Photo match?!
It seems to me that after modifying the style, you did not update it. Click on the thumbnail image of it at the top left (where those circular arrows are now).
This really driving me crazy haha.. Its not working clicking on the tumbnail when got the photosetup or after.. Nothing happends, still the same problem.
In this video (around 4 minutes in) it seems he's not doing a thing, his texture just follows with the photo setup.
/ N
The link doesn't work (for me)?!
neither to me.
Niclas, I guess you need to close the PM window in order to access other dialogs. In your screenshot, the Styles dialog is greyed out (i.e. inaccessible)
try that link instead
What am I doing wrong then? XD
Perhaps if you attach the model itself someone can have a look.
I bet that would be the best. Also I have no idea what you are trying to do here - so some info (as to what to achieve)) would be nice.
From the screen-shots, it is unclear what you want to "match" at all...
Sorry if I'm not being clear enough, what I want to achieve is:
- Make a photo setup of the pic up
- That my models texture (white walls, wooden garage, chromed door) stays in the model after importing the photo. NOT turn into transcluent as the attach.
If you'd just post the SKP file we could help you out and get this over with.
It doesn't seem there is anything unusual with the file. In the Styles window under EDIT and the "Modelling:" Tab, un-check "Foreground" photo" under "Match Photo" --or adjust opacity.
Then when you perform Match Photo the model faces will be visible.Save the style the way you want it. And update the match photo scene for good measure.
Note you must choose "done" in the MatchPhoto dialog (leave perspective setup mode) to perform other operations like updating the scene.
@gaieus said:
@pbacot said:
try adjustment to the "watermark" opacity in the styles window.
It's not the watermark settings but under Modelling settings:
Yeah well... it's in the Styles anyway
Should work as Gaieus says. Who knows on that video?
[edit: it is how he had his style setup prior to performing Match Photo] -
Ahhh finally! Haha thank you A small detail that mess up everything haha..
Another question:
Is it impossible to export the modell with the background photo to Maxwell Render?
When I tried the photo didnt showed up in the Render program? -
Here is a similar discussion with some ideas.
Thank you, Ill read it
Hi Niclasbladh
Can you post the photo?
