    Sketchup 64 bit?
    170 Posts 35 Posters 66.6k Views 35 Watching
    • N
      notareal
      @thomthom said:
      @jason_maranto said:
      Every workable solution I've seen requires the user to leave SketchUp -- which by definition means it fails as a host.
      The render engine can pipe the data to a 64bit process - so only the UI is hosted under the 32bit environment of SketchUp.
      Perhaps platform specific solutions (http://msdn.microsoft.com/en-us/library/system.servicemodel.netnamedpipebinding.aspx)? If so, then multiplatform programs could have issues (or at least do require more work). Like said, communication between 32 bit process and 64 bit is possible, but for some reason it's not used that often... I am pretty sure that there must be some good reasons for that šŸ˜‰
        jaceguay
        External Proxies/Instances are besides the point -- the geometry must be still loaded into the 32-bit SketchUp process in order to be rendered inside SketchUp... so even proxies can put you into a RAM based failure to launch the render.
        The reality is that SketchUp cannot adequately support the tools visualizers are using as a host app... and the concept of SketchUp as a platform is a failure because of that.
        I've not seen any other modern software that struggles as badly as SketchUp -- the "real-time" rendering in SketchUp might be part of the problem, and obviously you can also blame the inferencing engine as well to a certain degree. But better packages allow you to disable/enable those features as needed, rather than forcing you to suffer through them because of some philosophically misguided rationale of "simplicity trumps all"... which to me reads more like the developers (Bacus) saying "I know what's better for you than you do".
        Best,
        Jason.
        The real time rendering or viewport performance don“t get any advantage from the jump to 64bits, I think also there is no viewport performance gain in any 3d software from going 64 bits or more CPU cores. On the other hand taking advantage of the GPU its exactly what matters in this case, I“ve been using blender for about two years and before that 3dsmax, In fact the viewport in sketchup are ages in front of these two, as there is a clear and unique hierarchy in the visualization as a whole: lines, hidden lines, smoothed lines, faces and textures.
        In other apps to have this control over all the meshes of my scene I“ll usually have to jump in specific view preferences, modifiers preferences, proxy object propriety etc. and still only one at a time.
        In fact I can only imagine using any other viewport at all it“s because the modifiers, that enable you to manipulate the high poly meshes or polys, they have some LOD setting and don“t display the complete mesh all the time.
        And if I want to produce hi-poly renders I“m happy to work with my model surrounded by low poly avatars of the objects. But really for me the unique feature that make me use sketchup it“s about visualize and explore so this is the completely the other way.
        In my opinion you should take a look in another software, I did some years ago when I was needing to produce and control heavy poly models, and at that time I was feeling refreshed for all the new possibilities, still after some time I“ve came back to sketchup and even became a PRO user for what it is.
        • jason_marantoJ
          jason_maranto
          I wasn't referring to any advantages of 64-bit in regards to viewport rendering (which is open GL/video card based) -- there are several competing points being argued here, of which 64-bit is only one small part.
          Also, I have said repeatedly (elsewhere) I already do use several other 3D modeling packages (subD, Sculpting, etc.) -- it's not any mystery to me how the other parts of the 3D world live.
          I know few people here know much about me, but I do get tired of repeated shooting down the same arguments... I dislike repeating myself, and this conversation has become almost entirely repetitive at this point -- So I'm going to bow out.
          I've said what I've said -- I meant it all, and nobody has convinced me otherwise... so I'll let that stand.
          Best,
          Jason.
          • jeff hammondJ
            @thomthom said:
            And if you compare against other applications you can see how they usually provide a much more degenerated view of the model and leave the presentation to the render engine. While SketchUp has its real time sketchy render engine running at all time - generally providing a better presentation of the model in the viewport than what other engines do. It's quite a different animal from most out there.
            i don't know about that thom..
            here's a little vid showing an xfrog tree in rhino.. at first, i show the wireframe or degenerated view.. then the shaded view which is, as far as i can practically gather, the same thing we see in sketchup.. then i switch to rendered viewport which shows all the textures along with soft shadows etc..
            that's on a 3yr old laptop which is also running a screencapture software at the same time.. do it on a more suitable workstation and it takes a few of those trees just to show any sign of weakness..
            also, it takes about 1 second to import that into rhino.. we're looking at maybe 30 minutes to get it into sketchup at which point, the model is all but unusable anyway because sketchup becomes so sluggish..
            so from a user standpoint, i'm actually seeing better real time rendering at a very (very!!) noticeable performance increase compared to sketchup.. when using the same exact geometry and textures..
            so when i see this type of stuff with my own eyes on my own computers and my own projects, i can't help but wonder "what in the duck are those su devs sitting around doing all day??!!... it's obviously (very obvious!) possible to get way better performance out of a 3D modeler " ..or whatever..
