    Multi Face Scale Offset?
    22 Posts 5 Posters 5.9k Views 5 Watching
      Some foggy, an image ? ๐Ÿ˜„
        Aerilius
        A modification of Multi Face Offset where the resulting face has an area of the previous face ยฑ x%.
        The challenge would be to predict the offset area, which is not exactly the previous face multiplied by (100+x)%.
        • olisheaO Offline
          olishea
          Will make an image now. I think Greeble may be able to do it...
          oli
          • olisheaO Offline
            olishea
            Greeble still requires minimum/maximum DISTANCES. you can only scale the greebled face.
            That's how I should have written it!! You understand. I'm making an image now.
            oli
            • olisheaO Offline
              olishea
              Here we go...added image to original post.
              oli
              • cottyC Offline
                cotty
                ...a combination of TIGs Scale Face to target area, his smart offset and the multi...?
                my SketchUp gallery
                  Ok but in this case your structure will have a curious form of supports! ๐Ÿ˜„
                  How do you will resolve the junctions ? ๐Ÿ’š
                  Juxtaposition ?
                  I don't believe that a plug is yet existing for all levels in the same time ๐Ÿ˜•
                  Or maybe something with Panelization by Sdmitch ?
                  And on your example it is not 50 % but 25 % !!! ๐Ÿ˜‰
                  4 / 16 = 25 % ๐Ÿ˜‰
                  • olisheaO Offline
                    olishea
                    Juxtaposition ?
                    4 / 16 = 25 % ๐Ÿ˜‰
                    [attachment=1:1ltkz9b9]<!-- ia1 -->25.jpg<!-- ia1 -->[/attachment:1ltkz9b9]
                    Lol of course more coffee for me....scaling by 0.5 gives new area of 25% of the original. Thanks Pilou, you're on the ball today!! ๐Ÿ‘
                    Let me worry about the structure.....that model is just an example. Where there are smaller quads, I want the structure to become more "filigree".
                    Cheers Cotty, will look into those now.
                    Pilou, this is what I'm going for....but mesh isn't great.
                    oli
                      Aerilius
                      Ooops, this is Ruby (not JavaScript). Fixed!
                        I select my faces then call the Plug : nothing appen! ๐Ÿ˜ฎ
                        (tested in v7 )
                        Same for simple boxes
                          Ok! Cool! Works fine! โ˜€
                          Maybe will be useful that the new faces will be the new selection! ๐Ÿ’ญ
                          here the selection are still out the new faces at the end of the plugin!
                            Aerilius
                            Now selection of new faces.
                            With colors, for you ๐Ÿ˜†
                              Very cool! ๐Ÿ˜Ž
                              Maybe you can Inverse the number enter on inner "White / Blue" Surface
                              I must enter -50 on "White" surface !
                              And a little problem ๐Ÿ˜‰
                                Aerilius
                                That is a bug in offset (same bug is also in SketchUp's offset tool). I now changed the direction, and if you install TIG's smart offset, it will use that.
                                  Aerilius
                                  Ok, this could do it:
                                  This modified script (based on Remus' multi_face_offset.rb) does a relative offset depending on the area of the face and the given percentage.
                                  The percentage is not mathematically accurate for any shape (only accurate for rectangle and circle).
                                  requires offset.rb (http://www.smustard.com/freescripts/Offset)
                                    Many thx! โ˜€
                                      My Smart-Offset is also not perfect ! I have some improvements to make but these are at the bottom of a long 'to-do-list'... On relatively simple forms it will avoid the standard offset's 'bowtie' issues...
                                      • olisheaO Offline
                                        olishea
                                        I just got back home to check this thread!!
                                        WOW!!
                                        Gonna give it a go now.
                                        No, don't make the new faces the selection!! Just double the offset %....I can use split donut if old faces remain selected....or maybe give a choice before execution, or maybe it makes no difference anyway.This is exciting!! ๐Ÿ˜„
                                        oli
                                        • olisheaO Offline
                                          olishea
                                          IT WORKS!!!! ๐Ÿ˜ Great plugin! ๐Ÿ˜„
                                          oli
                                            Aerilius
                                            Time to start with Ruby ๐Ÿ˜‰
                                            When you open the ruby file, you can see where I have written "Select new faces".
                                            Just comment out line 54 and 55 by adding a # at the beginning of the line.
