    Distace from Camera to object in drawing.
    44 Posts 14 Posters 44.1k Views 14 Watching
    • Chris FullmerC
      Looks like he's got his f-stop set at 2.8. That should give a good DOF blur. And indeed in his first post, the image where he has f-stop at 2.8 and focal distance at 703, there is no visible blur, but when he changed the focal distance to 10, the entire image was blurry, indicating that the DOF is working, he just needs to set the correct distance.
      • Chris FullmerC
        I'm already changing my mind. I can see that lowering the f-stop even more might be needed Thom, good call. That should definitely be tried as well.
        The further the object is, the harder it is to get a shallow DOF (blur). Lowering the aperture will help create even more blur. But its possible the object could be so far away that there will never be any apparent blur. You could resort to using tilt frame to force a blur. But I'm thinking at that distance, you should be able to get some blur.
          He used a tool to measure the distance, so it should be correct.
          It is possible that the F-Stop in VfS isn't working 100% like a real camera does.
          • Chris FullmerC
            Well, in thinking about it, he's trying to blur something that is 58 feet or 17+ meters away. I'll get out my camera later today and open it to 2.8 and shoot something at about that distance, see if it produces any blur. At that distance, there is a chance there should be no blur.
              As I understand it... the bigger the f-stop number the greater the depth of field about the focal-depth.
              So a large number uses a 'pinhole' which has almost everything focused about that point, but a small number uses a 'wide-eyed' aperture which focuses on the point, with things nearer or farther away being shown blurred...
              In real cameras the smaller the aperture size [i.e. the bigger the number] the less light gets into the 'film' and so this affects the shutter-speed in turn - so then there are three variables to juggle. But in rendering the focal-depth and f-stop interact to control the sharpness of objects that are nearer/farther away... and the 'speed' is therefore somewhat arbitrary...
              πŸ˜•
              • Chris FullmerC
                Yup, except I think some (most?) renderers do take into account the shutter speed and use it for brightness/exposure control.
                @Thom, he used "a tool" to measure, but is it designed to work seamlessly with the renderer he's using? The tool returns the distance in inches, but do you know what unit V-Ray is expecting? That's why TIG and then I suggested he try some different units.
                I'm interested to hear back if its a units thing or not so I can move on from that sticking point.
                • stefanqS
                  stefanq
                  I rendered this image couple of years ago, so in an older version of v-ray, but what I can tell for sure is that, it's a raw v-ray image with f-stop at 0.4. I remember that I had a hard time using physical camera, so I turn it off.
                  PS: I used a free plugin called "CameraDistance" , and in v-ray, the units are inches.
                  Good luck.
                  • stefanqS
                    stefanq
                    It's working. I added a checker texture on the ground so that the DOF effect is clear.
                    What you need is a lower f-stop to really see the DOF effect. For this image I used 0,2 and I made the ISO 1 for balancing the exposure.
                      VfSU expects inches for everything - because it uses SU's internal units only. But his screenshot indicated the distance was in inches - did it not?
                      • Chris FullmerC
                        Ahh, see I don't know that, not being an VFSU user. The screen shot looked like he used a tool by Al to determine the distance. But the Vfsu screen does not indicate what units it is expecting. So there was no way to know that he had input the measurement in the correct units. But if you say it is expecting inches, then yes, 703 should work.
                          So, as Stefan confirms... IF the f-stop is a very small number [large iris aperture] then most things at or near the 'focal-point' [set in inches] will appear sharp, with blurriness increasing rapidly away from that point. If the f-stop is a very large number [small iris aperture] then most things will appear sharp, irrespective of the 'focal-point' [set in inches] and their relative offset from that.
                            angeli7on
                            Hi guys,
                            Thanks alot for the reply even I not fully understand it all ^^
                            I tried Stefanq setting, put down the F number to 0.1 and ISO to 1.0 and finally the blur came out, and only distance 703" is sharp.
                            However I need extremely blur to the black and blue ball, I tried the F number to 0.01, but all become wash out white.
                            eventhough I increase the speed to 16,000 to reduce light, it still wash out white. Do you have any advice how to get the blur more ? many thanks.
                            dof4
                              angeli7on
                              Hi guys, finally the blur is ok with me... attached is my last setting.
