    Custom templates. Where are they stored? Mac & PC
    17 Posts 6 Posters 7.9k Views 6 Watching
    • T
      tfdesign
      @tig said:
      You can't have a '?' in a file name.
      All Mac computers allow for this. It seems that PC's don't. It's a shame.
        PC disallow /:*?<>| in file/folder names.
        The first three are obvious as they are 'file-separators'.
        The <>| can be used in directing file input/output.
        The *? are used in 'search' pattern matching...
        • T
          tfdesign
          It's a silly old DOS thing?
            I got out my MacBook Pro to have a look. Try this:
            /Users/Username (your name?)/Library/Application Support/Google SketchUp 8/SketchUp/Templates
            That's where mine is, anyway.
            On the PC it is C:\Program Files\Google\Google SketchUp 8\Resources\En-US\Templates
            (just so they are both in the same place. πŸ˜‰
            • T
              tfdesign
              Okay. Thanks TIG and Dave. πŸ˜„
              I installed SketchUp on 10 clones in a school this morning. Then a class of 30 came in, to use the PC's for something else unrelated, and it all went pear-shaped!! πŸ˜† Back in again in an hour.
                How could they screw up your installation?
                good luck.
                • T
                  tfdesign
                  The IT in schools it seems in the UK, relies on external IT professionals who write a standard template that all state-funded schools need to comply with. It's pretty sh*t to say the least. It means you can and can't use commonly used commands- ones we take for granted without lengthy workarounds.
                  But the kids 'screwed up' the installation, because their lesson demands had to be met first. I'd logged on to all these PC's as admin, and they had to log off and on again as pupils. Because I was only half way through installation (ie I hadn't installed the templates yet), it screwed up my installation (technically speaking- "screwed up"! πŸ˜† ) πŸ˜„
                  Actually the actual class went very well, and the kids took to SketchUp like 'ducks to water'. I just need to convince the computer illiterate teachers next! 😲 πŸ˜’ πŸ˜•
                  • GaieusG
                    That's going to be the hardest thing. Definitely harder than teach SU to the kids.
                    πŸ˜„
                    • T
                      tfdesign
                      Ah yes, but we have our ways! We will smash the illiteracy trap together!
                      • Jean LemireJ
                        Jean Lemire
                        Hi folks.
                        On the Mac, with OS X Lion and Mountain Lion, The user library is hidden but can be easily accessed.
                        It is hidden to avoid people from mangling it and rendering applications unusable.
                        However, it is easy to find it.
                        From the Finder, open the Go Menu then press the Alt key. All of a sudden, the Library choice appears in the Go menu as long as you keep the Alt key pressed. Select it and you are all set. Once in the Library folder, search for Applications support --> Google sketchUp 8 --> SketchUp --> Templates.
                        Just ideas.
                        Jean
                        • Rick_7769R
                          Rick_7769
                          On a Mac, they are stored in a normally inaccessible folder. Here is how you find that folder quickly:
                          Step 1: Click File/New (it doesn't matter what template this opens).
                          Step 2: Click File/Save as Template.
                          Step 3: In the dialog box that appears, enter any word you like in the "Name" space. Doesn't matter.
                          Step 4: Now look at the "File Name" space below it. There is a magnifying glass icon to its right. Click on it.
                          Step 5: The folder with all your saved customized templates appears.
                          Step 6: From this folder, you can drag old templates to the trash, add new ones, or do as you please.
                          It's that simple.
