    [Plugin] OBJexporter v3.0 20130131
    304 Posts 96 Posters 642.7k Views 96 Watching
    • andybotA Offline
      andybot
      Great work, as usual, TIG!! This plugin is very essential for me. Many thanks for your development efforts!
      • cottyC Offline
        cotty
        Thank you for this update!
        my SketchUp gallery
          samurai1789
          What simple instructions???? What ever i do i cannot find it HELP!!!!
            They are on the download page ! http://sketchucation.com/forums/viewtopic.php?p=294844#p294844
            There are also some simple dialogs as you go after the tool is started...
            What problems do you have otherwise ?
              @tig said:
              The D.P. accuracy is not now applied to 'whole numbers', and any -0 values becomes 0.
              What made you chose to do this? Are there applications that doesn't handle these values well? I'm curious because I've been looking at the OBJ format this weekend.
              (Is there an official specification somewhere? I find multiple sources around...)
                See the external links at the end of the page πŸ˜„
                  Is that the official specs though? "martinreddy.net" ...
                    It just minimizes the OBJ file size, an importer reads 0 as 0.0, so making it 0.000000 is pointless, -0==0 so it might as well be 0 !... so all trailing zeros are now omitted, it speeds up the writing by a few % and I also the importing at the 3rd party end...
                    There's an OBJ Wavefront Wiki...
                      Are you sure all importers manage to read an int instead of a float which the specs appear to indicate? Just wondering in case the parsing is implemented in a stricter language...
                      Something missing from that sentence? πŸ˜•
                      This one? http://en.wikipedia.org/wiki/Wavefront_.obj_file
                        I have used OBJ files exported like this in many apps [Octane, Blender, MeshLab, MeshMan, AC3D etc] and they all import just fine.
                        As far as I can tell they expect a 'number', so 0 == 0.0 == 0.000000 etc, 1 == 1.0 == 1.000000...
                        They even take -0 == 0 when -0 is not really a number.
                        I also trap for 'NaN' and 'Infinity' which would break them...
                        Sharing vertex data is also permissible if you correctly reference the vertices.
                        Try it yourself using a box that is located at, and offset from, the ORIGIN by whole 'meter' distances. The native OBJ exporter using m/triangulation, flipped-YZ etc gives a similar result to my 'free' tool BUT 1.000000 >> 1 in mine... Now import the two OBJ files into an app like Blender and you get the exact same result... If you make the two much more complex you'll find mine loads into the app a tiny % faster. Of course it takes longer to write the file because the native exporter is a swifter exe...
                          There are no way to define faces with holes in OBJ, is it?
                          I see that OBJ files can support bezier patches - which is interesting for Bezier Surface.
                            Mra
                            I'm getting a crash during export, albeit its a large file, the obj gets up to about 5mb and sketchup crashes without warning.
                            I'm aware this would be highly scene dependant but is there anything I can do? I'd be happy to send in a scene somewhere for debug. πŸ˜„
                              chuckasaki
                              Firstly thanks for such a great plugin. I think it's a big rough that google want us to go all the way to 500 bucks for an obj export, something that could be considered pretty standard, and clearly exporting means that they may not even need all sketchup pros power as the model will be used elsewhere. I'd would love to see a slightly less expensive option, cos I ain't going to 5 without a good reason.
                              Having said that... I don't want to seem like someone whining about a freebie for sure, I think what you done is great..... but I can't get an export that works.
                              The model goes some way and then crashes- bugsplat . I can open the obj...sure.. but only half of it comes in.
                              Is your plugin still compatible?
                              If I can get results I will definitely donate.
                                As I have no way of knowing what it is you are trying to do then I don't have the feintest idea what's up.
                                My exported OBJ files have proved to be compatible with all of the standard apps that can import such files.
                                Have you tried exporting a simple box and seeing if that works...
                                Bugsplats during the export are very rare, if the SKP is large with complex geometry etc it can take a while to complete; so don't confuse a white-out with a 'crash'!
                                When Sketchup is doing intensive calculations it sometimes looses its screen focus and says it's 'unresponsive'.
                                However, it is still beavering away in the background writing the OBJ data etc.
                                Leave it alone until it's completed its tasks.
                                If you run it with the Ruby Console open do you get any error messages ?
                                If you still have issues and it's not just your impatience that's aborting things... then can you post [or PM] a sample of a SKP that is failing, so I can look at it...
                                For example do you have anything peculiar about your SKP files?
                                Like very small geometry, or very large geometry, edges and no faces, oddly grouped geometry, oddly layered faces/edges etc etc... ???
                                • cottyC Offline
                                  cotty
                                  @chuckasaki said:
                                  ... google want us to go all the way to 500 bucks for an obj export
                                  It's not google anymore πŸ˜‰
                                  my SketchUp gallery
                                    mommykathy
                                    Thank You, Thank You, Thank You! Been going nuts trying to find something to do this and this is PERFECT. Have a great day!
                                    • McGyverM Offline
                                      McGyver
                                      Hi! I'd like to thank TIG once again for this truly awesome plugin as well as all the subsequent updates.
                                      I frequently recommend this plugin for people who are new to SketchUp, showing them that their modeling efforts can be used in other programs besides SketchUp.
                                      A lot of people tend to believe that SketchUp is very limited, has no export options for the free version and are not aware of all the amazing plugins that extend SU's capabilities and give it greater power.
                                      I was just writing a short "How to" for people who wish to use their models in Poser/DAZ studio, but it occurred to me that while I giving instructions on how to install a ruby script such as "OBJexporter" I was not sure if there were any other plugins that needed to be installed for OBJexporter to work properly... I have quite a few and the thought came to me when I was describing the progress bar and "Model exported in X# of seconds" features... so I figured I'd ask-
                                      Does OBJexporter require any other plugins such as Progressbar.rb to function properly?
                                      Thats probably a pretty stupid question, but before I tell someone how something works, I figured I should probably include any relevant additional information.
                                      Thanks in advance for any information any of you can provide!
                                      Visit My ShareCG Freebie Gallery
                                        My OBJexporter code is 'self-contained'.
                                        It only 'requires' sketchup.rb, and that is installed by SketchUp itself in the Tools folder...
                                        The progress reporting etc is built-in to my code and needs no 3rd party helpers...
                                        • McGyverM Offline
                                          McGyver
                                          Thank you once again!
                                            the_bored_gamer
                                            Hi, I press the OBJexporter button... then it ask to "convert all to png?".
                                            Wether I press Yes or No, I get nothing, it just close. Please help!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