                              Now I learn one thing that vfsu is different than my DSLR, I used F/2.8 lens at 200mm and 5 meter object (ISO 100, speed 1/100) but different here in vfsu, number can vary from 0.01
                              now I have to get used to this ^^
                              One last question, Stefanq said that he didnt use physical camera setting, so what setting should I used without physical camera On ?
                              Thank you Chris, TIG, Thom, & Stefan.
                              solved dof
                              • jeff hammondJ
                                or focus closer.. i mean, i could shoot a mountain range from a couple miles away with a noct* wide open and the mountains will still be sharp..
                                many of the rendering programs do in fact mimic real optics.. so it helps to understand them if you want to use those controls for focusing a rendering..
                                for one, it's not all about the aperture.. it's that plus a combination of focal length (field of view) and distance to focal plane..
                                ie- i could shoot a 35mm lens at f/8 from a distance of around 20' and everything in the frame will be in focus..
                                i could shoot that same lens w/same aperture from 2' and the depth of field is going to get pretty thin.. maybe a few inches or so...
                                likewise.. using the same scenario above except this time i'll change lenses.. say a 200mm lens at f/8 and 20' away.. youll now have a thin dof of maybe a foot or two deep..
                                (notice the aperture stayed the same.. (shutter speed and/or iso doesn't matter in this comparison))
                                (i'm not sure if there's a 200mm lens that can focus at 2'.. maybe some sort of 200mm macro lens... but the dof at that point is going to be incredible thin.. like 1 mm thin πŸ˜‰ )
                                but, to get some shallow dof at 60' away is virtually impossible with the cameras of today.. you'd need a real long lens and a very large aperture (400mm f/1 lens ?? 😲 ).. but then you're way zoomed in on the subject and probably aren't getting the framing you're after..
                                i guess, if you want to render a picture of a house across the street then make it's backyard appear blurred, fake it in photoshop.. i mean, it's going to look fake no matter what.. our eyes aren't used to seeing things that way.
                                *classic fast nikkor.. f/1.2
                                • jeff hammondJ
                                  here.. play around with this thing:
                                  Access Denied
                                  (www.dofmaster.com)
                                  notice the 3 factors which determine depth of field... those same things need to be considered in a rendering app as well.
                                  • jeff hammondJ
                                    [the following is really nothing to do with the conversation but you're πŸ€“y so you might appreciate the tidbit πŸ˜„ ]
                                    f-stops, which are generally written f/4 etc, means (f)ocal length Γ· aperture stop
                                    so using a 100mm lens at f/4-- the f/4 tells you the physical size of the aperture opening for the lens/stop combo..
                                    (100mm / 4 = 25mm... so the aperture is 25mm in diameter... same lens at f/11 = 9mm aperture opening.. etcetc..)
                                    ie- your understanding about larger fnumbers = smaller apertures is correct.. the above is just an attempt at grasping the why..
                                    EDIt.. oh.. and to see these maths in action.. (ha)
                                    earlier in the thread, I said you'd need a 400 f/1 lens to do that... so that lens would need to have a 400 mm hole in it.. the glass & housing need to be bigger than that so we're looking at a lens approaching 2' across πŸ˜„
                                    • stefanqS
                                      stefanq
                                      When you disable physical camera, the "Aperture" box become available (under SettingsCameraDOF/Basic Params).In this case, you control the DOF effect with this option.
                                      "A small aperture will have a only a slight amount of
                                      blurriness for objects which are not within the focal distance. A large aperture will have a large amount of
                                      blurriness for objects outside the focal distance."
                                      There was the place where I had the value of 0,4 ,and not the f-stop like I said in my first comment. The problem is that I tried to recreate the same effect without physical camera, and it's not working. Must be a bug, because I had values between 0,001 and 500, without any changes for DOF effect.
                                      So, I'll guess you'll have to use physical camera when you want DOF.
                                      Cheers,
                                      Stefan
                                      • jeff hammondJ
                                        like i said earlier, you'll have to get closer ...
                                        it's practically impossible to stand 50' away from a subject and expect to get shallow dof.. regardless of camera settings..
                                        • monsterzeroM
                                          monsterzero
                                          Thread revive!
                                          I found this extension and wow---it's a lifesaver 7 years later! Thanks!
                                          monsterzero
                                          I live stream my work on my graphic novel:
                                          https://www.youtube.com/@monsterz3r0
                                          http://infinitemachine.tv/
                                          https://www.aaatitle.xyz/
                                          • 2 / 3
