    [Plugin] Script selects the line or face.(UPDATED 15/02/16)
    26 Posts 15 Posters 23.0k Views 15 Watching
      sahi
      The script selects the line or face.
      The first icon >> click on it - and only the lines stand out >> again click on it >> disables script
      The second icon >> click on it - and distinguished only by persons >> again click on it deactivates the script >>
      It selects only the face or edge or hidden lines
        I added a tutorial to this plugin as I think it is an essential tool in SketchUp. 👍
          dtrarch
          Sahi
          Just a killer app and thank you very much
          dtr
          • mitcorbM Offline
            mitcorb
            Great concept. Congratulations, sahi. And thank you, Rich, for that video.
            Now, a real trick would be to select only vertices. 💚
            • EdsonE Offline
              Edson
              sahi,
              great plugin! I suggest you change the title of this topic to reflect the exact name of your plugin. otherwise people will have a hard time find it, as was my case. something like [Plugin] selection_edge would work nicely. by the same token, why does the name of the plugin reflect what it does? selection_edge does not tell one that it also select faces.
              best regards.
              http://www.mahfuz.arq.br
              • mitcorbM Offline
                mitcorb
                How about Plugin: Select/Isolate Edge or Face.
                How about Plugin: Discrete Selection Edge or Face.
                Either one is all yours-- or none of the above.
                  sahi
                  Hi!
                  Thanks Rich O Brien
                  PS:I do not speak English so it's hard to explain all the functions of the plug
                  • irwanwrI Offline
                    irwanwr
                    [Edited]
                    Got it. Can see the difference between this plugin with TT Selection Toys.
                    Thank you Sahi, for this one, Axes Comp and Krug. I think this should be one of my "must have" plugin 😄
                      cityblueskyz
                      Thank you very much for sharing
                      It really is a very convenient plug-in 👍
                        This sort of selection don't yet existing in another plugins ? ( Selection Toys etc...)
                          snakeysnape
                          Hi All,
                          I wonder if anybody else is experiencing it, but this plug-in don't work for me when I use it with SU 2014. Previously in SU8 with select face toggled on even if I triple click a model only face would be selected as expected but for SU2014 edges are included in the selection.
                          I hope this gets resolved, as its been a real helpful plugin for me.
                          • sdmitchS Offline
                            sdmitch
                            I have experienced the same results. Works perfectly in SU8 but fails in SU2014 with no errors reported in the Ruby Console.
                            http://sdmitch.blogspot.com/
                            • cottyC Offline
                              cotty
                              Until then, you can use Thomthoms selections toys as an alternative for this task.
                              my SketchUp gallery
                              • sdmitchS Offline
                                sdmitch
                                The code
                                edges=sel.grep(Sketchup;;Edge); sel.clear; sel.add edges
                                works in SU2014 but causes a stack error that crashes SU8.
                                  driven
                                  @sdmitch said:
                                  The code...
                                  on mac both
                                  sel=Sketchup.active_model.selection
                                  edges=sel.grep(Sketchup;;Edge).to_a; sel.clear; sel.add edges
                                  work in v8 and v2014
                                  • sdmitchS Offline
                                    sdmitch
                                    Apparently my v8 is different because it still crashes with that addition.
                                      driven
                                      my test file had less than 2000 edges so is it a limit?
                                      • sdmitchS Offline
                                        sdmitch
                                        No I was using a small sample consisting of 3 or 4 faces.
                                        I did find a solution that works in both SU8 and SU2014 and that was to remove the observer before processing the selection and add it back after while using the selection processing code previously posted.
                                        	def onSelectionBulkChange(selection)
                                        		Sketchup.active_model.selection.remove_observer self
                                        		get_selection_edge(selection) if(@select_edge)
                                        		# get_selection_edge_smooth(selection) if(@edge_smooth)
                                        		get_selection_face(selection) if(@select_face)
                                        		Sketchup.active_model.selection.add_observer self
                                          snakeysnape
                                          Hi Sdmitch,
                                          Sorry but can you post the fixed plugin in here? I am confused as to where to put the selection code.
                                          thanks
                                          • sdmitchS Offline
                                            sdmitch
                                            @snakeysnape said:
                                            Hi Sdmitch,
                                            thanks
                                            With apologies to Sahi.
                                            selection_edge.rb
