    Easy question about shadow problem
    renderpluginsextensions
    9 Posts 6 Posters 757 Views 6 Watching
      decumano
      I'm finishing an exterior render but I have a problem with trees' shadow.
      Even if I'm going to work with PS when the Vray render is done, I need to understand how I can get a correct shadow: setting the tree component always in "front of the camera" as you can see the shadow (when the sun is not perpendicular to the image) is slim...
      what can I do?
      thanks
        broomstick
        A quick way to have reliable shadows is to do away with the face-me components, and put two copies of the tree group in the shape of a cross. For trees that are far away from the camera you can very often get away with it.
        If this doesn't work, then you have to use a 3D model... Welcome to a world of pain..
        • V Offline
          valerostudio
          You are always going to get the best results from a 3D tree. I highly recommend Alan's Geometree series from FormFonts. If you don't have a Formfonts account, there are some great 3D trees on the Warehouse.
            decumano
            And that's what I did...
            Initially I tried with 3d trees but SU gave me always error. The reason I think it's the big number of trees:
            Then I tried with groups of crossing trees:
            but it's to hard to modify this render with PS to arrive to something like this:
            I should do 7 or 8 render.. and it's a really long work
            Yes, i'm welcome in a world of pain...!!!
            Anything else?
              andybot
              perhaps you can still use the crossed trees, but use a copy of your material for the sideways facing tree that has "only in secondary" option checked. That way it is hidden in your render, but still casts shadows.
              • panixiaP Offline
                panixia
                that's very intersting.. i'll try too..
                  decumano
                  I'm so sorry, I forgot to answer to this topic! Thank you andybot, I tried the "only in secondary" option, it works!
                  thanks
                  bye
                  • 3 Offline
                    3dita
                    I was looking for this option in sketchup (similar to the "invisible to camera" in 3ds max) but did not know this was it.
                    THANK YOU!
                    3dita - Digital Visual Motion
                    • V Offline
                      valerostudio
                      You can now also using proxies in 1.6 and never have to deal with fake trees ever again!