            • jeff hammondJ
              and seriously.. i'm open to other people showing my the flaws in my logic here.. i mean, if I'm incorrect in my thinking here, how should i be processing the above scenario in my head?
              [edit] i should also add that this is mac rhino.. the rendering engine being used at this point in the beta is the old rhino4 engine.. i imagine things are way better on the official 5 release..
              [edit2].. see this as well:
              http://blog.rhino3d.com/2012/04/neon-10-beta-1-now-available.html
              • SketchUp Guide TommyS
                My comments and opinions are mine and mine alone. My goal is not to argue, debate, or sway. I simply want to express myself.
                I've worked with John for a little over 7 years now. He is a decisive, intelligent, and fantastic leader whom I would follow to any company. Period. I understand that excuses are not requested here, only results. Well, we've been hiring roughly a new person every month since beginning with Trimble. A huge breath of fresh ideas and innovations have been infused into SketchUp's (pale?) skin. It's no mystery that development on the SketchUp client slowed near the end of our time at Google. However, the improvements that I've seen over these short months have been astounding to me. I feel like everyone is very excited for the huge potential and future for SketchUp. Albeit, many wholes have yet to be filled, but that's a challenge we're prepared to face. Will you be blown away with the next version of SketchUp? I don't know. We'll find out. Ripping a software infrastructure out of a company (especially Google) and setting it up in another company isn't exactly like moving a tent between two camp grounds. We're working fast and furious to deliver great products (because SketchUp is only part of our portfolio), but it may take some time to see the strides of innovation that we expect from ourselves (let alone the expectations of SketchUp's passionate community). Patience is a luxury that no software company can ask of its users, and I won't do so today. If you've used SketchUp to successfully complete a project in the last month, year, or eight years, then we've done our job. Of course, we want all SketchUp users to continually find success with SketchUp every day, and if they don't they should absolutely explore other options. Competition does wonders for innovation as well (I learned that at Google šŸ˜‰.
                Many thanks for lending me your time and attention.
                Cheers!
                Regards,
                SGT
                  Thanks for chiming in Tommy. I do look forward to seeing what SketchUp 2013 brings. I realise it takes a while to reorganize and that lots of the time spent the last year has been restructuring from Google to something new, but just the fact that SketchUp is now looking get annual release cycles gives me good hopes. My expectations of the next release is a small indication to what I could expect in the future - contrasting it to the direction we saw Google taking it.
                  It'll probably be of no surprise to anyone that I'll be looking more toward what the Ruby API will give than anything else.
                  • jeff hammondJ
                    yeah.. i do some random stuff from timetotime for an ad agency here and saw them move from downtown up to hell's kitchen.. around 80 employees (and probably hundreds of computers)..
                    it took them a few months to get back to normal production rate and at two years now, i'd say they're almost fully settled in..
                    so that And moving to a different parent company surely must be a nice bit of fun for you all šŸ˜‰
                      Aerilius
                      Thanks Tommy!
                      I believe patience is in this case challenging for many (since the last major release is some long time ago). New features are still (even in these hard times) not disclosed (or even hinted). Nobody can understand what you are really working on very hard until it's released with a big surprise.
                      Let's have good hopes, everything suggests a positive future.
                      • PixeroP
                        Pixero
                        My understanding is that Google didn't give out any information until release.
                        What's Trimbles stand on this?
                        Many software companies have a more open communication with its users and publish teasers of upcoming new features and such to keep the user base "happy" and informed of what to expect.
                        I feel the last years lack of communication added to the frustration when users had high hopes and were disappointed when the product shipped without features we "guessed" would certainly be there. (Me included.)
                        • soloS
                          Good point, I hope Trimble does not inherit Goggles bad habits and anti user philosophy.
                          • jeff hammondJ
                            i'm thinking after 10 months of trimbleSU, we can figure out the answer to that question on our own..
