    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.5m Views 329 Watching
      It's bold and highlighted with the word 'Requires' in larger, red, bold text.
      • Chris FullmerC
        Ok, if it will help, I've gone ahead and made it bigger, bolder and redder! And I added another notice at the bottom of the page. So it says it at the top and bottom. Maybe this will help. Thanks,
          mgonzavega
          HI Chris,
          I have a problem with the shape bender tool. I select the objecy (group) and then hit the shape bender button. Then an arrow with a short line appears but it does not select the line the is on the red axis. Why? Please help!
          • Chris FullmerC
            Probably you installed it incorrectly. Please open the Ruby Console and then try to run shape bender again. It will probably write some errors. Please copy and paste those back here.
              Another possibility is that you are 'above average intelligence' and that you have installed it correctly [you say you are getting the custom cursor etc which is a good sign πŸ˜„ and hopefully you have also installed the required 'progressbar.rb' script too to avoid the tool falling over a little later on πŸ˜• ]...
              Perhaps your first line that you select [which must be parallel to the red axis and in the same context as the group you want to bend] might be touching some other geometry - it must be freestanding otherwise it can't be selected - the tool needs it to have no connected geometry. Similarly the 'curve' that you need to select next cannot touch other geometry either [the line/curve can touch the group or other groups/instances, but not each other, or other nearby loose geometry].
              With these two possibilities addressed how does it perform... πŸ˜’
                AnthonyPatschorke
                Chris how exactly do i get this plug in. Its just not working out for me.
                  Anthony, go back and read the first post of the thread and watch the video. Also read the first page or two. It has been explained quite well.
                  If you still have problems using it, explain what happens when you try it. Show us your set up. Give us something so we can help you.
                  • E
                    envisionary
                    Any chance there is a MAC version of this amazing plug in?
                    • GaieusG
                      Unless I have completely missed something (and am an idiot as not being able to find any reference), the plugin should work on Mac just as well as on Windows.
                      • E
                        envisionary
                        Sweet. I have not tried it, I just assumed.
                          Unless a tool says specifically that it's PC only then it should work on a MAC too.
                          The worst that will happen is it won't work.
                            You know what "assume' does. πŸ˜‰
                              a nelson
                              Hello,
                              I am using Sketchup 7.1 and I have installed the plugin as well as the pregressbar.rb. Everything seems to be in order but after I click on the group/component, the plugin doesn't seem to recognize the line. What am I missing here?
                              Any hep greatly appreciated.
                                a nelson
                                Aha! I figured it out. I extracted the CONTENTS of the folder to the PLUGINS folder but I was supposed to extract the entire folder. Hope this helps someone else.
                                  Don't know your own strength? πŸ˜„
                                  This is the most common reason why plugins don't function for people. They don't extract the files correctly.
                                    amarqhuszaireen
                                    hi,someone please help me,how to install this plugin?
                                      It's been covered here
                                      • N
                                        Nimoni
                                        This is awesome.. Thank you πŸ˜„
                                          AlainBo
                                          Arghh, bad luck I though it would be possible to bend its knee!
                                          bend knee.skp
                                          • gillesG
                                            gilles
                                            You should try Fredo scale blend tool for this.
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 63
                                            • 64
                                            • 55 / 64
