    Photo match?!
    27 Posts 7 Posters 2.3k Views 7 Watching
    • GaieusG
      @box said:
      Perhaps if you attach the model itself someone can have a look.
      I bet that would be the best. Also I have no idea what you are trying to do here - so some info (as to what to achieve)) would be nice.
      From the screen-shots, it is unclear what you want to "match" at all...
      • N
        Niclasbladh
        Sorry if I'm not being clear enough, what I want to achieve is:
        1. Make a photo setup of the pic up
        2. That my models texture (white walls, wooden garage, chromed door) stays in the model after importing the photo. NOT turn into transcluent as the attach.
          If you'd just post the SKP file we could help you out and get this over with.
          • N
            Niclasbladh
            Allright here it is!
            Thanks for taking your time! πŸ˜„
            Problem.skp
            • pbacotP
              It doesn't seem there is anything unusual with the file. In the Styles window under EDIT and the "Modelling:" Tab, un-check "Foreground" photo" under "Match Photo" --or adjust opacity.
              Then when you perform Match Photo the model faces will be visible.
              Save the style the way you want it. And update the match photo scene for good measure.
              Note you must choose "done" in the MatchPhoto dialog (leave perspective setup mode) to perform other operations like updating the scene.
              • pbacotP
                @gaieus said:
                @pbacot said:
                try adjustment to the "watermark" opacity in the styles window.
                It's not the watermark settings but under Modelling settings:
                Yeah well... it's in the Styles anyway πŸ˜›
                Should work as Gaieus says. Who knows on that video?
                [edit: it is how he had his style setup prior to performing Match Photo]
                • N
                  Niclasbladh
                  Ahhh finally! Haha thank you πŸ˜„ A small detail that mess up everything haha..
                  Another question:
                  Is it impossible to export the modell with the background photo to Maxwell Render?
                  When I tried the photo didnt showed up in the Render program?
                  • cottyC
                    cotty
                    Here is a similar discussion with some ideas.
                    my SketchUp gallery
                    • N
                      Niclasbladh
                      Thank you, Ill read it πŸ˜„
                      • beginnerB
                        beginner
                        Hi Niclasbladh
                        Can you post the photo?
                        Regards, SU 'beginner'
                        • 2 / 2
