    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      Apparently, you are missing LibFredo6 library.
      Go to the main post of FredoScale and follow the instructions.
        You might also need to fix the Properties > Security setting for the Plugins folder to FULL for yourself...
          suntansue
          Thank you for your excellent work. Much appreciated.
          • gillesG Offline
            gilles
            Just a question about Radial Bender:
            Is there any reason I can't bend more than 180Β°?
              thundermatch
              πŸ’š Thank you for sharing...
                thegoodguy
                Amazing work! Thanks so much for this brilliant tool.
                • V Offline
                  Vicky21S
                  I've downloaded, extracted and put all the necessary files into the Plugin folder but for some reason cannot see the FredoScale options in Sketchup even when I restart. I've checked the preferences folder, tools panel and still nothing. Someone please help me with this, I am beyond frustrated.
                  • pbacotP Offline
                    Vicky,
                    1. Working backwards, You should get a listing in "Tool palettes" for a toolbar and under the Tools menu, "Fredo Collection >> Fredoscale".
                    2. You say you checked in Preferences? Is Fredoscale listed (and checked) in the Extensions window?
                    3. You've gone back to the SCF topics for Fredoscale and LibFredo and checked the requirements and specifics of file placement.
                    4. You saw the warning on the Fredoscale topic:
                      "IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed."
                    5. Everything seems right to you then probably the next thing is to post a screenshot of your plugin folder where it shows all the required files, and see if someone can see something out of place.
                    • W Offline
                      willie_0
                      Thanks Fredo6 your a rockstar..
                      cheers,
                      Willie
                      • fredo6F Offline
                        FredoScale, and more generally Ruby scripts, have problems to deal with fresh copies of group. Under the hood, these groups share a common definition until they are edited.
                        So in your case, I would suggest that you
                        • either use Make Unique feature of FredoScale
                        • Just double click of the Group A and B instances to make them unique
                          Taniouska111
                          πŸ˜„
                            bucksbedrooms
                            Bug [pretty sure anyway].
                            Hi I love this Fredoscale plugin and was going to make a donation but I am getting some buggy results which I hope there is a solution for. Please see attachments.
                            Some whole components move or don't move instead of scale.
                            Top drawer irratic scaling
                            • cottyC Offline
                              cotty
                              I've tried some scaling and everything works as expected. Can you desribe your goal more detailed?
                              my SketchUp gallery
                                jdkarg1989
                                Hi. I have a question. When I twist an object and conferm my sketchup crashes. What could this be?
                                • fredo6F Offline
                                  Are you working on a Group which has been freshly copied?
                                    Or is the object very tiny ?
                                    Or very large ??
                                      What are the dimensions of the original before bending?
                                        giorgio1979
                                        Lovely plugin. πŸ˜„ Another issue: Sometimes when I do a "radial bending by selection of plane" I get some missing faces on the bending side.
                                        PS: I restarted sketchup, and I cannot reproduce this anymore. Perhaps I set something in Fredolib somewhere during an operation.
                                        See image:
                                        http://s11.postimg.org/5vqbc093n/radial_bending_by_selection_of_plane.png
                                          giorgio1979
                                          Very small, 2mm * 5 mm rectangle, extruded to 5mm.
                                          I just tried to reproduce it after a restart but couldn't. Will post back when I have a consistent way to reproduce this. Same dimensions work fine on a clean slate.
                                            Typically SketchUp won't fill in tiny faces such as the ones being generated in your bending operation. For that reason it isn't much of a surprise that it didn't work. Perhaps the second time you tried it you weren't making such tiny faces?
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 56 / 57
