    How to create a solid from curved surfaces
    21 Posts 7 Posters 12.7k Views 7 Watching
      Mike91
      Thanks but I found a plugin that used the section plan to cut everything above it, I linked all faces but I found the real problem: when I imported not all the meshes where done.
      Is there any plugin that creates the surfaces to fill those voids? They are to many to be done one by one with lines manually.
      • pbacotP Offline
        Mike 91,
        So you want to just cut everything at that horizontal plane? If you select the plane and use context menu, intersect with model, that will cut everything on that plane.
        Not sure what you are doing exactly, but it is not always so easy to make a solid when you are starting with a shape that isn't what you wanted and then cutting it up and hoping to stitch it back together. Could happen.
        The best way to get rid of all those unwanted lines and faces after intersecting is take a side view, left-to-right rectangle select everything above the plane, group, and delete.
          Why not post your original file? (save as V6 for a more large audience)
            πŸ‘
            ONE member larger, Pilou? πŸ˜†
            Anyway, what would you do with "solids" in V6? πŸ˜’
              You can reload it in V8 for some boolean festivities ! πŸ˜„
                Mike91
                Thank you all for helping. I solved a few issues, i now have what appers to be a solid, still I find a few mistakes, tried to use a few plugins to make it solid but with no success...A plugin told me it can-t become solid.
                Isn-t there a plugin or a way to simplify those surfaces impossible to close, in order to make it solid?
                PS I forgot to mention that there are 2 walls on the file because the more complete one is how I need it to be.
                CurvedWallMaison.skp
                  You are making is way too small - the walls are only a few cm apart !
                  Sketchup can't cope with tiny geometry.
                  It should be ~20x bigger, at least...
                  If you run thomthom's SolidInspector of it there are many errors.
                  Tiny holes, small gaps, loose-flaps, internal-partition-faces, double-faces etc...
                  A 'solid' can only contain faces and edges.
                  Every edge must have two faces, no fewer and no more.
                  Automatic solid-fixing tools must be given a chance - a myriad of issues lead down so many different possible paths that finding a good outcome is unlikely...
                    Mike91
                    Ok so, what do you suggest?
                    Should I recreate the curved surfaces making them 50x bigger, than import on sketchup, run an automatic solid-fixing plugin and scale down?
                    I did those surfaces on bonzai3d and than imported on sketchup because I wasn't able to create the surface from the edges on sketchup. On bonzai3d I simply selected the edges of the area and the surface was created, even if there where curves as edges, is there a plugin that does that directly on sketchup? SO I don't have to import and the mesh won't have errors.
                      Mike91
                      I re-did the whole wall from the start, this time I used the extrudetool plugin instead of bonzai so I didn't need to import/export. Also I scaled the curves 50x up before doing the surfaces.
                      If I use a section and use add section-cutface 2 parts of wall are solid while the first one is not, I tried a solid solver plugin but didn't work, do you have any suggestion?
                      Wall.skp
                      • cottyC Offline
                        cotty
                        Thomthoms Solid Inspector show the problems:
                        • Inner face
                        • Groups inside the group
                        • Volume not closed at bottom
                          (- different face orientations)
                        I've attached a solid version...
                        Wall-2_cotty.skp
                        my SketchUp gallery
                          Mike91
                          Thank you very much! May I ask how you made it solid? With a plugin?
                            Because the main Wall-group contained several nested groups they all needed exploding so it has a chance of becoming a solid group - remember "faces and edges" only and every edge needs exactly two faces!
                            Then using thomthom's Solid Inspector tool it will show the problems - mainly red for holes/flaps around the base level, few orange highlights, but these evaporate when the flaps/holes are resolved.
                            Erasing most of those flap edges manually, or Moving vertices to heal holes... and then using some erase-faceless-edge tools and so on... will quickly reduce the issues until it reports as a 'solid' in Entity Info...
                            Finally Orient the faces so the blue-gray backs are all inside...
                            • cottyC Offline
                              cotty
                              I would not even be able to write it better 😎
                              my SketchUp gallery
                                Mike91
                                Thank you all, I followed the instructions and was able to make it solid!
                                Sorry for all these stupid questions but I started using sketchup last week.
                                I've the last question, how can I hide all the geometry lines on the surfaces of these solid?
                                • gillesG Offline
                                  gilles
                                  Select all geometries, right click, soften/smooth edges.
                                    Mike91
                                    thank you!
