    SU 9 Wishlist
    436 Posts 99 Posters 181.7k Views 99 Watching
    • jo-keJ
      jo-ke
      My wish would be:
      that SU is going to be able to handle more complex models.
      It is such a pitty, if I get some nice highpoly furniture models but they are to huge to insert to my scene. sometimes I wish to have 3dsmax to handle that problem.
      better texturing tools inside SU would also be nice.
      when will be the next version released?
      http://www.zz7.de
        In 2013.
        • C
          cuttingedge
          I know there's a lot of people wish SU work like 3ds max wherein modifiers can be stacked.
          If that is still years away from now, at least , I wish that SU can have subdivision tools (like Artisan) that can toggle low poly to high poly by controlling iterations or turn it off altogether. The thing is once a low poly geometry is smoothed or subdivided, it's difficult to edit anymore. The solution left is to always keep a copy of the low poly by the side which is not really convenient thing to do especially if most of the objects are kind of organic in shapes.
          Also, if this is done then we can keep models on low poly thus keeping the size of the file smaller.
          I wish that there will be x-ref function or a proxy system to make it more efficient in handling complex geometries.
          And I wish it will be soon..
            No promise to when, but... http://sketchucation.com/forums/viewtopic.php?t=32810#p289240
              Many render engines implement proxy systems already.
              • pbacotP
                TT. But I think he means for SU to handle complex geometries. The difference might be to at least preview the whole model in SU, not a renderer, with all models linked.
                It is a little like external components now, except there is currently no performance savings in the main model and no update/link system. My method is to work on a building in a separate model, then reload it into the landscape model to view it in entourage and terrain. Instead an XREF system might have me working in one model with the ability to turn off the "weight" of polygons from linked slave models.
                • C
                  cuttingedge
                  Oh yes of course and I dream day and night to get hold of this plugin. 😄
                  Im not clear though what else it can do aside from what's shown in the video.
                  What Im talking about in my previous comment was like "nurms" subdivision that you tick on and off. Hope that's one feature you incorporated.
                  Finally, I hope SU can be rebuilt to work in quads, then importing and exporting from other platforms could be done seamlessly.
                    It let you choose sub-divisions for the mesh - in fact, I plan to make it so you can have instance of the same mesh with different sub-divisions.
                    Yea - native quads would be great. QuadFace Tools replicate a lot of tools to work with quads, even import and export. But it'd be nice to see that native.
                    • N
                      numerobis
                      Yes, PLEASE!!! quads & subD for sketchup!
                      and yes, XREFs would be nice, but simply to decrease the insanely long saving/autosaving times by splitting up the model...
                      I really can't understand how a 200MB sketchup file can take 4:30 min to save!!!
                      • G
                        giolio
                        I would like to have better 2D drawing tools in LayOut!
                        • F
                          fluffy82
                          I would love for some improvement in the follow me tool:
                          1. when doing a follow me, I'd like it to create a new group automatically --> now you need to make a group out of the profile, open the group, retrace the path within the group and then extrude. That's a lot of work, sometimes... Especially when you have complicated paths.
                          2. I'd love for it to "remember" the initial parameters so I can modify either the profile or the path afterwards, affecting the result, without having to redraw the complete thing.
                          3. Changing the profile also involves changing the number of faces/segments. For example, if you extrude a crown moulding with a round part in it, you should be able to change the number of segments in the profile if needed.
                            I think your work flow could be more efficient than you describe. I frequently have need to draw things like crown moldings but haven't done it the way you describe and have no problems.
                            @fluffy82 said:
                            1. I'd love for it to "remember" the initial parameters so I can modify either the profile or the path afterwards, affecting the result, without having to redraw the complete thing.
                            What parameters?
                              You need this plugin:
                              http://www.smustard.com/script/ProfileBuilder
                              Free version is also available:
                              http://sketchucation.com/forums/viewtopic.php?t=44237
                              • GaieusG
                                Exactly. Excellent plugin and does what you listed.
                                • jeff hammondJ
                                  @dave r said:
                                  What parameters?
                                  he's talking about history modeling.. (or at least that's the term i know it as)
                                  -draw a path & profile
                                  -follow me
                                  -move, say, a vertex of the path
                                  -the extrusion updates accordingly
                                  • F
                                    fluffy82
                                    If you extrude the profile without making it into a group first, it becomes virtually impossible to group afterwards (I make rather complicated crown mouldings with loads of corners, "popping out" on top of a column etc)
                                    @dave r said:
                                    What parameters?
                                    The form of the profile, the path it follows,... If you need to make a change now, you need to delete it and start over.
                                    • F
                                      fluffy82
                                      Super, I'll check it out immediately!
                                      -follow me
                                      Yes... I am very bad at explaining myself... But that's exactly what I mean.
                                        It certainly is possible to make it a group afterward. And it is quite simple. Why would you think it is "virtually impossible"? 😒
                                          If the operation is done in a model where other objects aren't grouped. Then it merge with other geometry. That's why I keep telling the people at my office to always group (or make components) out of everything - and organize the model properly.
                                            Indeed!
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 21 / 22
