    [Plugin Library] LibFredo6 - v15.8e - 15 Feb 26
    2.2k Posts 573 Posters 4.2m Views 575 Watching
    • N Offline
      nursill
      i have this crashing problem too( today
        sket
        Same here. I reinstalled Sketchup, and then started adding plugins one by one. I've even downloaded the latest versions of some plugins that i didn't update before thinking it may solve the problem.
        It is definitely a problem with Fredo6 plugins 😞
          If it was a problem with Fredo6 plugins as you assert, everyone who uses them would be having the same problems. I use them on several machines, both PC and Mac and don't have issues with crashes.
          Do you get the crashing with only Fredo6 plugins installed?
          What operating system? Do you get a Bug Splat? What exactly are you trying to do when the "crash" occurs? What is the geometry you're trying to use the tool on? How big? Post an example SKP file that crashes when you run the tool.
          Just saying it crashes without supplying useful information is a worthless report.
            sket
            I appologize Dave R, you are right...
            I'm using Win7 and SUPro8, and i think more people will be experiencing this problem, because untill today i had no problems with any Fredo6 plugins at all. But today when i wanted to open the file i was working on yesterday, it crashed. I tried again and again with same results. Bug Splat pop-up everytime.
            I tried to copy the file to a different location - it crashed. Renameing it - it crashed. Then i even tried to open the .skb file but got the same result. I then tied a new, blank file but it too crashed on startup.
            Next step was to reinstall Sketchup. It didn't help. So finally i removed SU and all plugins. Reinstalled SU again and started installing plugins. After each plugin was installed i started Sketchup just to test it. Vray and Artisan worked fine.
            Then i installed RoundCorner 2.3a. Started SU, saw the RoundCorner toolbar but got a notification about the library missing. Installing LibFredo6 4.7a was the next step. I didn't start SU immmediately, but installed the BezierSpline 1.4f. Ran Sketchup and it crashed.
            I removed and installed Fredo6's plugins back and forth trying to figure out which was the one actually causing the problem. In the end it was this one.
            I don't know why it started causing problems today, but i sure hope a fix is found soon.
            p.s. If it's of any help, i just remembered that the check-for-update pop-up for Fredo6 plugins was giving me errors since a while back. It couldn't connect to the database or something. I didn't pay much attention since i checked for new versions on the forum from time to time and the the older versions of some plugins (i updated today) worked fine so i wasn't in a rush to update.
              Why don't you add your operating system and SU version to your profile?
              So from your statement, you think more people will be having this problem since you are?
              I gather that you haven't done as I asked before and tried with only Fredo6 plugins installed. I suspect it isn't Fredo6 but rather the Vray plugin that is causing the problem you have. At least humor me and try it without Vray installed
                VfSU is known to be potentially unstable.
                  sket
                  emage wrote before me:
                  "today my windows updated itself, and now sketchup crashes on startup.
                  removing plugins one by one showed that only removing LibFredo will enable sketchup to run"
                  nursill reported the same issue, and i have found the same to be true. I only said that i expect that this will hapen to more users as the Windows update, the one that seams is in conflict with Freed6 plugin, gets to more people. I personally didn't see any update (it may have updated before shutting down, like usual), but something had to change from last night to this morning.
                  And yes, i did install only LibFredo6 and no other plugins while waiting for someone to reply, and Sketchup crashed immediately.
                  p.s. I've been a member of this forum for more than 2 years and haven't posted anything 'till today. If i didn't think that was the best place to get the solution for my problem, i would have been a 'silent' member still. That is why my profile is empty.
                    sket
                    I figured some Windows related update may have hapened last night and i'd try to reinstall the plugins today. The problem was resolved out-of-the-blue just like it apeared.
                    Just thought you guys should know... πŸ˜‰
                    • picky1958P Offline
                      picky1958
                      Help! Just installed LibFredo6 4.7 and now SU crashes! I overvrote the old version 3.7 and lost the old file! How can I bring it back to work??? I know, I should have saved the old LibFredo6.rb file... but I didn't. Can anyone help me? Where can I get the older rb file?
                        There should be no issues between old/new versions.
                        What do you mean by 'crash' ?
                        I suspect something else is causing the issue.
                        Can you post a screen shot of your Plugins folder...
                        Are you 100% sure that you have installed everything exactly as required??
                          picky1958
                          This is really strange... I just set the computer back to before the last Windows update and now it works without any problem. Hmmmm... could it be an Update problem?
                            picky1958
                            By "crash" i ment SU starts, then some icons appear an suddenly SU shuts down again. If I restart, the same thing happens again.
                              As TIG already requested once, post a screen shot of the Plugins folder. Also post one of the LibFredo6 folder.
                              It sounds like either an installation problem or a clash with some other plugin.
                                picky1958
                                Well, now it works! I set the computer back to before the last update und... no problem anymore!
                                Strange, ha?
                                  So why don't you remove LIBFREDO6_Dir_37?
                                  And what happens if you update Windows again?
                                    picky1958
                                    Oh, yeah, I forgot about removing that one now. I did that before... but it still was not working. I took all files an folders away and then I put them back one by one, testing each time. Everything went well until I copied the new LibFredo6.rb in the folder. Like I said... now it's working well. And... I have no clue what is going to happen after a new update. Probably I will be here, screaming for help again! πŸ˜‰
                                      picky1958
                                      Sooooo... Windows updatet itself again... but wonder oh wonder... nothing bad is happened this time. SU works and LibFredo6 as well! No problems so far! β˜€
                                        rayisaacs
                                        not very experienced with ruby scripts. but, the ruby scripts update info directed me to this:
                                        [Plugin Library] LibFredo6 - v4.7a - 28 Nov 12
                                        how do i i downloaded it? the page says go to "zip archive". where is that?
                                          Go to the first post on the first page and look for the yellow Download button.
                                          • KrisidiousK Offline
                                            Krisidious
                                            459,966 page views on this thread... that's got to be some kind of record.
                                            By: Kristoff Rand
                                            • 101
                                            • 102
                                            • 103
                                            • 104
                                            • 105
                                            • 109
                                            • 110
                                            • 103 / 110
