    Photo match?!
    27 Posts 7 Posters 1.5k Views 7 Watching
      It seems to me that after modifying the style, you did not update it. Click on the thumbnail image of it at the top left (where those circular arrows are now).
      • N Offline
        Niclasbladh
        This really driving me crazy haha.. Its not working clicking on the tumbnail when got the photosetup or after.. Nothing happends, still the same problem.
        In this video (around 4 minutes in) it seems he's not doing a thing, his texture just follows with the photo setup.
        / N
        • cottyC Offline
          cotty
          The link doesn't work (for me)?!
          my SketchUp gallery
            neither to me.
            Niclas, I guess you need to close the PM window in order to access other dialogs. In your screenshot, the Styles dialog is greyed out (i.e. inaccessible)
            • N Offline
              Niclasbladh
              • N Offline
                Niclasbladh
                try that link instead
                • N Offline
                  Niclasbladh
                  What am I doing wrong then? XD
                  • BoxB Offline
                    Perhaps if you attach the model itself someone can have a look.
                      I bet that would be the best. Also I have no idea what you are trying to do here - so some info (as to what to achieve)) would be nice.
                      From the screen-shots, it is unclear what you want to "match" at all...
                      • N Offline
                        Niclasbladh
                        Sorry if I'm not being clear enough, what I want to achieve is:
                        1. Make a photo setup of the pic up
                        2. That my models texture (white walls, wooden garage, chromed door) stays in the model after importing the photo. NOT turn into transcluent as the attach.
                          If you'd just post the SKP file we could help you out and get this over with.
                          • N Offline
                            Niclasbladh
                            Allright here it is!
                            Thanks for taking your time! πŸ˜„
                            Problem.skp
                            • pbacotP Offline
                              It doesn't seem there is anything unusual with the file. In the Styles window under EDIT and the "Modelling:" Tab, un-check "Foreground" photo" under "Match Photo" --or adjust opacity.
                              Then when you perform Match Photo the model faces will be visible.
                              Save the style the way you want it. And update the match photo scene for good measure.
                              Note you must choose "done" in the MatchPhoto dialog (leave perspective setup mode) to perform other operations like updating the scene.
                              • pbacotP Offline
                                @gaieus said:
                                @pbacot said:
                                try adjustment to the "watermark" opacity in the styles window.
                                It's not the watermark settings but under Modelling settings:
                                Yeah well... it's in the Styles anyway πŸ˜›
                                Should work as Gaieus says. Who knows on that video?
                                [edit: it is how he had his style setup prior to performing Match Photo]
                                • N Offline
                                  Niclasbladh
                                  Ahhh finally! Haha thank you πŸ˜„ A small detail that mess up everything haha..
                                  Another question:
                                  Is it impossible to export the modell with the background photo to Maxwell Render?
                                  When I tried the photo didnt showed up in the Render program?
                                  • cottyC Offline
                                    cotty
                                    Here is a similar discussion with some ideas.
                                    my SketchUp gallery
                                    • N Offline
                                      Niclasbladh
                                      Thank you, Ill read it πŸ˜„
                                      • beginnerB Offline
                                        beginner
                                        Hi Niclasbladh
                                        Can you post the photo?
                                        Regards, SU 'beginner'
