    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
    • GaieusG
      Unless I have completely missed something (and am an idiot as not being able to find any reference), the plugin should work on Mac just as well as on Windows.
      • E
        envisionary
        Sweet. I have not tried it, I just assumed.
          Unless a tool says specifically that it's PC only then it should work on a MAC too.
          The worst that will happen is it won't work.
            You know what "assume' does. πŸ˜‰
              a nelson
              Hello,
              I am using Sketchup 7.1 and I have installed the plugin as well as the pregressbar.rb. Everything seems to be in order but after I click on the group/component, the plugin doesn't seem to recognize the line. What am I missing here?
              Any hep greatly appreciated.
                a nelson
                Aha! I figured it out. I extracted the CONTENTS of the folder to the PLUGINS folder but I was supposed to extract the entire folder. Hope this helps someone else.
                  Don't know your own strength? πŸ˜„
                  This is the most common reason why plugins don't function for people. They don't extract the files correctly.
                    amarqhuszaireen
                    hi,someone please help me,how to install this plugin?
                      It's been covered here
                      • N
                        Nimoni
                        This is awesome.. Thank you πŸ˜„
                          AlainBo
                          Arghh, bad luck I though it would be possible to bend its knee!
                          bend knee.skp
                          • gillesG
                            gilles
                            You should try Fredo scale blend tool for this.
                              jack_13
                              how to install the shape bender plugin??
                              pls help..
                                pls help..
                                Instructions are on the first page of this very thread [ http://sketchucation.com/forums/viewtopic.php?p=147395#p147395 ], with the download link for the archived tool. Remember to get progressbar.rb too as explained in the link...
                                ***After installation of all 'loose' files and also the other files in their subfolder [exactly as they are inside the zip!], into the Sketchup Plugins folder, you need to restart Sketchup to auto-load these things...
                                You will also probably need then to activate it as an Extension [under Preferences] and then activate its Toolbar [under View]...
                                Follow the tools usage instructions carefully...
                                ***You might do best to get and install thomthom's 'Simple Plugins Installer' for v8M1 [Pro/Free PC/MAC] which auto-installs are types of downloaded toolsets from their files or archives... Look for it in The SCF Plugins Index... One this is installed it will make installing any future tools much less challenging...
                                  JCFENNELL
                                  Shapebender is not working for me in sketchup 8 pro since downloading the latest update. I'm specifically trying to bend text into an arc shape, and it keeps putting the text off the end of the arc rather than on the arc itself. Help!
                                  Fennell
                                    I found the same problem a few minutes ago. Strangely though, I found if I hit the down arrow, then the up arrow twice and finally the down arrow again (let it process in between) I got the correct results. I don't know if the order matters.
                                    • ToboboT
                                      Tobobo
                                      Sometimes it does that just be patient with it and try a double up or down arrow.
                                      Toby
                                      Philippians 4:13
                                      • P
                                        Patternvisions
                                        One of the most impressive plugins I've ever seen! I've needed something like this for years!
                                        • P
                                          pimpuppy
                                          Hello,
                                          I came here like i always do ... when i have a problem.
                                          And now it is with the "bending"
                                          Please take a look at the attached image. i tried to bend a simple shape but the plug-in get's stuck as it is shown. Maybe someone that understands the ruby console text can help me to fix the problem.
                                          I have to mention that i used very well the plugin in the past, but for some reason on the 2 computers that i am working on it gives the same error. On both i have the same plugins installed. maybe it is fighting with some other plugin ....
                                          Sorry if this is already answered and i am asking again.
                                          Thanks in advance,
                                          Marius.
                                          • Chris FullmerC
                                            Try uninstalling other plugins? There have been known conflicts in the past with other plugins who reassign things they should not be touching. Just move all other plugin files out of the plugins folder and leave the shapebender loader and the shapebender folder in there and try it again. See if it helps.
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 63
                                            • 64
                                            • 55 / 64
