    Creating ribs...?
    34 Posts 10 Posters 2.1k Views 10 Watching
      mac1
      I looks like you have a transition from the nose cone to the body not accounted for. Try and add some more info in that area. I did just a slanted line and the bump is no more ❓
      BTW you can take the section after the nose cone, copy it forward and use the scale tool to match the profile of the wind shield and maybe get much better results.
      I maybe misreading the drawing but it looks like the section elevations are not symmetrical with center line. Check that you may need to include the total cross section vs 1/2 you are now ❓
      • cottyC Offline
        cotty
        @solo said:
        Post your file save as V6 for a more large audiance!
        Hmm, I believe you are the last one. πŸ˜„
        "More large" is true nevertheless πŸ˜‰
        my SketchUp gallery
        • bunnyackB Offline
          bunnyack
          @bunnyack said:
          I'm not blaming curviloft, I suspect its me doing something wrong while creating the ribs πŸ˜‰
          how & with what tools are you using to create the profiles?
          I simply create square planes in the right dimensions (just like done in the tutorial I linked above) and then use the arc tool to round them off on the corners.
          • gillesG Offline
            gilles
            Play with parameters you see on the picture, READ the documentation.
            Also for better results make al curves the same account of segments, use BZ tools, right click on a selected curve then choose convert to/ segmentor.
            • bunnyackB Offline
              bunnyack
              Thanks, I had never tried playing with the parameters, that does help a lot. You mentioned BZ tools, what are they and if thats a plugin, where can I get it?
                Fredo's Bezier Spline Tools
                • gillesG Offline
                  gilles
                  http://sketchucation.com/forums/viewtopic.php?t=13563#p100509
                  Read the doc! πŸ˜‰
                  • bunnyackB Offline
                    bunnyack
                    Read the doc! πŸ˜‰
                    Sorry 😳 will read. And thank you!
                      All the power of Curviloft is inside changing parameters!
                      It's like a stand alone program inside SU ! β˜€
                      PS
                      No,no, I know even some people who has stay in the V5 Pro without Update ! πŸ˜‰
                      • gillesG Offline
                        gilles
                        Your old brother? πŸ’š
                        • bunnyackB Offline
                          bunnyack
                          Again, thank you so much! β˜€
                          for the first time, I'm actually happy with the results I get, and its thanks to Fredo's BZ tools you mentioned. This finally solves a huge problem, which had been holding me up for the past weeks. The body still needs some minor tweaks, but it is finally free of holes and bumps all over it:
                          You sir, saved my day.
                            mac1
                            You should not be doing that. The drawing gives you section planes a,b,c,d,e etc for the the profiles of the fuselage.They are not symmetrical with is cenetr line and what I was trying to tell you above.
                            • jeff hammondJ Offline
                              if you just loft the profiles provided on the top view without paying attention to creasing when appropriate.. it gives you somewhat of a more conceptual or futuristic looking shape that you might be able to use as a launching point if you ever get into a more loose interpretation mode..
                              huey2.skp
                              [edit]..to tie in more appropriately to the thread-- i guess i should add that even though this isn't what you're after, it's an example of using fredo's BezierSpline tools to draw your profiles (uniform B-splines.. order 4.. 30 segments each)..
                              i could probably edit them in certain areas to get a better mesh with CurviLoft but i don't really see a problem with just lofting what BZspline gives..
                              • gillesG Offline
                                gilles
                                Looks like a gold fish Jeff, do you πŸ’š think this could fly?
                                  yes.. very well actually..
                                  i mean, it looks like it would fit very nicely into the palm of your hand.. better than a football even (not those spherical things)
                                  • gillesG Offline
                                    gilles
                                    You could had two horns to get a Rhino.
                                    Just kidding.
                                    πŸ’š πŸ’š
                                      πŸ‘
                                      • bunnyackB Offline
                                        bunnyack
                                        Yeah, I noticed that the hard way... πŸ˜„ I should have used the given section planes, but now I've got it done anyway. Took a little longer but it looks good, IMHO:
                                        • jgbJ Offline
                                          jgb
                                          I do this sort of thing a fair bit, and without Curviloft, I'd still be trying to finish the first one.
                                          But here are a few tips on what I've learned so far.
                                          When CL creates a bad surface, most usually it is because A) too many vertices, B) Doing too big a surface in 1 go and C) Not enough curve guidance.
                                          A) Cut back on the vertices. Instead of the usual 24 segment circles, use 12. And by all means, try to keep the segment count on opposite sides of a contour the same, and evenly spaced. Not usually possible. When there are big differences, CL will create a very high poly count mesh.
                                          It tries to connect opposite points in parallel curves to the sides of the contours. That will create a myriad of extra lines and new vertices on the contour, and this is very difficult to clean up if you want to reduce the line count.
                                          B) Do big surfaces in 2 or more sections, using common contour lines. Do not explode the CL groups till you are done and satisfied. This makes it easier to redo or modify a section, and you can be sure adjacent sections are formed from the same contour lines.
                                          After CL does its thing and you explode it, the contour would almost always have many more segments than before, making the next surface that much more complex. Also, making several sections prevents any complex surface from influencing the next, like at the intersection of the windshield to the body sides and nose of the Huey.
                                          C) If your contour makes significantly big changes, and B) didn't help much, then you need to add additional contour control lines between the original contours, and do them as separate sections.
                                          I will first make the surface, that does not form the way I want. Then, I will draw a new contour line midway along a curve that is what I want, using the bad curve as a guide. Then I delete the bad CL surface and CL the section as 2 sections. This will almost always give you the desired end result. When happy, explode everything.
                                          I cannot live without Curviloft, in spite of it's (very) few warts. 😍
                                          jgb
                                            hey joel..
                                            a lot of what you say up there is true but there's more to it than "don't do big surfaces -- break them down into smaller sections using more curve definitions" [/paraphrase]
                                            generally, you want to make the surface as big and singular as possible..
                                            but, i suspect the problems you encounter don't actually have anything to do with the size of the surface, it's that you're trying to give curviloft more than 4 sides..
                                            you can't define a surface with more than 4 sides.. (this isn't just with cuviloft.. i'm talking in general)..
                                            and since cuviloft isn't a patching type of tool (i.e.- resulting surface will go through all of your edges, even if there are more than 4.. but the surface itself is larger and 4 sided.. just cut away.. )
                                            ....it's not a patch tool so it's going to break the surface down into 4 sided sections and deal with them individually..(which is sort of neat that it will do this.. other curve network commands i've seen won't even work if you try to give them more than 4 edges.. but with curviloft, i feel it's necessary to understand that unless you're using 4 edges, you're more likely than not going to be left with undesirable results)..
                                            some pics..
                                            now, while patching may look like the better choice, it's not really.. you don't have much control over the surface it creates other than it will pass through all the edges and allow for some stiffness control..
                                            the 'real' way to do it is by defining your surface(s) with 4 edge curves.. the way you should be doing it with curviloft.. as you will be able to much better define the resulting shapes.. for the arc/pentagon example, you should manually create the curve bisecting the shape to required/desired spec..
                                            that said, with an app like sketchup which is mainly going to be used for previz in these types of circumstances, a patch tool might be highly welcome because it will infact easily&quickly get a surface in there which is going to look nice and smooth etc.. just don't go in there and try to pull any measurements off the thing πŸ˜‰
                                            [edit-- actually, we already have somewhat of a 'patch' tool in sketchup and that is soap skin& bubble.. but another thing to notice with that tool, it's all about laying a grid over all your curves.. it's thinking in a 4 sided surface stateofmind then trims away the borders.]..
