by AdamB' and even though is written little different at its base is the same thing with couple functions added. So most of the credits should go to him...again thanks and if there is any issue please let me know.
                  ::GOSU dlg::
                    smicha
                    You are my hero πŸ˜„ Great job Rafael!
                    Can you add an option to get frames only (boxes with edges only, no sides)?
                      renderiza
                      Download the plugin again because I added some code that will allow you to add cline lines with no faces to proxy if you hold 'ctrl' key while clicking component.
                      Note: In the video I said 'cline line' and the correct name for it is 'construction line'. Also sometime if the web dlg is focused and you hold ctrl and click component it will not work, so before doing this move camera to refresh view-port so the plugin recognize a key being press.
                        smicha
                        Ctrl function is not working - I installed it twice.
                          smicha
                          Another improvement would be proxy on a single group, not a component.
                            renderiza
                            At the moment it seem that when the GOSU web dialog window is focused it doesn't recognize the keyboard so to fix it follow this steps until I can solve it on code...
                            1. click Set::Proxy on dlg window
                            2. Use middle button to orbit around so the dlg window is not focused anymore
                            3. Hold Ctrl and click component
                            4. Let me know if it worked because if not then the problem is not what I have in mind. Also just in case delete web cookies and download again because since I used same name as the one I had uploaded before it might had something to do with that (not sure).
                            At the moment the Definition Name is being used to set proxy and only components can have them. Not saying it cannot be done with groups but it will take more time to make it work.
                              smicha
                              Refael,
                              Isn't it better to do two separate functions - proxy with boxes and proxy with clines? That could let a user assign different shortcuts to such functions.
                              I'll test your plugin tomorrow morning.
                                renderiza
                                GOSU v1.0.7 Released!
                                [highlight=#bfff00:2t64rsa8]1.0.7:: 4/29/2013[/highlight:2t64rsa8]
                                • Set:: Proxy(box) - Added this to web dlg
                                • Set:: Proxy(cline) - Added this to web dlg
                                You can set a keyboard to Set::Proxy(box or cline) and No::Proxy(box or cline)like this
                                To set key shortcut to Set::Proxy(box or cline);
                                1. Select component
                                2. Got to Window menu
                                3. Then Preference
                                  4 On the left side click 'Shortcuts'
                                4. On Filter type cline
                                5. This should appear...Edit/Item/GOSU/Set::Proxy(Cline)
                                6. Add Shorcut
                                To set key shortcut to No::Proxy(box or cline);
                                1. Select component that is already with Proxy(Cline) Aplied or it will not work
                                3. Then Preference
                                5. This should appear...Edit/Item/GOSU/No::Proxy(Cline)
                                6. Add Shorcut
                                By the way ::smicha:: thanks for making suggestions! This will make GOSU better. πŸ‘
                                Cheers!
                                  Added to store
                                    renderiza
                                    @rich o brien said:
                                    Added to store
                                    Thank you very much!
                                    • CadFatherC Offline
                                      CadFather
                                      Thanks Rafael, it's a fun plugin!
                                      would be great if it went stealth - fantastic for jokes - imagine your boss clicks an object during a presentation and the appropriate sound goes off! πŸ˜†
                                        renderiza
                                        That would be hilarious indeed! πŸ˜† ...Hope no one gets fired. πŸ˜•
                                          smicha
                                          Here is a problem: I assigned F3 to cline. When I press F3 and select a component nothing happens. When I select a single component and press F3 it works but when I want to remove cline - no way to do it with F3. I also cannot convert all same components to clines with F3.
                                          Thanks for your effort Rafael.
                                            smicha
                                            • 2 / 4
