    [Plugin] LaunchUp – A Quick Launcher for SketchUp
    108 Posts 33 Posters 103.1k Views 33 Watching
      Oh! It remembers your last used items and place them on top! Nice!
        I also occasionally see the "Type to search..." string under text that has been entered. Can't quite reliably reproduce it though.
          Aerilius
          I forgot to add:
          • it is now possible to close the dialog when pressing the escape key.
          Isn't F5 the reload shortcut? I might have to test that reloading the JavaScript doesn't break it, or I add an override to prevent F5.
            Ah! Duh! Yea - I wasn't thinking of that. It's just that I've used all the "normal" keys.
              driven
              hi AE,
              for some reason the dialog window always starts bottom left corner, pinned, unpinned, same session or even after I close SU with it open.
              mac...
              • H
                hebeijianke
                something wrong in options at "custom color"
                • L
                  lionk
                  well done!thanks you!
                  another bug...
                  if I type some Chinese characters like "面"(it means "face"), there will be an error in ruby console and get no search results, then unable to search again.
                  ![Error: #<SyntaxError: (eval):1:in initialize': compile error (eval):1: unterminated string meets end of file (eval):1: syntax error, unexpected $end, expecting ']' ["look_up", "é?¢"]#16 ^>](/uploads/imported_attachments/x92F_20130416111835.jpg "Error: #<SyntaxError: (eval):1:in initialize': compile error
                  in light of this, i found these punctuations "?()[]{}+*" also make mistakes.
                    Aerilius
                    Thanks for finding that!
                    I also solved the custom color issue and will probably have an update later today.
                      Aerilius
                      Version 1.0.8 is available:
                      • I fixed the issue with invalid/incomplete custom colors.
                      • I fixed the error with 面?()[]{}+*
                      • and reloading the webdialog (F5) doesn't break it anymore.
                      • L
                        lionk
                        punctuation is OK but some Chinese characters still arise same error.
                        for example 面 领 到 认 封...not all the Chinese characters,just a few.i have no idea what caused this...encoding? ❓
                          Aerilius
                          Version 1.0.9 contains a quick fix, please update.
                            Aerilius
                            Please update LaunchUp as soon as possible!
                            It contains fixes for menu gray-out avoidance.
                            Thank you.
                              Added update to store
                              • F
                                function
                                oh man i was wondering why that was happening! Thanks for the update
                                • G
                                  glro
                                  Thank you.
                                  version 10 only show native sketchup plugins on my computer; components (with CLibraries_Loader.rb) or added plugins are not proposed anymore in the launchup window
                                  maybe i missed sometinhing...
                                  • P
                                    Pete
                                    Me too. I will revert to the old version until CLibraries_Loader.rb is supported again.
                                      Aerilius
                                      I found it and fixed it in 1.0.11.
                                      • G
                                        glro
                                        yes; it shows components now
                                        Some plugins still don't appear in the list, though
                                        It seems that the plugin name is not taken into account in the search; does the plugin need something special to be recognized?
                                        • EscapeArtistE
                                          EscapeArtist
                                          ^^^ Yep. Is this an issue with the plugin or is the list of downloadable plugins incomplete and being updated? I was looking for "repair broken lines" and noticed it wasn't listed. If incomplete or missing, would you like any missing files listed here?
                                            Aerilius
                                            "Plugins" don't exist as an entity, they are just text files and Ruby evaluates all as if it was one long seamless script.
                                            LaunchUp should recognize menu items and commands (like toolbar items) that are created after the file %(#000000)[!LaunchUp.rb] has been loaded (it is important that it is one of the first scripts that is loaded).
                                            So it searches menu text (+menu path), tooltip, toolbar name, and the file name of the ruby script in which the command was created. It would be easy to return all matching results, but there would be many. The challenge is to sort the results by relevance (which match best to the search term) and with error tolerance. It is possible that a result is too low in the ranking and comes up only after typing more characters.
                                            When I search "repair" I get "Repair broken lines". Can you give me the exact search terms that you enter, the commands that are missing and the plugins' names (where I can find and install them)?
                                            • 4 / 6
