    Barley Twist Spirals
    119 Posts 12 Posters 22.0k Views 12 Watching
      archturn
      @dave r said:
      I'd be happy to show you. I can't do it at the moment, though. Maybe another live demo with you or I'll make a video.
      Dave
      That'd be great!!
        and here for example after explode the original component for paint each faces
        I don't need to make a component again, but just a group! πŸ˜‰
          @archturn said:
          Dave
          That'd be great!!
          Maybe a live demo this weekend?
            archturn
            @dave r said:
            @archturn said:
            Dave
            That'd be great!!
            Sounds good
            • daleD
              dale
              I just want to thank you all for this thread. It has been a great learning experience. πŸ‘
              • gillesG
                gilles
                @archturn said:
                @gilles said:
                Here is your model with some corrections and the use of components,note it is 650Kb instead of 1950.
                Looks better than mine. So you redid the spiral?
                No I did not, its your model where I cut part of geometries to make components πŸ˜„
                • pbacotP
                  This thread is hot! Another point I would make is with screw.rb one can then make a component of spiral section that would stack directly beneath the other (without turning) and so you could increase, vary the height (within a module) easily.
                  I assume that can be done with Gilles' version.
                  • gillesG
                    gilles
                    Yes we can!
                    huhu couldn't resist.
                      archturn
                      If I understand you right this is one method I used - I made a 2 1/2" profile (the profile of my barley twist router cutter) then used the screw plugin to make a 5" high one revolution spiral. I grouped it, then copied and stacked it on top the other spiral. I then selected those to array the rest of the way.
                        That's pretty much it but use a component instead of a group.
                          archturn
                          Still not sure why there is such a difference in file size
                            I believe it's quasi the same size maybe a little less for the group because there is less informations inside no Glue etc..., but same info as pure geometry.
                            • gillesG
                              gilles
                              Isn't it a big difference?
                              Also modifying all instances at once.
                              Create libraries for further use in other models.
                                archturn
                                Re: file size of my barley twist stair newel
                                I'm still perplexed by the size of my file. I started over with a new SU file and made my newel without the barley twist. After imported my profile from CAD, did a sweep, created a component of the newel and my file size is 3 MB. What gives?
                                BTW I have purged layers from the CAD file import
                                  How many segments did your imported profile turn out to have? The profile I created last night with the Bezier tool had 22 (including the two little short segments I added at the ends. And the total number of entities after one turn of the screw was 2686.
                                    archturn
                                    Dave
                                    How can I determine that?
                                    Also I made another barley twist profile, ran the screw plugin and rotated like you did (7 1/2d for 24 seg.). I could not grab the edge of the component for copying and moving. Why did it work for you?
                                      @archturn said:
                                      Dave
                                      Select the imported profile and look at the entity count in Window>Model Info. Repeat that for the entire selected twist.
                                      Did you hide the edges before trying to copy? If so, turn on Hidden Geometry (View menu) or do as I did and wait until after copying the component before hiding the edges.
                                      • gillesG
                                        gilles
                                        also, time to time go window/ model info/statistics/purge unused.
                                          archturn
                                          Any thing interesting here: This is my swept newel no twist yet
                                            That's not overly useful by itself but I expect it'll result in a fairly large file size by itself. Is that for the entire newel post sans twist? You could actually make the newel post as a half or quarter, make that a component and copy rotate it as I showed you the other night.
                                            @N08/5169372316/" target="_blank" rel="noopener noreferrer nofollow ugc">
                                            http://farm5.staticflickr.com/4001/5169372316_db2dce793a_z.jpg
                                            • 5 / 6
