    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 792.6k Views 175 Watching
      It's in the first post of this thread. Click on it and it should download to your computer.
        bektaş
        thank you
        • E Offline
          erjenprins
          I can't find the zipfile, is it gone?
            Really? Look at the first post in the thread?
            • I Offline
              imabzeous
              I just dont know why will this happen to me and till when will it continue..... whenever i use any of extrude tool my sketchup crashes.. no matter what.. i use simple arc, i use bezier script... i make new files.. i work in older... but it will crash... it will work well will ask for all the options, reverse faces, erase faces etc.. but after tha it will crash 👊 so please please if anybody can help me out
                What other complex tools do you have loaded when using the EEby... tools?
                A few are known to change native-API methods, or have observers which are clumsily made and cause splats with innocent tools; when, like this one, they are adding groups etc...
                Is it a 'hang' [white-screen/unresponsive but it will complete given time] or a full 'Bugsplat' crash where Sketchup closes...
                Are there any messages in the Ruby Console ?
                Try disabling any other tools that you might suspect [temporarily move their .rb files out of the Plugins folder, adding them back [in steps] and restarting Sketchup until you have found the culprit[s]].
                There is a list on SCF of 'quarantined' scripts that are known to cause problems [like the old-version of Sketchy Physics etc]. Some recent 'BIM' tools are also known to add observers that can make big trouble even when they are not running, because their observers are always 'watching' and causing issues for others...
                A screenshot of any messages and/or the Plugins folder would help fix the issue, which I suspect isn't EEby... but other things interacting with it...
                • I Offline
                  imabzeous
                  Thanks a lot for your quick reply TIG.... i don't have many complex tools... the only one i can think of is power tool... but i remember this happened before too... and i have installed this tool recently....
                  here is a screenshot of my plugin folder... Bezier line script was installed after my first comment .. i thought may be there is some issue with native arc or its not welded so i decided to use that .. but it also didn't work.....
                  there aren't too many complex tools... but i will do and install a fresh copy...
                  but if you can suggest that which script is creating the problem...
                  and its full 'Bugsplat' crash ... like i run the script its running and suddenly it closes and sketchup ask for the crash report..
                    Most of them look OK, a few I am unfamiliar with...
                    So first try disabling the PowerBar tool rb file, restart and retest EEby...
                    [make a temporary 'Disabled' folder inside the Plugins folder, and move them into it]
                    You also have a number of Renderer tools loading, perhaps disabling some of those would help...
                    Otherwise disable ~half of the other rb files, restart and retest EEby...
                    If it still splats you know it's an issue with one of those rb files that are in Plugins so disable ~half of those etc and retest.
                    This way you can quickly zoom in on the clashing script.
                    If the issue stops after disabling some files you know the culprit is in the moved set, so reverse the move of ~half and again zoom in on the culprit...
                    You only have about 40 rb files to test [and most of those look innocent enough] so dong things 'by halves', that's 40 >> 20 >> 10 >> 5 >> 3 >> 1
                    That's a maximum of ~5 steps to test all of them, but you're likely to find the issue much quicker...
                    Let us know it you find the problem... 😕
                      Try to disable the render engines. They can often lead to crashes - especially if you have multiple loaded at the same time.
                      • Z Offline
                        zxinfinity
                        I know that podium doesn't play well with others. I'd start with that, I had the same issue with podium.
                        • BoxB Offline
                          HI Tig just a quick question.
                          Is it possible to set defaults for the various popups at the end?
                          For example I use EEBR quite often to create several sections and often the answers, no, yes,yes,no,yes,no will be the same for the next however many pieces I have.
                          As this wing shape has 7 sections it means a lot of clicking.
                            No, but you don't need to move the mouse and click the button.
                            Hitting the space-bar is equivalent to clicking the default button - here 'Yes' - or on an EN Windows PC pressing the Y key is also the same; pressing the N key takes the opposite button - here 'No' - ... presumably other locales have different, but similar shortcuts...
                            • BoxB Offline
                              OK, thanks Tig, yep I use the keyboard, just wanted to be sure I wasn't missing an easy setting.
                              • JBJDesignsJ Offline
                                JBJDesigns
                                Hi TIG!
                                Just want to let you know that I'm having a fabulous time testing out the various Extrude Tools in your plug-in! The tool works great -- and for a newbie, it's nice to have all the little "reminders" of what to do next. Thank you very much for your contribution to the community. I do truly appreciate your hard work!
                                Jo 😄
                                ...you send them to school, you give them books, and they eat the pages...
                                  MinjaRulezz
                                  i registered and i cant download
                                    If by that you mean that attachments aren't visible to you, then that suggests that you are breaking SCF's ToS to which you agreed when you joined, i.e. you are using a AdBlock app on your browser when visiting SCF.
                                    If so then you need to disable it for sketchucation.com AND buysellads.com, when the page is reloaded you should see all attachments...
                                    SCF relies mainly on a modest income from advertisers to pay its bills, it is free to you but costs money to run it. Unless advertisers have an expectation that you will see their ads they won't advertise and so SCF won't be able to continue because it'll go bust!
                                    The ads are discreet and vetted to ensure their relevance to members - so to have them 'on' is no great hardship, and it can actually be interesting and helpful...
                                      rsroy222
                                      Love this tool set! very helpful!
                                      • N Offline
                                        Nevernever13
                                        thanksss
                                          Here is an updated version http://sketchucation.com/forums/viewtopic.php?p=217663#p217663
                                          The tools themselves are basically unchanged BUT they have been recast in a more robust way that anticipates possible future changes to the way plugins work...
                                            dyustin
                                            Hello. I have tried to install your extrude tools package over the Sketchup installer, and tried to activate the extension / plugin (by unzipping) but I continually get an error message when I start Sketchup... TIGtools folder or file is not present. I set up a TIGtools folder and it still didn't work.
                                            I have already installed the toolset on my laptop without trouble, but that was the .zip file, which I just unzipped, and ping it worked. I am on my xp desktop at the moment and would very much like the use of your great tools! Can you help me out here?
                                            Thanks, Justin
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 31
                                            • 32
                                            • 25 / 32
