    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • picky1958P Offline
      picky1958
      @dave r said:
      So why don't you remove LIBFREDO6_Dir_37?
      And what happens if you update Windows again?
      Sooooo... Windows updatet itself again... but wonder oh wonder... nothing bad is happened this time. SU works and LibFredo6 as well! No problems so far! β˜€
        rayisaacs
        not very experienced with ruby scripts. but, the ruby scripts update info directed me to this:
        [Plugin Library] LibFredo6 - v4.7a - 28 Nov 12
        how do i i downloaded it? the page says go to "zip archive". where is that?
          Go to the first post on the first page and look for the yellow Download button.
          • KrisidiousK Offline
            Krisidious
            459,966 page views on this thread... that's got to be some kind of record.
            By: Kristoff Rand
              tovasafra
              Can someone please help me out?
              I have installed the libfredo6 according to instructions but i get these two messages on seketchup 8 startup:
              Cannot load plugin LibFredo6 because the script cannot create DEFPARAM_Dir folder in:
              /Library/Application Support/Google SketchUp 8/SketchUp/Plugins
              Please create it manually, respecting the case
              AND THEN
              Error Loading File clf_color_by_slope.rb
              undefined method file_loaded?' for main:ObjectError Loading File LibFredo6.rb undefined method average_load_time' for Traductor::Plugin:Class
              what can i do about this? I am working on a mac with snow leopard.
              Many thanks for your help!
                Make sure you have full read and write permissions established for the Plugins folder specified in the first error message. Then try restarting SketchUp and see what happens.
                The second error message appears to be due to the fact that LibFredo6 can't complete loading so fixing the first should take care or the second. Funny, though. I didn't know that Chris had made a plugin dependent on LibFredo6.
                  Don't think he has - but there's two errors there. When properly formatted:
                  Error Loading File clf_color_by_slope.rb undefined methodfile_loaded?' for main:Object
                  For the first - clf_color_by_slope.rb when it says undefined methodfile_loaded?' for main:Objectit sounds like clf_color_by_slope.rbis the first .rb file to load and it doesn't include require 'sketchup.rb'` at the top.
                  The second one - I don't know... That's a fredo thing. Maybe incorrect installation?
                    It was the line break that screwed me up.
                      Yea - it's an annoying and little helpful error message. ...I might bump this issue...
                        tovasafra
                        Thank you all for your suggestions- I realized the the color by slope plugin (separate from libfredo) that I had tried to install the day before, was also not loading and therefore also part of the error message.
                        The other plugins in my plugins folder all work, except for color by slope, and now the libfredo. The plugins folder seems kind of cluttered now. Is that ok?
                        As regards to permission, when I tried to install the libfredo, I did get the popup window asking for password in order to make changes to the plugins folder, and I gave it (since it is my own computer). I wasn't asked to give that access password in order to create any other folders or give access at any other point in the installation - and I do not know how to create the DEFPARAM_Dir folder that it asks me to create manually. (or rather, I don't trust myself to do it correctly and have things work)
                        Should I just try to do it manually? Will that work, do you think?
                        Thanks for helping a total novice!
                          You should change the permissions for the Plugins folder to Read and Write so that you don't run into these sorts of problems again when you install other plugins.
                            @tovasfra
                            You need to adjust the access-rights to your MAC's plugins folder [HD main one not the 'user' one...]
                            They need to be FULL read/write.
                            Some tools like Fredo's Lib need to write files to the plugins folder and if you have had to jump through hops to manually add a file there is no way the script is going to manage to do it !
                            I think Dave_R wrote something about setting MAC folder permissions...
                            Perhaps he can point you at it ?
                              I did. I'll have to find it. Or maybe remake it.
                                Here we go.
                                Navigate to the Plugins folder, right click on it and choose Get Info. At the bottom of the window click on the Lock icon to allow changes. Enter your password as required. Then change all of the permissions to Read & Write. Close the Info box. Make sure you have already quit SketchUp and open it. LibFredo6 should now be able to create the file it needs to make.
                                FWIW, I have added the Plugins folder to the Favorites column so I can easily drag plugins from the Downloads folder to Plugins without any real navigation. The Sketchucation Store plugin makes it much simpler to find and install plugins, though.
                                  tovasafra
                                  THANKS! works great now.
                                  • danchoD Offline
                                    dancho
                                    yesterday i was updated my plugin LibFredo6 to version v.4.7c
                                    After restarting SU there was message "Sketchup App has stopped working"
                                    When I change back a version 4.7a everything is ok.
                                    I was try with empy PLUGIN folder and put inside only LibFredo6 v.4.7c,
                                    and SU stop imediately.
                                    System: WIN 7 64bit, latest SU PRO.
                                    Any suggestion?
                                    Regards,
                                    Daniel
                                    • fredo6F Offline
                                      @dancho said:
                                      Is this something you can reproduce systematically?
                                      • rwarchpcR Offline
                                        rwarchpc
                                        Hello Fredo,
                                        I am trying to install LibFredo6 per your instructions and keep getting an error message, as shown in the attached screen shot. Any idea what I'm doing wrong? I am running SU pro 8 on a mac.
                                          @Robert
                                          You do not have sufficient security-permissions to the Plugins folder - its path is given in the error-message.
                                          Some tools need to write logs and other temporary files into the folder or a subfolder, if you have limited rights they can't and therefore fail.
                                          This has been discussed oin several posts - including in this very thread.
                                          So you need to set your security-permissions to FULL Read/Write...
                                          To avoid repeating ourselves for the umpteenth time here's how...
                                          http://sketchucation.com/forums/viewtopic.php?p=468689#p468689
                                          • rwarchpcR Offline
                                            rwarchpc
                                            Many thanks.
                                            RW
                                            • 108
                                            • 109
                                            • 2 / 109
