    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 70.6k Views 16 Watching
      smicha
      I just watched a video tutorial - your plugin is great!
      • renderizaR Offline
        renderiza
        Thank you sir for does kind words! πŸ‘
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          smicha
          Rafael,
          I have a very very very big wish, and I think you can introduce it into your great plugin. This would speed up sketchup many many times. You are a very talented programmer, so I truly think/believe that you can do it πŸ˜„
          I may say in advance that I saw such a solution in a very famous 3d software πŸ˜„
          The point is: let's assume I have a component (or a group, it should apply to both, but components are more important to me) and let's assume that this components have 1 million polygons. Now lets assume I have 100 copies of this component. Yes - 100 millions polygons altogether (BTW it's not a problem for Octane Render using instancing with great TIG's plugin - see Octane forum). We all know how such geometry may affect speed of SU - orbiting, zooming can be a real nightmare. Now imagine I select one copy of a component, go to your plugin, choose a new option eg. "Set:: bounding box" and only bounding boxes (frames only) become visible. Just 12 edges of a bounding box instead of millions. We can assign a shortcut key like "alt+B" to turn on/off this option. And now orbiting, zooming, navigation would be so fast.
          An extra option would be to give a user a choice to turn on/off bounding boxes on all of same components or on all but the selected one.
          Tell me what you think and if the idea is clear to you and of course if it is possible to code?
          Kind regards,
          Sebastian
          PS. I attach some screenshots with the idea.
          1. Copies of a component.
          2. First version of a plugin function - frames on each copy of a component.
          3. Second version of a plugin function - frames on each copy of a component but not selected one.
          https://lh6.googleusercontent.com/-1xVKBuxKshA/UXpcW92rTLI/AAAAAAAADwQ/D_U4dQdqb-M/w1000/bb1.jpg
          https://lh6.googleusercontent.com/-6H00eE2whMA/UXpcW_kfmyI/AAAAAAAADwI/fHshc4H9GUo/w1000/bb2.jpg
          https://lh6.googleusercontent.com/-f3JnCBrgZXc/UXpcW-eeudI/AAAAAAAADwM/wFnDjGE5wDQ/w1000/bb3.jpg
            renderiza
            ::smicha::
            Hi, very clear explanation! πŸ‘
            Here is a video for "Bounding Box View" Plugin found here... http://sketchucation.com/forums/viewtopic.php?t=21427
            I have not tested "Bounding Box View" plugin yet to know if your suggested extra options is available but for the most part its pretty close to what you asked I think.
            Tell me if that plugins was what you wanted if not maybe something else can be worked out.
            Cheers!
              smicha
              It's almost it. But selecting one component and running the plugin should also change all other components without a need of selecting them. And an option to have one selected component visible and rest in a form of frames would be so useful.
              Perfect solution (for me) would look like this: select a component, apply the plugin - frames on all components, apply it again - frames on all but selected, apply again - go back to an original view. And a dream πŸ˜„ is to assign one shortcut, eg. 'F6'.
              What do you think Rafael?
                renderiza
                Sounds like a plan! I will put this things on my to do list and hopefully make it happen in a reasonable amount of time. I like to realease simple scripts that solve just a few of your suggestions and then refine it by updates.
                No promises since I have extra work but I think is a good idea so I will try.
                @techdave02 said:
                If so what about a right click sub menu to choose function???
                This is done already just need to check few thing so I can release it.
                Cheers
                  renderiza
                  GOSU v1.0.5 Released!
                  [highlight=#bfff00:hy2ldg96]1.0.5:: 4/26/2013[/highlight:hy2ldg96]
                  • Right click sub menu to choose functions.
                  Cheers!
                    renderiza
                    Hey I stumbled upon this ... http://sketchucation.com/forums/viewtopic.php?f=180&t=21334
                    Please tell me what you think...cheers!
                      smicha
                      I saw ghostcomp yesterday - great plugin but its use is not as fast as I wanted. It introduces extra layer, wireframe is only for original component (box is with sides). Anyway ghostcomp is a great plugin.
                        renderiza
                        @smicha said:
                        I saw ghostcomp yesterday - great plugin but its use is not as fast as I wanted. It introduces extra layer, wireframe is only for original component (box is with sides), it doesn't convert all same components unless I select them,... I think proxy component works better for me. Anyway ghostcomp is a great plugin.
                        I have started to add the 'Set:: Proxy' to Gosu.
                        @smicha said:
                        BTW. Do you know any plugin that selects same components? This function is available in a component manager, right click on a component that is on a list, and choose 'select instances' but I cannot assign shortcut key for it.
                        Here is the one I found by Confitex Architure;
                        [Plugin] Select component instances on right click - http://sketchucation.com/forums/viewtopic.php?t=9810
                        Note: You can add a shortcut key to that plugin under 'Edit/Item/DC Instances/Select Active
                          smicha
                          5 minutes ago I found the same plugin πŸ˜„
                            smicha
                            I am confused - I cannot find it.
                              smicha
                              I found it. Thanks.
                                renderiza
                                GOSU v1.0.6 Released!
                                [highlight=#bfff00:3lqn88ji]1.0.6:: 4/26/2013[/highlight:3lqn88ji]
                                • Set:: Proxy - Replaces complex component with simple one temporarily.
                                Set:: Proxy
                                Note: The Set:: Proxy feature in Gosu is a modification of a plugin called 'Bounding Box View by AdamB' and even though is written little different at its base is the same thing with couple functions added. So most of the credits should go to him...again thanks and if there is any issue please let me know.
                                ::GOSU dlg::
                                  smicha
                                  You are my hero πŸ˜„ Great job Rafael!
                                  Can you add an option to get frames only (boxes with edges only, no sides)?
                                    renderiza
                                    Download the plugin again because I added some code that will allow you to add cline lines with no faces to proxy if you hold 'ctrl' key while clicking component.
                                    Note: In the video I said 'cline line' and the correct name for it is 'construction line'. Also sometime if the web dlg is focused and you hold ctrl and click component it will not work, so before doing this move camera to refresh view-port so the plugin recognize a key being press.
                                      smicha
                                      Ctrl function is not working - I installed it twice.
                                        smicha
                                        Another improvement would be proxy on a single group, not a component.
                                          renderiza
                                          At the moment it seem that when the GOSU web dialog window is focused it doesn't recognize the keyboard so to fix it follow this steps until I can solve it on code...
                                          1. click Set::Proxy on dlg window
                                          2. Use middle button to orbit around so the dlg window is not focused anymore
                                          3. Hold Ctrl and click component
                                          4. Let me know if it worked because if not then the problem is not what I have in mind. Also just in case delete web cookies and download again because since I used same name as the one I had uploaded before it might had something to do with that (not sure).
                                          At the moment the Definition Name is being used to set proxy and only components can have them. Not saying it cannot be done with groups but it will take more time to make it work.
                                            smicha
                                            Refael,
                                            Isn't it better to do two separate functions - proxy with boxes and proxy with clines? That could let a user assign different shortcuts to such functions.
                                            I'll test your plugin tomorrow morning.
                                            • 2 / 4
