    PDF Print/Export is crazy slow!
    layout
    21 Posts 9 Posters 9.6k Views 9 Watching
      Charlie__V
      Perhaps a shared benchmark file is in order?
      (For .pdf export time/file size...I know...I know...but perhaps it is simply not hardware related).
      & fwiw, the 2 projects I mention are ~ .25 acre and probably ~6+ acre respectively.
      Unfortunately I cannot share the actual project files...maybe a vanilla/pseudo variant?
      Thoughts?
      Charlie
        sonder
        Well, if you want to see crazy PDF file size, I have one set of CDs for a 4000 sf house that is 415 mb. I exported on high quality. What I found is that exported to low quality printed on 24x36 inch paper reads really well, so that is why I export on low quality now. In fact the difference between high and low when printed is minimal at best.
        If the file size is a problem, there are PDF exporters that work well. For me, the ease of export out of layout is great. If you are vector rendering an entire model, that is where you will pay in time. Mine are all raster with isolated line work vector rendered, so I never see exports take longer than 30 seconds for the larger files.
          sonder
          Thoughts?
          Charlie
          I'm getting a new machine in two weeks, but my current setup is:
          I7 2600k
          Nvidia gtx 550ti
          16gb ram
          (1) 47" led
          New machine:
          I7 3930 super clocked to 4.2-4.6
          Nvidia gtx 680
          64gb ram
          (3) 47" led......he he he.
            Penguin2
            Not a technical answer but I found that certain styles I was using in Sketchup quadrupled the PDF file size in Layout.
            Penguin2
              I use a pretty standard template based on the Architectural style.
              • V Offline
                victorcn
                right click on layout process in windows task manager, set priority to high. It'll speed up a little bit
                • RichardR Offline
                  Richard
                  Have you tried optimising the PDF's after export - this I've found can reduce the file size of lots of CAD generated files.
                  Advanced > PDF optimiser!
                  BUILTBRAND.COM.AU
                    Yea, very mixed results. The ones that actually bring the size down makes everything look really bad.
                    While in comparison, if I set up the same pages in InDesign I get much smaller files, no problem.
                      Look at the meta of an InDesign export and a LayOut.
                      • KrisidiousK Offline
                        Krisidious
                        I've learned to use my PDF995 to print PDFs out of Layout. It's much faster and the file sizes are 1000 times smaller with all the detail. It's a pdf printer port emulator.
                        By: Kristoff Rand
                        • RichardR Offline
                          Richard
                          Clever
                          BUILTBRAND.COM.AU
