    Barley Twist Spirals
    119 Posts 12 Posters 22.0k Views 12 Watching
      That's pretty much it but use a component instead of a group.
        archturn
        Still not sure why there is such a difference in file size
          I believe it's quasi the same size maybe a little less for the group because there is less informations inside no Glue etc..., but same info as pure geometry.
          • gillesG
            gilles
            illes wrote:
            Here is your model with some corrections and the use of components,note it is 650Kb instead of 1950.
            Isn't it a big difference?
            Also modifying all instances at once.
            Create libraries for further use in other models.
              archturn
              Re: file size of my barley twist stair newel
              I'm still perplexed by the size of my file. I started over with a new SU file and made my newel without the barley twist. After imported my profile from CAD, did a sweep, created a component of the newel and my file size is 3 MB. What gives?
              BTW I have purged layers from the CAD file import
                How many segments did your imported profile turn out to have? The profile I created last night with the Bezier tool had 22 (including the two little short segments I added at the ends. And the total number of entities after one turn of the screw was 2686.
                  archturn
                  Dave
                  How can I determine that?
                  Also I made another barley twist profile, ran the screw plugin and rotated like you did (7 1/2d for 24 seg.). I could not grab the edge of the component for copying and moving. Why did it work for you?
                    @archturn said:
                    Dave
                    Select the imported profile and look at the entity count in Window>Model Info. Repeat that for the entire selected twist.
                    Did you hide the edges before trying to copy? If so, turn on Hidden Geometry (View menu) or do as I did and wait until after copying the component before hiding the edges.
                    • gillesG
                      gilles
                      also, time to time go window/ model info/statistics/purge unused.
                        archturn
                        Any thing interesting here: This is my swept newel no twist yet
                          That's not overly useful by itself but I expect it'll result in a fairly large file size by itself. Is that for the entire newel post sans twist? You could actually make the newel post as a half or quarter, make that a component and copy rotate it as I showed you the other night.
                          @N08/5169372316/" target="_blank" rel="noopener noreferrer nofollow ugc">
                          http://farm5.staticflickr.com/4001/5169372316_db2dce793a_z.jpg
                            archturn
                            That is the newel without the twist.
                            I could make the newel as you say but that doesn't account for how gilles could take my existing file and reduce it to such a small size. I'm missing something.
                            • gillesG
                              gilles
                              It is the interest with components.
                              In my file the newel with the twist is about 690Kb, duplicate X100 it is only 1178KB...
                              Imagine 690X100.
                                archturn
                                Imagine 690X100.
                                Pulling my last bit of hair out - The uploaded file is 2.4 MB. How can I reduce the the size of the file? It is already composed of components. How did you take my large file last time and get it to less than 1 MB
                                N112.skp
                                  Check your e-mail.
                                    Jim57
                                    Here are some barley twists I made for the base of an altar for a church in Texas. They were machined on a CNC. The model started in Sketchup but I had to go to Rhino to tweak the legs.
                                    About 25 hours each for cutting, matching and gluing, plus 30 hours milling and 30 hours of sanding. The plates at top & bottom were hand turned. Both the spiral and the worm diameter taper. The gullet follows along a different taper.
                                    I have more photos of the set at http://www.SpringwoodStudios.com It's the first time I've done a whole church in SU. Thanks to all on the forum who helped with the tricky bits πŸ˜‰
                                    • cottyC
                                      cotty
                                      πŸ‘
                                      my SketchUp gallery
                                        Jim57
                                        Sorry, thought the photos posted. The model is a bit large at 2.2 MB.
                                          archturn
                                          Wow
                                          Pretty incredible!!
                                            archturn
                                            [attachment=1:1gqmkiwh]<!-- ia1 -->Sacred Heart Altar1.jpeg<!-- ia1 -->[/attachment:1gqmkiwh]
                                            [attachment=0:1gqmkiwh]<!-- ia0 -->Sacred Heart Altar2.jpeg<!-- ia0 -->[/attachment:1gqmkiwh]
                                            Reminiscent of the columns in the Vatican. Pretty fantastic!
                                            • 6 / 6
