    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
      Another possibility is that you are 'above average intelligence' and that you have installed it correctly [you say you are getting the custom cursor etc which is a good sign πŸ˜„ and hopefully you have also installed the required 'progressbar.rb' script too to avoid the tool falling over a little later on πŸ˜• ]...
      Perhaps your first line that you select [which must be parallel to the red axis and in the same context as the group you want to bend] might be touching some other geometry - it must be freestanding otherwise it can't be selected - the tool needs it to have no connected geometry. Similarly the 'curve' that you need to select next cannot touch other geometry either [the line/curve can touch the group or other groups/instances, but not each other, or other nearby loose geometry].
      With these two possibilities addressed how does it perform... πŸ˜’
        AnthonyPatschorke
        Chris how exactly do i get this plug in. Its just not working out for me.
          Anthony, go back and read the first post of the thread and watch the video. Also read the first page or two. It has been explained quite well.
          If you still have problems using it, explain what happens when you try it. Show us your set up. Give us something so we can help you.
          • E
            envisionary
            Any chance there is a MAC version of this amazing plug in?
            • GaieusG
              Unless I have completely missed something (and am an idiot as not being able to find any reference), the plugin should work on Mac just as well as on Windows.
              • E
                envisionary
                Sweet. I have not tried it, I just assumed.
                  Unless a tool says specifically that it's PC only then it should work on a MAC too.
                  The worst that will happen is it won't work.
                    You know what "assume' does. πŸ˜‰
                      a nelson
                      Hello,
                      I am using Sketchup 7.1 and I have installed the plugin as well as the pregressbar.rb. Everything seems to be in order but after I click on the group/component, the plugin doesn't seem to recognize the line. What am I missing here?
                      Any hep greatly appreciated.
                        a nelson
                        Aha! I figured it out. I extracted the CONTENTS of the folder to the PLUGINS folder but I was supposed to extract the entire folder. Hope this helps someone else.
                          Don't know your own strength? πŸ˜„
                          This is the most common reason why plugins don't function for people. They don't extract the files correctly.
                            amarqhuszaireen
                            hi,someone please help me,how to install this plugin?
                              It's been covered here
                              • N
                                Nimoni
                                This is awesome.. Thank you πŸ˜„
                                  AlainBo
                                  Arghh, bad luck I though it would be possible to bend its knee!
                                  bend knee.skp
                                  • gillesG
                                    gilles
                                    You should try Fredo scale blend tool for this.
                                      jack_13
                                      how to install the shape bender plugin??
                                      pls help..
                                        pls help..
                                        Instructions are on the first page of this very thread [ http://sketchucation.com/forums/viewtopic.php?p=147395#p147395 ], with the download link for the archived tool. Remember to get progressbar.rb too as explained in the link...
                                        ***After installation of all 'loose' files and also the other files in their subfolder [exactly as they are inside the zip!], into the Sketchup Plugins folder, you need to restart Sketchup to auto-load these things...
                                        You will also probably need then to activate it as an Extension [under Preferences] and then activate its Toolbar [under View]...
                                        Follow the tools usage instructions carefully...
                                        ***You might do best to get and install thomthom's 'Simple Plugins Installer' for v8M1 [Pro/Free PC/MAC] which auto-installs are types of downloaded toolsets from their files or archives... Look for it in The SCF Plugins Index... One this is installed it will make installing any future tools much less challenging...
                                          JCFENNELL
                                          Shapebender is not working for me in sketchup 8 pro since downloading the latest update. I'm specifically trying to bend text into an arc shape, and it keeps putting the text off the end of the arc rather than on the arc itself. Help!
                                          Fennell
                                            I found the same problem a few minutes ago. Strangely though, I found if I hit the down arrow, then the up arrow twice and finally the down arrow again (let it process in between) I got the correct results. I don't know if the order matters.
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 63
                                            • 64
                                            • 55 / 64
