    [Plugin] DXF_export v0.0.4 (2011-10-28)
    54 Posts 22 Posters 103.0k Views 22 Watching
    • G
      Gumleguf
      Hi Scott,
      Perhaps your shape is too advanced for the DXF_export tool to handle or there are errors in your drawing.
      Try to upload your Sketchup model here and perhaps someone with a Sketchup Pro version could try to export it to dxf. If it also fails your drawing is bad, if it works the DXF_export tool doesn't support your model.
      /Greg
        sli21
        thanks greg
        i couldnt even work out how to attach a file earlier - lol. (still cant work it out!)
        i drew a circle in a new document and exported - no worries.
        somehow i changed the axis on my model so it was actually exporting the top view. does it export any particular view by default??
        i rotated my model and off it went.
        thanks for the quick reply - great 😄
        i also had troublesmoothing the edges toany acceptable level. i hope to create a toolpath for my cnc so would like to get it a lot smoother. maybe not possible with SU8 Free Vers.
        regard scott
        • G
          Gumleguf
          Hi Scot,
          You are welcome. Glad you solved your problem.
          If yuo right click the circle in Sketchup you should be able to select properties and define the smoothing of the edge. Default value is pretty rough (12, or so) but just change it to whatever value you need.
          /Greg
            If it is an arc or circle you can make it initially with lots of segments [e.g. typing 72s gives it 72 segments] OR select it and use 'Entity Info' to adjust its segment count later. BUT once an arc is incorporated in a 3d object it's no longer editable like that, and so it will mean recreating that part later... so plan ahead. Unattached other 'curves' like Bezier etc can have their segmentation changed with the edit function within Fredo's BezierTools...
            • G
              Gumleguf
              Yeah, what TIG said. I don't have Sketchup here, so sorry I couldn't be more precise.
                sli21
                thanks guys
                regards scott
                • dereiD
                  derei
                  Nice fixing on this plugin. Thank you ! It's a very useful tool for me.
                  If I may, I would like to ask for some feature requests as follows:
                  .1 -save layers (I don't know if it does it now, but I had some edges distributed on layers and all of them were saved on Layer 0 in DXF)
                  .2 -Save As name of the selected object (Component/Group), or Parent's name (if I select raw geometry inside a Comp/Group)
                  optional (.3 -Bulk Save As separate files, if several Components/Groups are selected. Each one using its own name.)
                  Thank you very much !
                  DESIGNER AND ARTIST DEREI.UK
                  • dereiD
                    derei
                    is this plugin still supported/developed ?
                    • T
                      trizwiz
                      You rock for putting such a great plugin online for us! We just started using it and I don't understand it all yet but I have exported my first DXF and it worked well.
                        jeremy_rutman
                        can u provide a link for the dxf export plugin?
                        in chrome I do not see any evidence of a link or blocked popup
                          sipik
                          Здравствуйте, у меня ArtCam PRO 9 не открывает модель ...
                          • robertWanR
                            robertWan
                            If the curves are grouped, the elements move after the export to DXF.
                            When there are no groups it's ok, but inconvenient, edition in SU is
                            troublesome.
                            Can anyone confirm these problems?
                            Robert
                            Group
                            No group
                            DXF no Group
                            DSF Group
                            In CAM DXF Group
                            In CAM DXF no group
                            In SU
                            • Z
                              zonian
                              Hello Jörg!
                              Wonderful plugin. Export about 99.5% of my skp file write and the remaining 0.5% was
                              intersperse far far away from my model. I just delete the
                              intersperse 0.5% and finished the dwg file manually.
                              Great work Thanks
                                MikeDragon
                                Finding this plugin very useful for exporting to laser cutter. The only other free plugin I found exports a circle as 24 lines (or however SketchUP is configured to draw a circle). A series of lines isn't nearly as attractive when laser cut as the point where two lines meet is visible.
                                Thanks for the plugin. Mike
                                • G
                                  GentlemanJosh
                                  Is this plugin for PC only? I've copied plugin into folder but all of my plugins have a .plugin extension whereas this one is .rb. Tried both extensions neither worked. Using Sketchup Make 2016 on OS X 10.10.3
                                    This is VERY old plugin, it might not work with any of the newer SketchUp versions...
                                    What makes you thing it goes into a folder which contains .plugins files ?
                                    SketchUp's Plugins go into your own 'Plugins' folder, created when SketchUp is installed...
                                    Putting a SketchUp 'plugin' anywhere else is doomed to failure...
                                    Open the Ruby Console and paste this text into it, + <enter>
                                    UI.openURL("file:///#{Sketchup.find_support_file('Plugins')}")
                                    The newly opened folder is YOUR very own SketchUp 'Plugins' folder.
                                    Put the loose .RB file in there.
                                    Restart SketchUp and see what happens...
                                    If it messes up remove it...
                                    There might be several better options available - look in the EWH for DXF Export...
                                    PS:
                                    Most Extensions/Plugins now come as RBZ archives.
                                    You use the SketchUp > Preferences > Extensions > Install Extension... button to select an RBZ and install it automatically, without ever having to worry about your Plugins folder might live...
                                      driven
                                      ... all of my plugins have a .plugin extension ...
                                      you are looking inside SketchUp.app contents and the .pluginsare all compiled C code, not ruby...
                                      don't put anything into the app, unless you 'really' know how to bypass issues...
                                      always make sure your using the User/<your_name>/Library/... until you know how it all works...
                                        monekia
                                        when i use this plugin on su 2016, it doesn't work , can u help me?
                                          I what way does it not work ?
                                          Are there error messages ?
                                          If you open the Ruby Console any messages when you use it ?
                                          At which point does it fail ?
                                          It's a very old plugin - see my old post a few back https://sketchucation.com/forums/viewtopic.php?p=594141#p594141
                                          There might now be better options...
                                            minnimi
                                            Hi there,
                                            for me when exporting from SKP 2021 to Dxf everything is exported in lines. NOT in real circles or arcs.
                                            am I doing something wrong.
                                            Guess Holzi 😲
                                            • 3 / 3
