πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Script selects the line or face.(UPDATED 15/02/16)
26 Posts 15 Posters 21.5k Views
    sahi
    The script selects the line or face.
    The first icon >> click on it - and only the lines stand out >> again click on it >> disables script
    The second icon >> click on it - and distinguished only by persons >> again click on it deactivates the script >>
    It selects only the face or edge or hidden lines
    • topic:timeago-later,6 months
      I added a tutorial to this plugin as I think it is an essential tool in SketchUp. πŸ‘
        dtrarch
        Sahi
        Just a killer app and thank you very much
        dtr
          mitcorb
          Great concept. Congratulations, sahi. And thank you, Rich, for that video.
          Now, a real trick would be to select only vertices. πŸ’š
          • E Offline
            Edson
            sahi,
            great plugin! I suggest you change the title of this topic to reflect the exact name of your plugin. otherwise people will have a hard time find it, as was my case. something like [Plugin] selection_edge would work nicely. by the same token, why does the name of the plugin reflect what it does? selection_edge does not tell one that it also select faces.
            best regards.
            http://www.mahfuz.arq.br
              mitcorb
              How about Plugin: Select/Isolate Edge or Face.
              How about Plugin: Discrete Selection Edge or Face.
              Either one is all yours-- or none of the above.
                sahi
                Hi!
                Thanks Rich O Brien
                PS:I do not speak English so it's hard to explain all the functions of the plug
                • topic:timeago-later,about a month
                • I Offline
                  irwanwr
                  [Edited]
                  Got it. Can see the difference between this plugin with TT Selection Toys.
                  Thank you Sahi, for this one, Axes Comp and Krug. I think this should be one of my "must have" plugin πŸ˜„
                  • topic:timeago-later,3 months
                    cityblueskyz
                    Thank you very much for sharing
                    It really is a very convenient plug-in πŸ‘
                      This sort of selection don't yet existing in another plugins ? ( Selection Toys etc...)
                      • topic:timeago-later,11 months
                        snakeysnape
                        Hi All,
                        I wonder if anybody else is experiencing it, but this plug-in don't work for me when I use it with SU 2014. Previously in SU8 with select face toggled on even if I triple click a model only face would be selected as expected but for SU2014 edges are included in the selection.
                        I hope this gets resolved, as its been a real helpful plugin for me.
                          sdmitch
                          I have experienced the same results. Works perfectly in SU8 but fails in SU2014 with no errors reported in the Ruby Console.
                          http://sdmitch.blogspot.com/
                            cotty
                            Until then, you can use Thomthoms selections toys as an alternative for this task.
                            my SketchUp gallery
                              sdmitch
                              The code
                              edges=sel.grep(Sketchup;;Edge); sel.clear; sel.add edges
                              works in SU2014 but causes a stack error that crashes SU8.
                                driven
                                @sdmitch said:
                                The code...
                                on mac both
                                sel=Sketchup.active_model.selection
                                edges=sel.grep(Sketchup;;Edge).to_a; sel.clear; sel.add edges
                                work in v8 and v2014
                                  sdmitch
                                  Apparently my v8 is different because it still crashes with that addition.
                                    driven
                                    my test file had less than 2000 edges so is it a limit?
                                      sdmitch
                                      No I was using a small sample consisting of 3 or 4 faces.
                                      I did find a solution that works in both SU8 and SU2014 and that was to remove the observer before processing the selection and add it back after while using the selection processing code previously posted.
                                      	def onSelectionBulkChange(selection)
                                      		Sketchup.active_model.selection.remove_observer self
                                      		get_selection_edge(selection) if(@select_edge)
                                      		# get_selection_edge_smooth(selection) if(@edge_smooth)
                                      		get_selection_face(selection) if(@select_face)
                                      		Sketchup.active_model.selection.add_observer self
                                        snakeysnape
                                        Hi Sdmitch,
                                        Sorry but can you post the fixed plugin in here? I am confused as to where to put the selection code.
                                        thanks
                                          sdmitch
                                          @snakeysnape said:
                                          Hi Sdmitch,
                                          thanks
                                          With apologies to Sahi.
                                          selection_edge.rb
                                          1 / 2
