    [Plugin] Canvas v1.1.3
    98 Posts 31 Posters 85.6k Views 31 Watching
    • guanjinG
      guanjin
      I got loaded error message, thank you!
      • renderizaR
        renderiza
        Box::
        I tested the plugin on another computer so I could check if groups worked and they didn't...now I am confused as to why groups work on my computer.
        guanjin::
        For the Plugin to load the "RND_0_Menu.rb" must be placed on the plugins folder as well. If you do have the file already then this is another issue I need to look into.
        [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        • jolranJ
          jolran
          Hi Rafael.
          As for your last suggestion it is really good idea and I am sure if I don't do it someone else might give it a shot. However if the material opacity is 2% for example painting multiple plane objects on top of each other gives a nice effect (The brush hairs is an example).
          I did not think of that! Thats neat use of it.
          I do think YOU should be the one doing the edits, it's your plugin, man πŸ˜„
          I had a quick peek at the code and have a hunch why there seams to be some troubles with detecting groups.
          The way your doing it now is that you accept anything that's not nil, face or edge ?
          Maybe it would be better to trap for groups or components specifically.
          I mean assign the group or component to a variable. If not that variable prompt user.
          Just an idea to solve the problem. Anyway Keep up the good work! It's a nice concept!
          • renderizaR
            renderiza
            Update RND_Canvas v1.0.1 Beta
            Fixed::
            1.0.1 Beta:: 4/5/2013
            * Fixed some spelling mistakes
            * Changed "Sketchup.send_action(21022)" to "Sketchup.send_action('selectSelectionTool:')"
            * Shortened some if statements
            * Now tool should works with both Groups and Components
            Note::
            While reading this post http://sketchucation.com/forums/viewtopic.php?f=323&t=40482 I found a solution for making groups work with the tool.
            TIG mentioned the following...
            You can only use entities.add_instance() of a definition, BUT there's no built in group.definition method πŸ˜’ , BUT all components, groups and images are all just types of instances of a definition.
            To find a group's definition you have to find its entities' parent which is the definition - so
            defn = group.entities.parent
            ComponentDefinition
            just as the much snappier method defn = instance.definition does for a component-instance !
            The second argument of the entities.add_instance(defn, tr) is the transformation used to place/manipulate the new instance...
            So I added this...
            if @@sel.is_a? Sketchup;;Group
             defn = @@sel.entities.parent ### You can find group definition by adding this
             @@ents.add_instance(defn, t)
            If anyone is kind enough to test if the tool works with groups I will be very thankful! πŸ‘
            • BoxB
              Yep, groups works for me as smooth as a baby's bottom.
              • guanjinG
                guanjin
                guanjin::
                Thanks[/quote]
                My plugin folder, thank you!
                • renderizaR
                  renderiza
                  guanjin::
                  Thomthom develped a Debugging utility to check if there's files in the Plugins folder that's ended up in Window's VirtualStore.
                  Please download this here http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                  Make sure you have admin rights to move the files to 'Plugins' folder.
                  Have you tried running Sketchup as an Admin ?
                  Have you double-checked that you/ALL have FULL security permissions to the Plugins folder and all of its contents including subfolders and their contents ?
                  No 'Compatibility Files...' button/links at all ?
                  Again solving this issue might take couple of tries but hopefully with your help we can solve it. Thanks!
                  • srxS
                    srx
                    πŸ‘ Great! It is like instancing brush from rendering application, like Thea. Thanks.
                    www.saurus.rs
                    • C
                      cuttingedge
                      great plugin. Can we control some parameters?, My components gets stacked at each other sometimes
                        3dsmax9
                        in the RND_Canvas v1.0.1 Beta.rar file this file is missing RND_0_Menu.rb so download the RND_0_Menu.rbz guanjin
                        this is very cool but can you make it add a comp or groupe with just one click every time you click one time an component will be added it will be very usful.
                        • KrisidiousK
                          Krisidious
                          what is the difference between this and spray paint can?
                          By: Kristoff Rand
                          • guanjinG
                            guanjin
                            Or can not be loaded, the same problem! 😞 😞
                            • guanjinG
                              guanjin
                              • guanjinG
                                guanjin
                                Issue is resolved, I reinstall sketchup8, and then test the normal use, thank you, it is tough!
                                • renderizaR
                                  renderiza
                                  srx::
                                  Thank you
                                  cuttingedge::
                                  There is no parameter controls at the moment but its on my to do list.
                                  3dsmax9::
                                  Added RND_0_Menu.rb to Rar File...Thank you for pointing it out. πŸ‘
                                  Thanks for your suggestion I will look into it but in the mean time please check 'Repeat Copy' by Chris Fullmer here... http://sketchucation.com/forums/viewtopic.php?t=26117
                                  Krisidious::
                                  What makes Canvas unique is the constant copies you get without having to do multiple clicks.
                                  guanjin::
                                  I am glad you were able to resolve the issue. πŸ‘
                                  • guanjinG
                                    guanjin
                                    guanjin::
                                    I am glad you were able to resolve the issue. πŸ‘[/quote]
                                    Increase the size of the adjustment distance the better, some randomness, overlapping other components, will produce along the Z axis superimposed.
                                    • sicksickisckS
                                      sicksickisck
                                      hah nice tool! and work very fine for me :]
                                      • renderizaR
                                        renderiza
                                        Update RND_Canvas v1.0.2 Beta
                                        New::
                                        1.0.2 Beta:: 4/8/2013
                                        • Add:: Multiple -- Adds Multiple Groups or Components while holding left mouse button
                                        • Add:: Single -- Adds Single Groups or Components while holding left mouse button
                                        • Don't Add:: If pointer on top of face
                                        • Select:: Normal or Random Input Position
                                        http://sketchucation.com/forums/download/file.php?id=104057
                                        "Add:: On Edge" will be available on v1.0.3
                                        Note:
                                        Added new features that some of you were suggesting and if you have any more suggestions let me know.
                                        Now you can choose to add only one group or component per click use "Add:: Single".
                                        Also for people that want to avoid having groups or components overlaps use the "Don't Add:: If pointer on top of face".
                                        ::A tip:: When using "Don't Add:: If pointer on top of face" I suggest having the Group or Component Axis on center
                                        For adding some randomness while adding groups or components click :Select:: Random Input Position"
                                        That is it I hope you like the new features for "Canvas"! πŸ‘
                                        • guanjinG
                                          guanjin
                                          New::
                                          Note:
                                          The so quickly update the functionality I want,Renderiza: Great, you're God.
                                          πŸ‘ 😍
                                          • renderizaR
                                            renderiza
                                            guanjin ::
                                            Thanks for your positive comment!
                                            Here is a Sneak Peak on next Canvas version 1.0.3 Beta!
                                            http://sketchucation.com/forums/download/file.php?id=104104&mode=view/rokbox.jpg
                                            Hope to release it soon and maybe add more features...again thanks!
                                            • 1 / 5
