    [Plugin] LaunchUp – A Quick Launcher for SketchUp
    108 Posts 33 Posters 98.5k Views 33 Watching
      Aerilius
      Thanks for finding that!
      I also solved the custom color issue and will probably have an update later today.
        Aerilius
        Version 1.0.8 is available:
        • I fixed the issue with invalid/incomplete custom colors.
        • I fixed the error with 面?()[]{}+*
        • and reloading the webdialog (F5) doesn't break it anymore.
          lionk
          punctuation is OK but some Chinese characters still arise same error.
          for example 面 领 到 认 封...not all the Chinese characters,just a few.i have no idea what caused this...encoding? ❓
            Aerilius
            Version 1.0.9 contains a quick fix, please update.
              Aerilius
              Please update LaunchUp as soon as possible!
              It contains fixes for menu gray-out avoidance.
              Thank you.
                Added update to store
                • F Offline
                  function
                  oh man i was wondering why that was happening! Thanks for the update
                    glro
                    Thank you.
                    version 10 only show native sketchup plugins on my computer; components (with CLibraries_Loader.rb) or added plugins are not proposed anymore in the launchup window
                    maybe i missed sometinhing...
                      Pete
                      Me too. I will revert to the old version until CLibraries_Loader.rb is supported again.
                        Aerilius
                        I found it and fixed it in 1.0.11.
                          glro
                          yes; it shows components now
                          Some plugins still don't appear in the list, though
                          It seems that the plugin name is not taken into account in the search; does the plugin need something special to be recognized?
                          • EscapeArtistE Offline
                            EscapeArtist
                            ^^^ Yep. Is this an issue with the plugin or is the list of downloadable plugins incomplete and being updated? I was looking for "repair broken lines" and noticed it wasn't listed. If incomplete or missing, would you like any missing files listed here?
                              Aerilius
                              "Plugins" don't exist as an entity, they are just text files and Ruby evaluates all as if it was one long seamless script.
                              LaunchUp should recognize menu items and commands (like toolbar items) that are created after the file %(#000000)[!LaunchUp.rb] has been loaded (it is important that it is one of the first scripts that is loaded).
                              So it searches menu text (+menu path), tooltip, toolbar name, and the file name of the ruby script in which the command was created. It would be easy to return all matching results, but there would be many. The challenge is to sort the results by relevance (which match best to the search term) and with error tolerance. It is possible that a result is too low in the ranking and comes up only after typing more characters.
                              When I search "repair" I get "Repair broken lines". Can you give me the exact search terms that you enter, the commands that are missing and the plugins' names (where I can find and install them)?
                                glro
                                OK
                                it is just that i had not typed enough letters for the plugin to be able to be recognized by launchup
                                it seems to be working fine
                                  EscapeArtist
                                  Fascinating. It works fine now. Please disregard the previous. Restarted SU.
                                    Anton_S
                                    Hey, AE
                                    LaunchUp is truly beneficial to use 👍, but how should I get around the submenu.set_validation_proc(item)? It seems not to work anymore on my pc 😒
                                    I have ae_LaunchUp_1_0_11.rbz
                                    Edit:Installed ae_LaunchUp_1_0_13.rbz, everything seems to work great now. Once again, thank you for the awesome plugin 😍
                                      lionk
                                      thank you! AE!
                                      DBCS bug is fixed now.
                                        lionk
                                        "Search…" is missing when open LaunchUp since ver 1.0.11.
                                        in IE9...
                                          Aerilius
                                          I found why the placeholder text disappeared and added it back. And I updated the webdialog for higher dpi settings.
                                          • E Offline
                                            ephi
                                            cool tool
                                            • 4 / 6
