    Making Grass on a Contoured Plane using Displacement?
    renderpluginsextensions
    23 Posts 7 Posters 6.7k Views 7 Watching
    • V Offline
      valerostudio
      Here is my second pass at it. 45 min render time on this one.
      • fuzzionF Offline
        fuzzion
        From my years of experience , if your surface is not
        1. A golf course
        2. A straight large plane with little bits of curve
        Then
        Go for make fur plugin. Its works well with short and small corners, giving it that realistic look
        Below are some attachments.
        This took 2 mins to render. Not sure why you took 45mins
        Without VRay
        Afer Vray and plugin --->
        Vray with Fur plugin
        "Only the dead have seen the end of war" - Plato
        • V Offline
          valerostudio
          Fur is great, but I have issues trying to fur an entire front lawn.
          • fuzzionF Offline
            fuzzion
            True. The trick is to only place grass from where you intend to render, Hence in this photo there is no grass/fur plugin used(Behind the house) since that plane is hidden. ➑
            • V Offline
              valerostudio
              What we really need is VRay Fur inside of SketchUp!
              • andybotA Offline
                andybot
                [attachment=0:2fvsrfcp]<!-- ia0 -->Futzer2.jpg<!-- ia0 -->[/attachment:2fvsrfcp]
                unfortunately, the scale is way off there. That's much coarser than real grass. To get it fine enough, you would run out of memory pretty quick.
                • V Offline
                  valerostudio
                  I have to agree with Andy on this one. The only way to really render grass is proxies or something like VRayFur. Watch this and dream of having these abilities one day in SU!
                  • fuzzionF Offline
                    fuzzion
                    @andybot said:
                    [attachment=1:18jit4q3]<!-- ia1 -->Futzer2.jpg<!-- ia1 -->[/attachment:18jit4q3]
                    Its called cow grass πŸ˜’
                    [attachment=0:18jit4q3]<!-- ia0 -->Rumput 1.jpg<!-- ia0 -->[/attachment:18jit4q3]
                    • andybotA Offline
                      andybot
                      if you like that sort of thing...
                      • fuzzionF Offline
                        fuzzion
                        The cows liked it πŸ˜„
                        • 2 / 2
