    Multi Face Scale Offset?
    22 Posts 5 Posters 6.1k Views 5 Watching
      Aerilius
      Ooops, this is Ruby (not JavaScript). Fixed!
        I select my faces then call the Plug : nothing appen! ๐Ÿ˜ฎ
        (tested in v7 )
        Same for simple boxes
          Ok! Cool! Works fine! โ˜€
          Maybe will be useful that the new faces will be the new selection! ๐Ÿ’ญ
          here the selection are still out the new faces at the end of the plugin!
            Aerilius
            Now selection of new faces.
            With colors, for you ๐Ÿ˜†
              Very cool! ๐Ÿ˜Ž
              Maybe you can Inverse the number enter on inner "White / Blue" Surface
              I must enter -50 on "White" surface !
              And a little problem ๐Ÿ˜‰
                Aerilius
                That is a bug in offset (same bug is also in SketchUp's offset tool). I now changed the direction, and if you install TIG's smart offset, it will use that.
                  Aerilius
                  Ok, this could do it:
                  This modified script (based on Remus' multi_face_offset.rb) does a relative offset depending on the area of the face and the given percentage.
                  The percentage is not mathematically accurate for any shape (only accurate for rectangle and circle).
                  requires offset.rb (http://www.smustard.com/freescripts/Offset)
                    Many thx! โ˜€
                      My Smart-Offset is also not perfect ! I have some improvements to make but these are at the bottom of a long 'to-do-list'... On relatively simple forms it will avoid the standard offset's 'bowtie' issues...
                      • olisheaO
                        olishea
                        I just got back home to check this thread!!
                        WOW!!
                        Gonna give it a go now.
                        No, don't make the new faces the selection!! Just double the offset %....I can use split donut if old faces remain selected....or maybe give a choice before execution, or maybe it makes no difference anyway.This is exciting!! ๐Ÿ˜„
                        oli
                        • olisheaO
                          olishea
                          IT WORKS!!!! ๐Ÿ˜ Great plugin! ๐Ÿ˜„
                          oli
                            Aerilius
                            Time to start with Ruby ๐Ÿ˜‰
                            When you open the ruby file, you can see where I have written "Select new faces".
                            Just comment out line 54 and 55 by adding a # at the beginning of the line.
                            • olisheaO
                              olishea
                              Will give it a go now. Excellent work Aerilius!!
                              And GREAT images Pilou! ๐Ÿ˜„
                              oli
