    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 479.7k Views 96 Watching
      @Sound
      The vertex 'duplication' isn't actually a 'bug', since that would suggest that it isn't doing what it is intended to do: and it currently does exactly what it is coded to do.
      However, I do take your [inelegantly put] point that vertex entries could be 'reused' if they are 'shared' by more that one facet...
      So I now have an idea on to make an adjusted version of the code that will now does this: and it can also have a few other tweaks; to reduce the file size further, to optimize the processing time etc.
      I'll post it soonest...
      PS: Although I do 'reserve all rights' to my code... please feel free to make your own improvements to any of my tools, and either PM me or post them here, of course for free unfettered use by all members... The only thing I ask is not to post whole scripts in the same thread as it'll cause confusion... πŸ˜’
        Here's v2.8 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
        The D.P. accuracy is not now applied to 'whole numbers', and any -0 values becomes 0.
        Any shared-vertex entries are now 'reused'.
        The OBJ file size is minimized and the processing time is optimized.
          Sound
          TIG, thank you very much for working on that and for clarifying your terms about modifying the script.
          I will test the new version as soon as possible and report success or failure.
          Have a good day.
            Sound
            I can confirm this works for any model I tried.
            Thank you! Exported OBJ is now topologically correct and thus suitable for a lot more uses.
              Good.
                Here's v2.9 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                Merging of shared vertices is now optional, as it slows down processing for larger models considerably; and it is only required by some more picky mesh-apps, but renderers etc don't seem to mind non-merged vertex data at all.
                  Here's v3.0 http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                  It has a much improved shared-vertex merging algorithm that is now slightly faster than a non-merging version, so the option 'not to merge' has been removed because it is now of no benefit.
                  Where possible, shared-vertex data is always reused, ensuring correctly formed geometry.
                  This can mean that a SKP export containing 100,000 faces and therefore potentially 300,000 vertices can be 'compacted' to use perhaps 50,000 shared-vertices [but of course this depends on each SKP's geometry, grouping etc]: this 'compaction' also reduces processing time [which will now be perhaps ~60 seconds for this sized example], and when combined with the latest optimized 'numerical-entries' gives much smaller OBJ file sizes, and faster processing in 3rd-party apps too.
                  • andybotA Offline
                    andybot
                    Great work, as usual, TIG!! This plugin is very essential for me. Many thanks for your development efforts!
                    • cottyC Offline
                      cotty
                      Thank you for this update!
                      my SketchUp gallery
                        samurai1789
                        What simple instructions???? What ever i do i cannot find it HELP!!!!
                          They are on the download page ! http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
                          There are also some simple dialogs as you go after the tool is started...
                          What problems do you have otherwise ?
                            What made you chose to do this? Are there applications that doesn't handle these values well? I'm curious because I've been looking at the OBJ format this weekend.
                            (Is there an official specification somewhere? I find multiple sources around...)
                              See the external links at the end of the page πŸ˜„
                                Is that the official specs though? "martinreddy.net" ...
                                  It just minimizes the OBJ file size, an importer reads 0 as 0.0, so making it 0.000000 is pointless, -0==0 so it might as well be 0 !... so all trailing zeros are now omitted, it speeds up the writing by a few % and I also the importing at the 3rd party end...
                                  There's an OBJ Wavefront Wiki...
                                    Are you sure all importers manage to read an int instead of a float which the specs appear to indicate? Just wondering in case the parsing is implemented in a stricter language...
                                    Something missing from that sentence? πŸ˜•
                                    This one? http://en.wikipedia.org/wiki/Wavefront_.obj_file
                                      I have used OBJ files exported like this in many apps [Octane, Blender, MeshLab, MeshMan, AC3D etc] and they all import just fine.
                                      As far as I can tell they expect a 'number', so 0 == 0.0 == 0.000000 etc, 1 == 1.0 == 1.000000...
                                      They even take -0 == 0 when -0 is not really a number.
                                      I also trap for 'NaN' and 'Infinity' which would break them...
                                      Sharing vertex data is also permissible if you correctly reference the vertices.
                                      Try it yourself using a box that is located at, and offset from, the ORIGIN by whole 'meter' distances. The native OBJ exporter using m/triangulation, flipped-YZ etc gives a similar result to my 'free' tool BUT 1.000000 >> 1 in mine... Now import the two OBJ files into an app like Blender and you get the exact same result... If you make the two much more complex you'll find mine loads into the app a tiny % faster. Of course it takes longer to write the file because the native exporter is a swifter exe...
                                        There are no way to define faces with holes in OBJ, is it?
                                        I see that OBJ files can support bezier patches - which is interesting for Bezier Surface.
                                          Mra
                                          I'm getting a crash during export, albeit its a large file, the obj gets up to about 5mb and sketchup crashes without warning.
                                          I'm aware this would be highly scene dependant but is there anything I can do? I'd be happy to send in a scene somewhere for debug. πŸ˜„
                                            chuckasaki
                                            Firstly thanks for such a great plugin. I think it's a big rough that google want us to go all the way to 500 bucks for an obj export, something that could be considered pretty standard, and clearly exporting means that they may not even need all sketchup pros power as the model will be used elsewhere. I'd would love to see a slightly less expensive option, cos I ain't going to 5 without a good reason.
                                            Having said that... I don't want to seem like someone whining about a freebie for sure, I think what you done is great..... but I can't get an export that works.
                                            The model goes some way and then crashes- bugsplat . I can open the obj...sure.. but only half of it comes in.
                                            Is your plugin still compatible?
                                            If I can get results I will definitely donate.
                                            • 11
                                            • 12
                                            • 15
                                            • 16
                                            • 10 / 16
