    Making Grass on a Contoured Plane using Displacement?
    renderpluginsextensions
    23 Posts 7 Posters 6.3k Views 7 Watching
    • V Offline
      valerostudio
      My diffuse is just a grass texture map from the web, not noise. It's the displacement map that's using noise and makes the grass spikey. White as color A and black as color B and the size is set to .005. That's all I did. My displacement settings are 8.0 on the amount and 256 subdivs and 1.0 on edge length. Turn off Use Globals so this doesn't get overridden. Your light cache will take a while to calc, so turn that down to like 200 sudivs to do your test renders.
      Make sure your faces are forward facing and the grass object is its own group outside of any other groups. In other words, not nested into a site group or something like that.
      For a nice grass texture, just look on CG Textures for one. Best site for textures in my opinion. http://www.cgtextures.com/
      Now give it a try my student, and post your render! When the class likes what they see, share your vismat for all to enjoy!
      • V Offline
        valerostudio
        Here is my second pass at it. 45 min render time on this one.
        • fuzzionF Offline
          fuzzion
          From my years of experience , if your surface is not
          1. A golf course
          2. A straight large plane with little bits of curve
          Then
          Go for make fur plugin. Its works well with short and small corners, giving it that realistic look
          Below are some attachments.
          This took 2 mins to render. Not sure why you took 45mins
          Without VRay
          Afer Vray and plugin --->
          Vray with Fur plugin
          "Only the dead have seen the end of war" - Plato
          • V Offline
            valerostudio
            Fur is great, but I have issues trying to fur an entire front lawn.
            • fuzzionF Offline
              fuzzion
              True. The trick is to only place grass from where you intend to render, Hence in this photo there is no grass/fur plugin used(Behind the house) since that plane is hidden. ➑
              • V Offline
                valerostudio
                What we really need is VRay Fur inside of SketchUp!
                • andybotA Offline
                  andybot
                  [attachment=0:2fvsrfcp]<!-- ia0 -->Futzer2.jpg<!-- ia0 -->[/attachment:2fvsrfcp]
                  unfortunately, the scale is way off there. That's much coarser than real grass. To get it fine enough, you would run out of memory pretty quick.
                  • V Offline
                    valerostudio
                    I have to agree with Andy on this one. The only way to really render grass is proxies or something like VRayFur. Watch this and dream of having these abilities one day in SU!
                    • fuzzionF Offline
                      fuzzion
                      @andybot said:
                      [attachment=1:18jit4q3]<!-- ia1 -->Futzer2.jpg<!-- ia1 -->[/attachment:18jit4q3]
                      Its called cow grass πŸ˜’
                      [attachment=0:18jit4q3]<!-- ia0 -->Rumput 1.jpg<!-- ia0 -->[/attachment:18jit4q3]
                      • andybotA Offline
                        andybot
                        if you like that sort of thing...
                        • fuzzionF Offline
                          fuzzion
                          The cows liked it πŸ˜„
                          • 2 / 2
