    Photo match?!
    27 Posts 7 Posters 1.6k Views 7 Watching
    • N Offline
      Niclasbladh
      Allright here it is!
      Thanks for taking your time! πŸ˜„
      Problem.skp
      • pbacotP Offline
        It doesn't seem there is anything unusual with the file. In the Styles window under EDIT and the "Modelling:" Tab, un-check "Foreground" photo" under "Match Photo" --or adjust opacity.
        Then when you perform Match Photo the model faces will be visible.
        Save the style the way you want it. And update the match photo scene for good measure.
        Note you must choose "done" in the MatchPhoto dialog (leave perspective setup mode) to perform other operations like updating the scene.
        • pbacotP Offline
          @gaieus said:
          @pbacot said:
          try adjustment to the "watermark" opacity in the styles window.
          It's not the watermark settings but under Modelling settings:
          Yeah well... it's in the Styles anyway πŸ˜›
          Should work as Gaieus says. Who knows on that video?
          [edit: it is how he had his style setup prior to performing Match Photo]
          • N Offline
            Niclasbladh
            Ahhh finally! Haha thank you πŸ˜„ A small detail that mess up everything haha..
            Another question:
            Is it impossible to export the modell with the background photo to Maxwell Render?
            When I tried the photo didnt showed up in the Render program?
            • cottyC Offline
              cotty
              Here is a similar discussion with some ideas.
              my SketchUp gallery
              • N Offline
                Niclasbladh
                Thank you, Ill read it πŸ˜„
                • beginnerB Offline
                  beginner
                  Hi Niclasbladh
                  Can you post the photo?
                  Regards, SU 'beginner'
                  • 2 / 2
