    Are 'cutting components' broken in the first Trimble build?
    13 Posts 7 Posters 1.0k Views 7 Watching
    • mitcorbM Offline
      mitcorb
      I know this is an elementary comment, but, what ThomThom said immediately gave me a mental picture of when you draw something on a plane and pushpull it up in a volume the pulled face rises away from the original plane and if you make it a group or component it will leave a hole in the plane after you move the group.
      This may not be what he means, but it is the image I get.
      You can right click on the group to Unglue it and move it off the plane. You of course can edit either the plane or the group to close the missing face by tracing along an edge.
        @sdmitch said:
        The "Cut Opening" has rarely if ever worked for me. It obviously works for some but what the secret is is a mystery to me.
        It's all about having a closed loop of edges on the red & green axes of the component. The blue axis must be pointing upwards.
          If you are making a cutting component that stands alone draw it flat on the ground - loops on the ground plane will cut the hole[s], the blue/z axis is the face normal.
          Obviously you have to give the cutting-component gluing and cutting behaviors.
          A simpler way to do it - e.g. for a window - is to model it 'in place' on a 'wall' face and when you elect to make it into a component Sketchup assumes that it's going to glue/cut etc in the initial creation dialog - you can also adjust it's insertion point as desired - provided it's still on the wall's face-plane...
          • sdmitchS Offline
            sdmitch
            So it will only cut through the face that it is "glued" to. If you place it in a wall with thickness, only the outer wall will be cut?
            http://sdmitch.blogspot.com/
              Correct. SketchUp is a surface modeller - it will only cut through one face.
              • sdmitchS Offline
                sdmitch
                Thanks ThomThom. That explains why I thought that all my attempts seemed to fail.
                  Correct - a glued/cutting component only makes a 'hole' in the face it's on... however, my "Hole Punching Tool" script [amongst a few others - see the Plugins Index - http://forums.sketchucation.com/viewtopic.php?p=271170#p271170 ] is a context-specific toolset that will let you select a glued/cutting component-instance [or several at once] and have it punch through a 3d wall making reveals etc to match the 'inner-face', the difference with my tool compared to some others is that the cutting component and its associated reveal geometry select as one bound set [like the edges that form a 'curve' can't be selected individually], so if you move say a window it moves the geometry making up the 'hole' that it also punches through the wall with it. The toolset allows you to move/copy/swap/etc already punched instances, you can also un-punch/re-punch/re-glue etc...
                  So if you must have cutting components punching through wall thickness there are tools available...
                    Another thing to note when making cut hole componentes - create them so no edges of the component you want to cut out touch the edges of the face it's stuck to. The component will not be created correctly unless you do this.
                    • E Offline
                      errror404
                      @thomthom said:
                      I see no change with glued or cut hole components. Maybe you can share a sample model?
                      In general though, if I know I want to create a cut hole component I draw the profile of the hole on a face and select it with the edges and immediately create a cut hole component out of it before I model any more to it.
                      It could be something on how the geometry is that makes the different options in Make Component not be selected.
                      This is exactly how I do my glue/cut components,
                      I draw a rectangle on a surface, double click the inside of the rectangle(this should select the rectangle and the edges "only"... if you triple click it you went too far 😆 ), then right click it-> "create component" make sure cut opening and replace selection with component are checked, and press okay....
                      After that, I double click the component and erase the rectangle but leave the edges.
                      As long as the edges are in a closed loop and are not inside a group/component they will cut the opening.
                      If it's a door or a component that might be touching the edge of the surface that I'm about to cut, I just move it a couple of inches off the edge before creating the component.
                      It sound more complicated than what it's. With practice, it's just a couple of secs. 😄
                      • kuponoK Offline
                        kupono
                        This gave me fits for a while. I couldn't figure out why I could get some components to glue and cut and not others. It seemed that when component axis was at a face, the cut would work, but when I tried to move the axis to the middle of the component, it wouldn't.
                        Then I read Thom Thom's post:
                        That is it in a nutshell. To get a component to cut through the face it's glued to, there must be a continuous edge around the component at the component's axis, which is where it will glue itself to the face.
                        Thanks TT.
                        Check out the attachment.
                        Component glue cut.skp
