    [Plugin] Hypocycloid Cam Profile Generator v1.0.0
    12 Posts 5 Posters 5.5k Views 5 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      Generate 2D profiles of hypocycloid cams for cycloid drives.
      SEE wikipedia: Cycloidal Drive
      This has nothing to do with curves made with the Spirograph toy !
      Translated into SketchUp Ruby, from Alex Lait's Python script
      Aal_Hypocycloid_1_0_0.rbz
      Git repository : Issues & Feature Requests
      Notes:
      Does not currently do ANY checking for sane input values and it
      is possible to create un-machinable cams, use at your own risk.
      Suggestions:
      • Eccentricity should not be more than the pin radius.
      • Has not been tested with negative values, may have interesting results!
      πŸ€“
      I'm not here much anymore.
      • renderizaR Offline
        renderiza
        Time to google what hypocycloid means...sounds good!
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
          Please post image on the first post of a plugin! β˜€
          Does it this
          http://infosthetics.com/archives/scrambler_drawings.jpg
          or this ?
          http://www.samstoybox.com/toypics/SpirographBox.jpg
            Ah that is something like this! πŸ˜„
              renderiza
              When I was a kid I remember having that toy!
                Dan Rathbun
                I will ... and there are reference links in the file headers.
                  I don't see thickness like your image result on the first post
                  I miss something ? (just tested in v7)
                    Dan Rathbun
                    I push-pulled the face up manually.
                    This plugin is for creating profiles for CNC routing machines that will cut the cam.
                      Dan Rathbun
                      OK driven and I are planning to 3D-ize this plugin.
                      The old CNC dxf way is out of style. John wants to use SketchUp to have cams 3D Printed.
                      So we'll be making new 3D features. (But we'll leave the 2D layers with the 2D profiles.)
                        added to store
                        • gullfoG Offline
                          gullfo
                          http://en.wikipedia.org/wiki/Epitrochoid
                          http://en.wikipedia.org/wiki/Hypocycloid
                          looks more like the former than the latter...
                          and then there's:
                          http://en.wikipedia.org/wiki/Hypotrochoid
                          Glenn
                          http://www.runnel.com
                            Dan Rathbun
                            πŸŽ‰
