    [Plugin] CleanUp
    974 Posts 217 Posters 861.1k Views 217 Watching
      Solid Solver and Fix Solid should both do it - at least they where made to do so. Perhaps you have an edge case there.
      • voljankoV Offline
        voljanko
        @tomot said:
        I created a simple cube greeble ruby a while ago that draws an array of cubes in xy, xz, yz, or xyz planes. My idea was to carve out cubes from these arrays to create other 3d objects, retaining the basic cube module, much like the Voxel idea. Attached is 3d object file.
        I ran Cleanup on this file. but it was unable to delete the redundant interior faces.
        In addition is Cleanup able to remove the unnecessary exterior cube lines while retaining the integrity of the 3d object?
        Hello,
        I have checked the model it with SuSolid plugin and fixed the model with 1 button.
        David
        SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
        • olisheaO Offline
          olishea
          @tomot said:
          none of them perform interior face removal 😞
          Have you tried Remove Inner Faces plugin?!
          oli
            tomot
            @voljanko said:
            Hello,
            David
            OK!..... please attach my file with you 1 button fix πŸ‘
            my plugins
            tomot
              tomot
              Where? there is no such name when searching at this forum or at the ruby library depot.😞
              my plugins
              tomot
                You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
                • voljankoV Offline
                  voljanko
                  No problem πŸ˜„
                  Hilbert_all_solids.skp
                    tomot
                    Yes I included that thread also, visually I did not find anything. 😞
                    my plugins
                    tomot
                      Use the browser's search feature to quickly find things. (Often F3 activates it)
                      • mitcorbM Offline
                        mitcorb
                        Remove Inner Faces by wikii in the Plugins Index.
                          tomot
                          @thomthom said:
                          Have you looked at TIGs tools?
                          I have, in fact I have been trying to compile a Rubies folder on this subject, which is far from complete. Here is what I have so far.
                          TIG solid solver
                          TT cleanup
                          Fix solid
                          ky delete Interior faces
                          wikii remove Inner Faces
                          my plugins
                          tomot
                            tomot
                            Thanks! it was the first one I tried a while ago, it also did not meet the test.
                            I added to my list, in the event someone else is searching this subject.
                            my plugins
                            tomot
                            • mitcorbM Offline
                              mitcorb
                              Actually, olishea said it first. I was just clarifying who what the when where and how.
                                tomot
                                @thomthom said:
                                "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                                NO! I mean like the attached pic. The left image in xray mode shows the cubes and interior faces. the right image in xray mode shows the manual removal of the exterior edges. Naturally in this simple example the manual removal of the exterior edges automatically also deleted the interior unwanted faces. But in more complex organic meshes this is not always that simple.
                                my plugins
                                tomot
                                • david_hD Offline
                                  david_h
                                  I have loaded Cleanup3 but i get this warning screen. I have tried searching for this addon but can't seem to find it. any help here?
                                    penumbra
                                    try here;
                                    http://sketchucation.com/forums/viewtopic.php?t=30503
                                      Linked right above the download link - under the "Requirements" header.
                                        Seems there is not an inner faces selection eraser?
                                        • david_hD Offline
                                          david_h
                                          Thanks. I have that and I have run the little installer as well.
                                          It's going now. thank you.
                                          You see. . this is why I really shouldn't be wearing the green badge.
                                            shifo1002000
                                            I can't get it to work for Sketchup 8 pro, I pasted the file "tt_cleanup.rb" in the sketchup plugins folder but I get a (Error Loading File tt_cleanup.rb
                                            no such file to load -- TT_Lib2/core.rb)
                                            Can you please help?
                                            I also posted on your video on YouTube, sorry for the inconvenience
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 48
                                            • 49
                                            • 28 / 49
