    Lamp is not shining...
    renderpluginsextensions
    11 Posts 4 Posters 1.2k Views 4 Watching
    • tibetT Offline
      tibet
      hi,
      i wish to follow the tutorial , to create a beautiful square lamp,
      http://renderingtutorials.blogspot.cz/2011/08/sketchup-vray-resources.html
      but the final result isn´t good enough to produce a bright shining light 😞
      i´d be grateful for any tips to fix it. ( v-ray 1.49.00 )
      (the model is attached below)
      thanks!
      http://img.sceper.eu/images/KzDf.jpg
      lamp.skp
      SU 2015 Pro on Win10 x64
      • V Offline
        valerostudio
        1.49.01 is the most current version. I didn't download the model, but what are you using for a light source in the lamp. Seems to me that you need a planar light, set to visible and set to a yellowish color to achieve that effect.
        • tibetT Offline
          tibet
          hi, thanks for a tip, but i think, there´s something missing in my twosided material:-(
          http://img.sceper.eu/images/C3RTt.jpg
          • andybotA Offline
            andybot
            your material is working OK. I would suggest putting an omni light in your scene. (instead of relying on the emmissive material.)
            • V Offline
              valerostudio
              Do not use emissive materials for lighting. V-Ray does not use emissive materials like other engines. The emitter material is only an effect to give a material the look of being lit, like a TV screen. You should stick to omni or planar lights for this lamp effect.
              • tibetT Offline
                tibet
                thanks for your valuable tips, but i´d like to stich up to the nice tutorial.
                • soloS Offline
                  First issue is the scale, the whole room is around 1.5ft high and wide.
                  Secondly use an Omni.
                  • V Offline
                    valerostudio
                    And as for the diffused glow - that's Photoshop. It currently cannot be done in VRay 1.49.01
                    • tibetT Offline
                      tibet
                      hi solo,
                      a pretty nice work, congratulations! 😍
                      would you mind to upload it please, just for a pleasure.
                      thanks!
                      • soloS Offline
                        Oh crap, I never saved it, I can recreate it tomorrow if you want (busy rendering at moment)
                        Or you could just upsize scene x10, remove the light emissive material and replace with an Omni, set to watts and up the power as needed.
                        • tibetT Offline
                          tibet
                          hi solo,
                          thanks for your answer and kind offer to upload a model of the lamp.
                          that´d be very kind of you!
