    [Plugin] GOSU v1.1.1
    69 Posts 16 Posters 71.3k Views 16 Watching
    • renderizaR Offline
      renderiza
      @iichiversii said:
      R I'm very impressed with this and see alot of potentional in it, ideas are flowing, never would of taught of it myself, I applaud you on a great plugin, well done and look forward to updates, seriously, well done.
      Thanks its really nice to read compliments like that... 💚
      New Video for GOSU v1.0.3
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Litchi
        Thanks for your present!
        I would like to know whether we can be completely removed my settings
        “Pause”is just only pause
          renderiza
          Hi, thanks for your comment!
          Let me see if I understood correctly...
          You want a tool that removes the Set:: Options that you previously added, more like reset everything button?
          or
          You suggesting for the pause button to be removed?
          Again thanks!
            Litchi
            or
            Again thanks!
            I'm sorry,My English is not good……
            I mean if we can add a new function "Reset",remove my settings(Can select all or selected components)
            thanks! 😄
              renderiza
              thanks! 😄
              I got it now and don't worry English is not my 1rst language as well. 👍
              This is what I have in mind for next update...
              Clear:: Selected
              Clear:: All
              Will remove settings on all or selected components but before doing so a messege will pop asking "Are you sure?".
              In the mean time just in case all of the setting values are stored on component is name. You can access that by opening "Entity Info" window. There you can manually remove it or you can use Set:: URL and erase the content there I believe.
              Cheers!
                Litchi
                thanks! 😄
                Clear:: Selected
                Clear:: All
                Cheers!
                that's great,thanks!
                I look forward to your new works!
                  renderiza
                  GOSU v1.0.4 Released!
                  1.0.4:: 4/23/2013
                  *Set :: Name - Allows you to set a specific name to any component.
                  *Set :: Empty - Allows you to clear the name of any component.
                  *Reset Button - This will remove the 'Set:: Attributes' of every component
                  Again thanks for the comments & suggestions!
                    Litchi
                    [attachment=0:3i6adbg9]<!-- ia0 -->dlg-1.jpg<!-- ia0 -->[/attachment:3i6adbg9]
                    1.0.4:: 4/23/2013
                    Thanks,Your work with remarkable efficiency!
                    Do you agree with me to reprint your files to other forums?
                    I promise I will retain the original URL and the name of the author
                    I want to share it with more people
                    Again thanks !
                      renderiza
                      Again thanks !
                      I will be happy if you shared this with other people on other forums. 👍
                        TECHDAVE02
                        Am I right that GOSU will only do 1 function at a time??
                        If so what about a right click sub menu to choose function???
                        My pause button is not working
                        rest works great so far.
                          renderiza
                          Gosu can do multiple functions in some cases since it uses the same component name for all "Set::" parameters. The "Set:: Scene" and "Set:: Layer" are the ones that can be repeated with another "Set::" option withoud any issues...Let me give you an example;
                          Example A
                          1. Set:: URL = http://www.sketchUcation.com
                          2. Set:: Scene = http://www.sketchUcation.com
                          3. Set:: Layer = http://www.sketchUcation.com
                          ^^When you use ::Gosu:: it will active URL,Scene and Layer at the same time.
                          Example B
                          1. Set:: Sound = C:\Users\name\Desktop\folders\audio.wav
                          2. Set:: Scene = C:\Users\name\Desktop\folders\audio.wav
                          3. Set:: Layer = C:\Users\name\Desktop\folders\audio.wav
                          Note: Again notice how Set:: Scene & Set:: Layer can be combine with other "Set::" Options.
                          This is great idea I will try to add it on next version...thanks!
                          What the Pause button is supposed to do is deactivate tool be leave the web dlg window instead to closing it like the close button do. If this does not work try hitting 'Esc' key or Select another tool like the Select tool. I will see if I can find the issue...thanks.
                          Cheers!
                            smicha
                            I just watched a video tutorial - your plugin is great!