                            • Chris FullmerC
                              @Last wasn't too open either about their upcoming releases. I think its built into them, more than imposed upon them šŸ˜„ I could be wrong though!
                              • soloS
                                I hope not, I'd really prefer an open relationship, working together, feeling part of the Sketchup team. More understandable to get news of a feature I need not included when well discussed and explained than nothing.
                                • PixeroP
                                  Pixero
                                  I believe the positive effects of openness far outweighs any giveaways to a competitor.
                                  (To be honest I feel SketchUp has a lot of catching up to do before the competition would be interested in what they about to do.)
                                  Just think of how many great ideas could come if Trimble "sat down" with us and asked: "What can we do to make your everyday life easier?"
                                  I wish Trimble would realize how lucky they are to have such a devoted user community. I also believe that the more devoted the community is the more it should be included not excluded.
                                    That's a nice way to put it.
                                    Download the free D'oh Book for SketchUp šŸ“–
                                      Like BaseCamp?
                                      Like Reddit?
                                      Like the feature request thread on the Google forum?
                                      The thing is, I think many people would like them to say in advance what will be released next round. Which I fully understand any developer to hold back. Because it's really hard to predict what will make it into the next release. Something might crop up that makes implementation take longer, maybe it has to be scrapped because it caused unforeseen consequences.
                                      Expecting them to reveal in advance what will be included is a dead end.
                                      I do think they have several channels where they do listen. ("Listen" doesn't mean they will do everything that is mentioned.)
                                      I was not really wowed by the features implemented under the Google reign. Sure, there was some nice ones, but considering the time SketchUp was owned by Google I had somewhat expected more to develop - one thing is the modelling tools another is the API and docs. But as information has come out after Google it's clear that Google wasn't throwing resources after the product - only enough to build what they needed for their mapping services.
                                      Now with Trimble, we've yet to see a full release, but we do know there will be one each year. So at least that's some predictability - as before you never really had a clue. It also indicate increased development. And they even announced several positions after the Trimble acquisition - meaning their expected workload is increasing. And at BaseCamp they said that Layout would receive more attention - a product nearly laid dead under Google.
                                      So, I'm excited about this next SketchUp release, but even more so for the 2014 release - because that will give an indication to the direction and changes SketchUp will make and it would have given this new Trimble team time to settle in.
                                      • PixeroP
                                        Pixero
                                        There are several software companies that are more open about such things.
                                        There can be roadmaps, tech news and such without specifying a date when a certain feature will be released.
                                        Thea Render is one, just to mention an example.
                                        Hey, even Adobe and Autodesk has "labs" with technology previews.
                                        • Mike LuceyM
                                          Mike Lucey
                                          Guys,
                                          I see this debate has moved to the question of disclosure and communication with the user-base!
                                          Someone said that @Last did not disclose in advance what was to come, not exactly so! I distinctly remember attending one of the BaseCamps when quite a few intended new directions were indicated and demo'd on the big screen! Some made it into the subsequent release, some didn't, at least it opened up opinion, debate and created buzz! There was no one too disappointed that certain things indicated didn't make it and everyone loved the buzz šŸ˜„
                                          In my humble opinion there are two reasons a company / manufacturer will not make know what it has in the pipeline, either the new product is so innovative that it doesn't what to let the cat out on the bag in fear that it could be upstaged / copied by others or they simply don't have anything much exciting in mind!
                                          The new trend these days, even adopted by Apple if what I read can be believed, is to 'leak' information. The new iWatch for example! There is some method in this 'madness', it creates a buzz rather than moaning and groaning ..... like we have here on this particular thread!
                                          We won't have to wait too much longer to find out which it is, ground breaking or mundane! I understand the next release of SketchUp and its siblings, if they materialize, will be called SketchUp (flavor) 2013 etc ...... there are only 10 months left in 2013 and I imagine we will not be seeing a last minute release ...... then again there is not even a release date set in stone. No deadlines equals no decisions made!
                                          Whoever is in charge of 'buzz creation' at Trimble SketchUp, if anyone, needs to look at the situation with new eyes. They are missing a golden opportunity! I am at their service should they need advise / assistance šŸ˜‰
                                          Mike
                                            Aerilius
                                            Oh, we can't leak what we know, and we can't leak what we don't know. šŸ˜ž
                                            With your input, this post could be even better šŸ’—
                                            • 7 / 9
