    Problem with SU
    48 Posts 13 Posters 11.0k Views 13 Watching
    • 66searcher6
      66searcher
      it works ! after execute the command my toolbars blast!
      now my sketchup starts faster more than before and then i rearrange the toolbars.
      thank you.
      http://hamidtoliat.deviantart.com/
      • V
        valerostudio
        THIS FIXES THE ISSUE! ThomThom saves the day once again. Hopefully Trimble fixes this as a bug.
        • cottyC
          cotty
          @thomthom said:
          Use at Own Risk!!!
          This is a couple of batch commands I use to clear the toolbar registry. It has worked for me - but I put a word of caution anyway; use at own risk.
          Activate the one corresponding to your SketchUp version.
          I had to change the content of the batch-file to (Windows 7-64):
          "c;\Windows\System32\reg.exe" query "HKEY_CURRENT_USER\Software\Google\SketchUp8" /f "ToolbarsUser" >> reg_keys.txt
          for /f %%k in (reg_keys.txt) do (
              "c;\Windows\System32\reg.exe" delete %%k /f
          (I found 4539 entries, who has more 😎 ? )
          my SketchUp gallery
            [code]"c:\Windows\System32\reg.exe" query "HKEY_CURRENT_USER\Software\Google\SketchUp8" /f "ToolbarsUser" >> reg_keys.txt
            It was made on Windows 7 64bit...
            It's using relative path - I see you used a full path. Seems like there's something odd about your PATH environment variables...
            I've had double that... After a session of longer debugging a toolbar problem. πŸ˜’
              Mine last cleared out at over ~1800 toolbar entries - and it had been crawling !
              After a lot of debugging of scripts/toolbars/extensions etc it does grow alarmingly...
              You must have been waiting forever for it to startup !
              I have a cmd that removes all toolbar guff and extensions too.
              It reduces startup time by a factor of 4 or 5 after it's run and I reinstall the extensions/toolbars I need !!
                Extensions bogg down as well?
                  I think if you keep adding/subtracting/activating/deactivating extensions during tests legacy entries can build up.
                  Seems to slow me down when developing tools using them - if it crashes on a faulty load I think a new one gets added... The extension's name is determined by the loader .rb and if you change the text in that, then the older one can be left behind ?
                  Also if you physically move an extension or rename it .rb! then its extension data is left in the registry clogging things up...
                  Just seems easier to clean them out now an again, like the toolbars.
                  • cottyC
                    cotty
                    The neccessary change was the "/f" instead of the "| find" which causes an error for me.
                    I made it without a single line of debugging πŸ˜‰
                    my SketchUp gallery
                    • Dan RathbunD
                      Dan Rathbun
                      I updated the command file a bit:
                      (1) saves current WD and switches to the User Home dir.
                      (2) first deletes an old file if it exists (because the REG QUERY appends to the file.)
                      (3) Echos the number of lines containing keys to be deleted.
                      (4) Accepts a "view" argument that will open the generated key file in the system's default text application, at the end of processing.
                      (5) Switches back to the previous directory.
                      @echo off
                      set olddir= %CD%
                      cd %USERPROFILE%
                      if exist su_reg_keys.txt del su_reg_keys.txt
                      reg query "HKCU\Software\Google\SketchUp8" | find "ToolbarsUser" >> su_reg_keys.txt
                      echo .
                      echo SketchUp Toolbar Registry entries to be deleted;
                      find /C /I "HKEY" su_reg_keys.txt
                      echo .
                      for /f %%k in (su_reg_keys.txt) do (
                          reg delete %%k /f
                      REM   Open file in default text application
                      REM   if "view" param is passed;
                      if %1.==view. su_reg_keys.txt
                      if %1.==VIEW. su_reg_keys.txt
                      cd %olddir%
                      set olddir=
                      I'm not here much anymore.
                      • G
                        gerrrg
                        Haven't yet posted anything until now...thanks very much thomthom, for this excellent solution! Worked perfectly for me, on a problem that has been plaguing me for just over a month.
                        • G
                          g_wilson
                          Thanks Thom - batch file worked like a dream - startup time greatly reduced.
                          • 3 / 3
