Barley Twist Spirals
and here for example after explode the original component for paint each faces
I don't need to make a component again, but just a group!
I just want to thank you all for this thread. It has been a great learning experience.
This thread is hot! Another point I would make is with screw.rb one can then make a component of spiral section that would stack directly beneath the other (without turning) and so you could increase, vary the height (within a module) easily.
I assume that can be done with Gilles' version.
Yes we can!
huhu couldn't resist.
If I understand you right this is one method I used - I made a 2 1/2" profile (the profile of my barley twist router cutter) then used the screw plugin to make a 5" high one revolution spiral. I grouped it, then copied and stacked it on top the other spiral. I then selected those to array the rest of the way.
That's pretty much it but use a component instead of a group.
Still not sure why there is such a difference in file size -
I believe it's quasi the same size maybe a little less for the group because there is less informations inside no Glue etc..., but same info as pure geometry.
illes wrote:
Here is your model with some corrections and the use of components,note it is 650Kb instead of 1950.Isn't it a big difference?
Also modifying all instances at once.
Create libraries for further use in other models. -
Re: file size of my barley twist stair newel
I'm still perplexed by the size of my file. I started over with a new SU file and made my newel without the barley twist. After imported my profile from CAD, did a sweep, created a component of the newel and my file size is 3 MB. What gives?
BTW I have purged layers from the CAD file import -
How many segments did your imported profile turn out to have? The profile I created last night with the Bezier tool had 22 (including the two little short segments I added at the ends. And the total number of entities after one turn of the screw was 2686.
Dave
How can I determine that?
Also I made another barley twist profile, ran the screw plugin and rotated like you did (7 1/2d for 24 seg.). I could not grab the edge of the component for copying and moving. Why did it work for you? -
@archturn said:
Dave
How can I determine that?Select the imported profile and look at the entity count in Window>Model Info. Repeat that for the entire selected twist.
Did you hide the edges before trying to copy? If so, turn on Hidden Geometry (View menu) or do as I did and wait until after copying the component before hiding the edges.
also, time to time go window/ model info/statistics/purge unused.
Any thing interesting here: This is my swept newel no twist yet
That's not overly useful by itself but I expect it'll result in a fairly large file size by itself. Is that for the entire newel post sans twist? You could actually make the newel post as a half or quarter, make that a component and copy rotate it as I showed you the other night.
@N08/5169372316/" target="_blank" rel="noopener noreferrer nofollow ugc">
That is the newel without the twist.
I could make the newel as you say but that doesn't account for how gilles could take my existing file and reduce it to such a small size. I'm missing something.