                              renderiza
                              Thank you sir for does kind words! 👍
                                smicha
                                Rafael,
                                I have a very very very big wish, and I think you can introduce it into your great plugin. This would speed up sketchup many many times. You are a very talented programmer, so I truly think/believe that you can do it 😄
                                I may say in advance that I saw such a solution in a very famous 3d software 😄
                                The point is: let's assume I have a component (or a group, it should apply to both, but components are more important to me) and let's assume that this components have 1 million polygons. Now lets assume I have 100 copies of this component. Yes - 100 millions polygons altogether (BTW it's not a problem for Octane Render using instancing with great TIG's plugin - see Octane forum). We all know how such geometry may affect speed of SU - orbiting, zooming can be a real nightmare. Now imagine I select one copy of a component, go to your plugin, choose a new option eg. "Set:: bounding box" and only bounding boxes (frames only) become visible. Just 12 edges of a bounding box instead of millions. We can assign a shortcut key like "alt+B" to turn on/off this option. And now orbiting, zooming, navigation would be so fast.
                                An extra option would be to give a user a choice to turn on/off bounding boxes on all of same components or on all but the selected one.
                                Tell me what you think and if the idea is clear to you and of course if it is possible to code?
                                Kind regards,
                                Sebastian
                                PS. I attach some screenshots with the idea.
                                1. Copies of a component.
                                2. First version of a plugin function - frames on each copy of a component.
                                3. Second version of a plugin function - frames on each copy of a component but not selected one.
                                https://lh6.googleusercontent.com/-1xVKBuxKshA/UXpcW92rTLI/AAAAAAAADwQ/D_U4dQdqb-M/w1000/bb1.jpg
                                https://lh6.googleusercontent.com/-6H00eE2whMA/UXpcW_kfmyI/AAAAAAAADwI/fHshc4H9GUo/w1000/bb2.jpg
                                https://lh6.googleusercontent.com/-f3JnCBrgZXc/UXpcW-eeudI/AAAAAAAADwM/wFnDjGE5wDQ/w1000/bb3.jpg
                                  renderiza
                                  ::smicha::
                                  Hi, very clear explanation! 👍
                                  Here is a video for "Bounding Box View" Plugin found here... http://sketchucation.com/forums/viewtopic.php?t=21427
                                  I have not tested "Bounding Box View" plugin yet to know if your suggested extra options is available but for the most part its pretty close to what you asked I think.
                                  Tell me if that plugins was what you wanted if not maybe something else can be worked out.
                                  Cheers!
                                    smicha
                                    It's almost it. But selecting one component and running the plugin should also change all other components without a need of selecting them. And an option to have one selected component visible and rest in a form of frames would be so useful.
                                    Perfect solution (for me) would look like this: select a component, apply the plugin - frames on all components, apply it again - frames on all but selected, apply again - go back to an original view. And a dream 😄 is to assign one shortcut, eg. 'F6'.
                                    What do you think Rafael?
                                      renderiza
                                      Sounds like a plan! I will put this things on my to do list and hopefully make it happen in a reasonable amount of time. I like to realease simple scripts that solve just a few of your suggestions and then refine it by updates.
                                      No promises since I have extra work but I think is a good idea so I will try.
                                      This is done already just need to check few thing so I can release it.
                                      Cheers
                                        renderiza
                                        GOSU v1.0.5 Released!
                                        [highlight=#bfff00:hy2ldg96]1.0.5:: 4/26/2013[/highlight:hy2ldg96]
                                        • Right click sub menu to choose functions.
                                        Cheers!
                                          renderiza
                                          Hey I stumbled upon this ... http://sketchucation.com/forums/viewtopic.php?f=180&t=21334
                                          Please tell me what you think...cheers!
                                            smicha
                                            I saw ghostcomp yesterday - great plugin but its use is not as fast as I wanted. It introduces extra layer, wireframe is only for original component (box is with sides). Anyway ghostcomp is a great plugin.
                                            • 2 / 4
