    Jean Prouvé - S.A.M. Tropique table - 1950
    36 Posts 10 Posters 5.0k Views 10 Watching
    • massimoM
      massimo Moderator
      Where I got lost here was in the fresnel. I couldn't grasp why you would use a fresnel on metal.
      The result is perfect but my understanding of fresnel was for fabrics. This is where my confusion begins.
      A typical illustration of the fresnel effect (you can use this example for the fresnel reflection too) is when you look at a pool: if you look straight down from above at a pool of water, you will not see very much reflected light on the surface of the pool, and can see down through the surface to the bottom of the pool. At a glancing angle (looking with your eye level with the water, from the edge of the water surface), you will see much more specularity and reflections on the water surface, and might not be able to see what's under the water.
      Maybe just very reflective metals don't show this in reflection. Anyway I don't know how much that effect added to the mat. I'll try to delete it and see the result.
      Obviously it worked but when using the material ball to test materials it doesn't suit this trial and error approach, does it?
      A material is not good in itself. It depends a lot on lighting, models, environment etc of the scene. Of course a material can have a good "structure". Lets say that Thea's ball is a good "average" tool. I make the mats on Thea's ball (or another simulation scene) and then adjust them once applied in the "real" scene.
      The layer stack system I grasp but is was always going 50/50 when the textures occupied the same layer.
      You don't have to worry about multiple texture on the same layer. That is automatically managed by Thea accordingly to the energy conservation law. In Kerkythea, for example, you have to assign different layers even for a simple specular map. That's a bit harder.
      I don't mean to say Thea is hard to use but its depth of options make advanced materials a science.
      Well the possibilities are almost infinite. So if you think is hard having infinite possibilities then...yes, is hard. 😄 If you have clear from the beginning what you want to achieve then you'll learn by trying and especially by looking at how good mats are made.
        Thea allows that you can give this material to Rich or he must rebuild it? (Copyright licence ? )
        • massimoM
          massimo Moderator
          Pilou, I have no problem at all in sharing materials. I've done that many times. However I think it's more fun trying to rebuild it. 😉
          • massimoM
            massimo Moderator
            I'd like this model in my library 😉
            Ok, you can find it here
            • N
              notareal
              Custom fresnel has other uses too, for example it can be used to create a car-paint that changes the color based on viewing angle... it's not only the reflectance color tham can be changed, but curve itself can be modified (there some preset when you right click on custom curve area, when it's enabled)
              I think massimo got a novel idea to use it with these finger prints. 👍
              • daleD
                dale
                So much to learn.... so little time 😲
                • massimoM
                  massimo Moderator
                  Rich here you have some experiments to play with on a bit unorthodox use of the fresnel effect.
                  Just a fingerprints map in the fresnel reflectance slot with a custom curve...
                  ...the same material with a roughness map added in order to enhance a bit the effect.
                  Of course you can do almost the same using the map in the reflectance slot, but here the effect is more subtle and slightly changes in relation to the angle of view.
                  • massimoM
                    massimo Moderator
                    And here you can see the fresnel effect in reflections on some aged plastic.
                      You can definitely see the impact the roughness map has on the fingerprints. If find just the fresnel looks the best.
                      Is the tweaking of the custom curve just a hit and miss affair? I can see the presets but is there info somewhere on this?
                      • massimoM
                        massimo Moderator
                        As far as I know for Thea you have just this at the moment. But of course you can find something searching on the net.
                          Thanks for that.
                          @everyone...
                          sorry for spoiling this thread with meaningless banter that should occur over on the Thea forums
                          • massimoM
                            massimo Moderator
                            Anyway the concept is basically that at a 0° deg angle you can see reflections coming from what you have in the reflectance slot, and at 90° deg angle you'll see reflections coming from what you have in the fresnel slot. Adjusting the curve you can change this transition/balance relating to the viewing angle (in the x axes you have the degrees). Here you have the same plastic with a different curve. As you can see the transition in reflections is more abrupt from 0° to 90° deg because the curve goes from 0° to 90° deg more drastically.
                              How have you the Structure box in the same area as the Scatter box?
                              Another off topic query.... 😒
                              That explanation makes perfect sense.
                              • massimoM
                                massimo Moderator
                                Well I think that many rendering app (for example Vray & Maxwell) support something like that. So maybe interesting also for non-Thea users. 😄
                                • massimoM
                                  massimo Moderator
                                  Control + Left Click (on Layer/Scatter/Struct buttons). Merge layer/scattering/structure properties listed in a single panel.
                                    Thanks Massimo.... 👍
                                    • B
                                      bytor
                                      I don't have any of these renderer's and I found this post most rewarding. Massimo - thanks so much for taking the time here to explain the detail in the material, and thanks for the model as well!
                                      Find the Cost of Freedom.....
                                        Added to Gallery
                                        404 Not Found
                                        (sketchucation.com)
                                        • 2 / 2
