    Terrain from contours - improve on native 'from contours'?
    99 Posts 18 Posters 29.1k Views 18 Watching
    • utilerU Offline
      utiler
      No problem, Fredo, I'm not surprised at issues with the first one as it was a survey of a site with an existing residence on it which prevented a uniform data to be taken...
      What you've done with the other one looks good! Can't wait to see how this plugin ends up. I'll see if I can dig out some other survey plans off file and convert them for you.
      πŸ‘
      Just Curious...
      • fredo6F Offline
        I evolved the algorithm for calculating the concave hull on your complex model and could obtain a result on your model, without any change, here attached.
        A lot of the problem come from the small terminations hooks in several contours, like illustrated on the picture below
        The issue with terrain construction is that you need to have a correct hull in order to determine the spatial distribution of the influence of the contours.
        utiler_survey01.skp
        PS: I hope to finish a first version in 2-3 weeks time, as I have actually very few moment available currently
        • EarthMoverE Offline
          EarthMover
          Can't wait! Thanks Fredo!
          Content Creator at Skapeup
          • utilerU Offline
            utiler
            that is looking very sweet, Fredo!!!! Can't wait as well!!!
            Just Curious...
            • KrisidiousK Offline
              Krisidious
              here's a topo I just got from a survey company... if you need tests.
              HANNA-TOPO.dwg
              By: Kristoff Rand
                EarthMover
                Here's another set of contour lines from my current project. All welded up.
                Coleman Topo.skp
                • pbacotP Offline
                  I've gone ahead and started using one of the tests you made of my contour set, Fredo. I don't have a lot to do as yet but it was really clean leveling some areas and "filling" others with Artisan. Maybe we can illustrate the cut and fill on the project with before and AFTER terrains. Thanks!
                  • fredo6F Offline
                    Adam,
                    Here is what I obtain on the original file. I think however that the contour should be simplified a little bit because there are a lot of edges and it slows down the calculation.
                    Earthmover Coleman Topo.skp
                      EarthMover
                      A quick play with the contours. Simplified the curves using Thom's Edge Tools. Then did a From Contours terrain. Then a Drape Cpoints / Triangulate method to retopo. Then opened the high res contour lines in 3ds Max and used the free Populate Terrain plugin to generate a similar terrain. Then brought it back into sketchup and compared the two.
                      Earthmover Coleman Topo (1).skp
                        dtrarch
                        Terragen2 download πŸ‘
                        http://planetside.co.uk/index.php?option=com_content&view=article&id=30&Itemid=170
                        Someone here was looking for this and here tiz β˜€
                        dtr
                        • fredo6F Offline
                          By the way, did anyone try SimuTerra? (see this post)
                          • Chris FullmerC Offline
                            Does anyone know if Erez is still maintaining his Simuterra program? We haven't seen him around in ages!
                            • soloS Offline
                              Nice clean results.
                              I have a set of contours that I'd like to compare if you have the time, I used sandbox and got a mess, wondering if this will give a better result. Here is the skp, however I'm wondering if the dwg would not be better.
                              test contours.skp
                              • fredo6F Offline
                                @solo said:
                                Nice clean results.
                                Here is the result on your model without any change, with the current version of TopoShaper. Grid definition is 60 x 27. I did some tests with a higher definition but cannot post it back because the size of the skp file is bigger than 4 Mb.
                                Note that your contours add up to more than 44,000 edges, with a quite complex concave hull. So it takes a minute to calculate it and there are still some problems on the borders.
                                Solo test contours.skp
                                • soloS Offline
                                  That's very clean, wow, this is awesome.
                                  • pbacotP Offline
                                    Adam,
                                    Very cool working out the c-points method. I didn't realize those capabilities existed.
                                    Fredo,
                                    Thanks for interface video. Looking great! What you do to program this is so far beyond my ken....
                                    Peter
                                    • fredo6F Offline
                                      I imported the dwg file and found that most contours were interrupted in their middle. This is a problem for TopoShaper currently, at it allows topological communication between contours.
                                      I just closed the missing links, and here is the result
                                      Krisidious Hanna Topo.skp
                                      Thanks again for this testing model
                                        Krisidious
                                        Yes, Fredo... No problem. That's where the road runs in the property. I just thought you'd like to get samples directly from surveyors. no touch ups. Looks great. can't wait to buy/download this plugin.
                                        Edit... actually that is not the road. it's where the grade heights are typed in as text.
                                        By: Kristoff Rand
                                        • soloS Offline
                                          Any news?
                                          Sorry about bumping this topic but I'm anxiously awaiting this plugin, hopefully it will be in the store soon.
                                          I have a tricky project, I got contours from Civil 3D in fbx format but even though it's not a very large or complicated mesh needed it seems that there are too many edges (think the segments are too much for su) I open it but it crashes sandbox after 7 minutes of thinking.
                                          • fredo6F Offline
                                            @solo,
                                            I am progressing. Actually, I had to build a cleanser module because all the contours I have seen so far have many glitches that prevent correct generation of terrain.
                                            For your terrain, just send me the contours and I will see if TopoShaper can handle it.
                                            • 5 / 5
