    [Plugin] LaunchUp – A Quick Launcher for SketchUp
    108 Posts 33 Posters 103.1k Views 33 Watching
    • H
      hebeijianke
      something wrong in options at "custom color"
      • L
        lionk
        well done!thanks you!
        another bug...
        if I type some Chinese characters like "面"(it means "face"), there will be an error in ruby console and get no search results, then unable to search again.
        ![Error: #<SyntaxError: (eval):1:in initialize': compile error (eval):1: unterminated string meets end of file (eval):1: syntax error, unexpected $end, expecting ']' ["look_up", "é?¢"]#16 ^>](/uploads/imported_attachments/x92F_20130416111835.jpg "Error: #<SyntaxError: (eval):1:in initialize': compile error
        in light of this, i found these punctuations "?()[]{}+*" also make mistakes.
          Aerilius
          Thanks for finding that!
          I also solved the custom color issue and will probably have an update later today.
            Aerilius
            Version 1.0.8 is available:
            • I fixed the issue with invalid/incomplete custom colors.
            • I fixed the error with 面?()[]{}+*
            • and reloading the webdialog (F5) doesn't break it anymore.
            • L
              lionk
              punctuation is OK but some Chinese characters still arise same error.
              for example 面 领 到 认 封...not all the Chinese characters,just a few.i have no idea what caused this...encoding? ❓
                Aerilius
                Version 1.0.9 contains a quick fix, please update.
                  Aerilius
                  Please update LaunchUp as soon as possible!
                  It contains fixes for menu gray-out avoidance.
                  Thank you.
                    Added update to store
                    • F
                      function
                      oh man i was wondering why that was happening! Thanks for the update
                      • G
                        glro
                        Thank you.
                        version 10 only show native sketchup plugins on my computer; components (with CLibraries_Loader.rb) or added plugins are not proposed anymore in the launchup window
                        maybe i missed sometinhing...
                        • P
                          Pete
                          Me too. I will revert to the old version until CLibraries_Loader.rb is supported again.
                            Aerilius
                            I found it and fixed it in 1.0.11.
                            • G
                              glro
                              yes; it shows components now
                              Some plugins still don't appear in the list, though
                              It seems that the plugin name is not taken into account in the search; does the plugin need something special to be recognized?
                              • EscapeArtistE
                                EscapeArtist
                                ^^^ Yep. Is this an issue with the plugin or is the list of downloadable plugins incomplete and being updated? I was looking for "repair broken lines" and noticed it wasn't listed. If incomplete or missing, would you like any missing files listed here?
                                  Aerilius
                                  "Plugins" don't exist as an entity, they are just text files and Ruby evaluates all as if it was one long seamless script.
                                  LaunchUp should recognize menu items and commands (like toolbar items) that are created after the file %(#000000)[!LaunchUp.rb] has been loaded (it is important that it is one of the first scripts that is loaded).
                                  So it searches menu text (+menu path), tooltip, toolbar name, and the file name of the ruby script in which the command was created. It would be easy to return all matching results, but there would be many. The challenge is to sort the results by relevance (which match best to the search term) and with error tolerance. It is possible that a result is too low in the ranking and comes up only after typing more characters.
                                  When I search "repair" I get "Repair broken lines". Can you give me the exact search terms that you enter, the commands that are missing and the plugins' names (where I can find and install them)?
                                  • G
                                    glro
                                    OK
                                    it is just that i had not typed enough letters for the plugin to be able to be recognized by launchup
                                    it seems to be working fine
                                    • EscapeArtistE
                                      EscapeArtist
                                      Fascinating. It works fine now. Please disregard the previous. Restarted SU.
                                        Anton_S
                                        Hey, AE
                                        LaunchUp is truly beneficial to use 👍, but how should I get around the submenu.set_validation_proc(item)? It seems not to work anymore on my pc 😒
                                        I have ae_LaunchUp_1_0_11.rbz
                                        Edit:Installed ae_LaunchUp_1_0_13.rbz, everything seems to work great now. Once again, thank you for the awesome plugin 😍
                                        • L
                                          lionk
                                          thank you! AE!
                                          DBCS bug is fixed now.
                                          • L
                                            lionk
                                            "Search…" is missing when open LaunchUp since ver 1.0.11.
                                            in IE9...
