    [Plugin] Zorro2 (beta)
    314 Posts 154 Posters 446.9k Views 154 Watching
    • DesertRavenD
      DesertRaven
      @gaieus said:
      No, Zorro2 will use the section plane as a cutting plane and that is always flat by nature. I cannot think of another plugin that would perform such a cutting operation now (this does not mean it does not exist) and of course, a manual intersection may be extremely tedious with complex geometry and/or lots of nested elements in groups/components.
      Some boolean tools may make it easier but still, nested things can be an obstacle.
      Maybe it is a good idea to create SU models with cleaned up geometry in general as a code of good conduct. That way you can, via boolean subtract, make any section of any shape you wish.
      Also I don't understand why in SU version 8 they have not gotten it together to fix the section tool so that it makes filled up solid section or sections with a hatch pattern??
      Why we need another plug in for this basic function, which already exists, is beyond me!
      simplicity is the ultimate sophistication
        Skwatz
        the reason why sketchup doesn't fil in the solids is because is doesn't is is a solid!
        not even when you work with the boolean substract.
        you draw lines and sketchup conect them with planes.
        i can't be solved to my opinion, otherwise you need to change the fundaments of sketchup.
        if you want a progame that works with volumetric and 'real ' boolean use 3ds max or autocad.
        keeping your model clean is true but not easy at al, and when you use groups (like me) slicesing them is a hell of a job.
        so...
        Thx for this great plugin πŸ˜„!!
        • cottyC
          cotty
          There are solid tools, so there have to be solids too πŸ˜‰
          my SketchUp gallery
          • DesertRavenD
            DesertRaven
            so...
            Dude, you are completely wrong or you are just not doing it right, the last time I did a section with boolean subtract, there were faces in the section! πŸ˜†
            Also it is very easy to keep your geometry clean by just paying attention to what you are doing and not being sloppy and lazy. (I constantly get models from other companies especially architects, that are just F>U>B>A>R> because they don't even care to learn their S*@t.
            And No sir I'm not going to buy 3D MAX or any other tool just because sketchup is a "half assed" software that just needs some fixing.
            Sketchup has all it needs to be an outstanding tool, there are just some things that never got fixed and I'm not talking about adding more commands and buttons, just fixing what there is already would be a leap into the right direction.
              svadilfari
              Hey guys,
              I am trying to cut my model, everytime there is a bug and SU crashes down?
              Any solutions, advices?
              It is quite complicated model with a lot of components and materials, could it be that?
                Without post your model (save as V6) it's impossible to say something πŸ˜„
                  You answer is in your question.
                  Zorro isn't magic.
                  If there are zillions of 'containers' contents to cut it only needs to trip up once for a splat!
                  Because the process is destructive you are presumably working on a copy of the original SKP and you probably have little use for its 'structure' of groups/instances...
                  So, in that copy, why not explode all containers in the active model [iterating until there are none in the Outliner - that's an easy way to select them...]
                  Also erase all hidden layers and their contents etc... and all hidden objects too [if any]/
                  Also purge the model of unused things... this will speed up what it has to look through when 'cutting'...
                  Now retry on the slimline group-free version of the SKP.
                  It should be much quicker and less prone to failure...
                  • Q
                    qianyi
                    my schoolmate recommend me this plugin,seems useful ,looking forward! 😍
                      Ronnie
                      Would be pretty cool if you could also split at section plane, but without deleting anything, like inserting a 10mm gab or whatever at the intersection of the section plane.
                      Very useful for cutting a model up for 3d printing.
                      • jolranJ
                        jolran
                        You can by right clicking section plane, create groups from slice. But it doesent destroy original group.
                        • BoxB
                          Or use tigs slicer.
                            Ronnie
                            Thanks.
                              Da Man
                              I'm new to this. where does this plugin? my sketchup 8 only has .rbz plugins
                              • olisheaO
                                olishea
                                C:\Program Files\Google\Google SketchUp8\Plugins
                                oli
                                • E
                                  eroc121
                                  Exactly what I needed! This tool was a life saver for creating quick perspective sections to be rendered into 3dsMax. I was amazed by how quickly it cut through a complex model, too. Thank you, Whaat!
                                  • O
                                    onri999
                                    Hey guys, new to sketchucation. My friend recommended I get Zorro as I have started using 3d rendering software and want to take sections and render them. However, I have been reading through this thread and many others like it because sketchup keeps crashing every time I try to "slice model at section" it says "cuttinggroup#2" at the bottom left hand corner of the window.
                                    I have tried pretty much everything, disabling other plugins, purging unused, exploding all groups and components (outliner is showing just one entry) I have tried opening in su7 and 8 both pro.
                                    I really can't understand why it isn't working, I have seen much more complicated models cut by Zorro2.
                                    I am using a Mac but I don't think that should make a difference.
                                    Please, any help would be much appreciated.
                                    Thank you for taking the time to read this.
                                      Keep what is 'cut' as simple as you can.
                                      You can imaging that the process of cutting geometry and discarding some etc is very complex and prone to fail at every step.
                                      SketchUp can't cope with very tiny geometry.
                                      For example, its in-built accuracy could consider two points that are very very slightly different, as being coincident... and therefore it might not draw a line between them, although in reality a tiny line would be needed to complete an intersected 'cut' - thus it fails.
                                      You can see this issue with the native intersect tool not making a perfect intersected outline it it's through a mesh that has tiny facets so parts of the intersected outline would be very small, and they don't get made. FollowMe will also fail to complete everything, say a very faceted pipe on a very tight radius bend, where some facets would be tiny and get omitted.
                                      You will get tiny geometry from very faceted/triangulated surfaces, leaves, etc; so
                                      If you are cutting very small geometry consider Scaling the whole model up by x100, cutting and then scaling down again. Very tiny geometry can exist but creating it can prove difficult.
                                      • O
                                        onri999
                                        Thank you so much for the very quick reply, I have used the follow me extrude tool for hand railings so i will try either getting rid of them or placing the section plane away from them. Also I thought scaling the project down might have helped so I shall scale back up.
                                        I will let you know how it goes.
                                        Thanks again.
                                          mallikab
                                          I was having bug splat issues with SU Pro 8 as well. My model had quite a few groups and components but wasn't that large. After trying some of the suggestions here, putting the model into SU 7 (just the free version) to use Zorro worked. Then put it back in 8 to use SectionCutFace and V-ray render. Great plug-in (once it worked), thanks!
                                            33Angelo33
                                            @Whaat: Hi there when try to cut using the section plane sketch up just crashes on me so i have no luck using this plugin.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
