    Tiles in Kerkythea and Sketchup
    13 Posts 5 Posters 982 Views 5 Watching
    • massimoM Offline
      massimo Moderator
      Hi, do you have any back (blue) face in your model by chance? Check it by pressing the monochrome button in SU.
        auchifai
        oh i checked and i think my sketchup model is right. Seems that i still cannot make it as the orientation is still a mess.... 😞
          Show us an image from SketchUp using the Monochrome face style.
            auchifai
            here is the monochrome view of the sketchup model.
            • massimoM Offline
              massimo Moderator
              Well you have some back faces in the model but it seems not on the floor. Could you share just the model of the floor (with textures) so we can have a look?
              • tridemT Offline
                tridem
                it seems rather a UV issue, try applying cubic mapping in kerkythea
                  auchifai
                  Hi, thank you for suggesting me solutions πŸ˜„ I have attached my sketchup file with this message. Thank you very much for your effort.
                  Besides, i have changed my tile material to cubic in kerkythea, however, the result is the same. see the image i attached.
                  sketchup file
                  • soloS Offline
                    You have applied the material to the group and not the face, explode and regroup, it will work.
                    • tridemT Offline
                      tridem
                      I'm not able to reproduce the issue, this is a quick test I made and it seems ok
                      but as Solo said you've applied the material on the group (that usually is not a problem) and also on the backface of the tiles, try to clean the scene
                      • massimoM Offline
                        massimo Moderator
                        Hi auchifai, some suggestion:
                        -always purge the models in SU;
                        -never apply materials directly on groups/components: open them and then apply the material on single faces;
                        -never have back faces pointing outward;
                        -don't put materials on back faces;
                        -what's the point in having the floor subdivided if you apply uniformly on the whole floor a tileable texture like that? I would go with slight different orientation of the texture for each tile or with a good texture map of tiles applied on the whole floor not subdivided (KT doesn't render lines);
                        -it seems that you have set "clay render", "photomatched" etc. on "yes" in the SU2KT exporter. I would let the settings that come with the installation.
                        Hope this helps a bit. πŸ˜„
                        P.S. Anyway as already said by others the model looks fine once exported in KT.
                          auchifai
                          Hi everyone, I can make it now... Thank you for all your advice. I think my problem is that i should not export the CLAY from sketchup to kerkythea, and i have adjust the sketchup model that now no back faces were shown....
                          Thank you very much! Now i can go on designing my new home. πŸ˜„
                          • massimoM Offline
                            massimo Moderator
                            πŸ‘
