    [Plugin] TIG-Smart_offset
    143 Posts 55 Posters 186.5k Views 54 Watching
      rv1974
      @jean-franco said:
      looking at your skp and welding part of the segments you'll see different results.
      [attachment=0:2t1zi3eq]<!-- ia0 -->TIG-Smart_offset_example.jpg<!-- ia0 -->[/attachment:2t1zi3eq]
      I exploded those arches and no offset get executed ๐Ÿ˜’
      • Jean-FrancoJ Offline
        Jean-Franco
        @rv1974 said:
        [attachment=0:3fig2342]<!-- ia0 -->TIG-Smart_offset_example.jpg<!-- ia0 -->[/attachment:3fig2342]
        Yes, the same behavior for me.
        Jean-Franco
          I'm investigating...
          ๐Ÿ˜•
            Here's v2.0 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
            Just ready for the New Year ๐Ÿ˜‰
            It has further refinements and glitch trapping.
            The recent reports of malformations were caused by the face having very 'sharp' spikes, which were returning a false negative when testing for their offset vertices for the new outline's points. This is now fixed, but it has meant that the point-on-face 'checking tolerance' has had to be increased to 0.5mm - so it could now fail on a face that has a 'finger' that is narrower than 0.5mm, when measured along adjacent vertices' internal-angle-bisectors - but that is very very unlikely anyway...
            ๐Ÿ˜’
              rv1974
              the last one is much better!
              things to refine:
              no outer offset in attached shape
              tig4.skp
                mapi_79
                great job, as always TIG. Thank you and Good Year ๐Ÿ‘
                  Here's v2.1 http://sketchucation.com/forums/viewtopic.php?p=446462#p446462
                  This version now has the same vertex checking tolerances applied to curves' vertices as to plain edges... [I accidentally missed that code out in the previous version].
                  Hopefully it now also works with the recent problem offset examples posted: mind you, these are getting somewhat 'extreme' ๐Ÿ˜ฎ
                  Feedback please ๐Ÿ˜•
                  • kenK Offline
                    ken
                    I have been following the updates, and the plugin still has this output with my model. I am not sure this is correct or is a problem.
                    Thanks for your work.
                    Ken
                      Ken
                      Ken, I'm curious. If you were to draw that out with paper and pencil, what would you expect that amount of offset to look like?
                        @Ken
                        That's not right. ๐Ÿ˜•
                        The offset is not maintained evenly - it's too near the 'spikes'.
                        I can't get the effect... ๐Ÿ˜ž
                        However, I do get the outline failing at some point sooner than it ought, when the inward facing 'spikes' get so large they cut through to the other side of the shape...
                        I looking to see what's up with that...
                        Outward offsets are also problematical on that shape...
                          rv1974
                          It starts to look like quest game ๐Ÿ˜Ž
                          Step by step it's getting better.
                          Inner ofsetting (value:-25) in my last attachment is not 100% correct.
                          P.S. Thank you
                          And Happy New Year!
                            Maybe you just need to change the name of the plugin to TIG_Random _Shape_Generator.rb. ๐Ÿ˜„ ๐Ÿ˜„
                            I also got something similar to your second one, TIG, when I used a larger offset distance.
                              I've got my algorithms in a twist [very painful!]
                              Trying to unravel the mess...
                              I'll update asap...
                              • kenK Offline
                                ken
                                Ken
                                Dave
                                Well I don't know. That is why I questioned, just what is an offset in an earlier post. Like I said, I only use offset to define a distance to place another object. I know that an offset will eventually distort the shape, so I don't use it to make a larger version of the shape.
                                I just feel that the attached offset is not what I expected. And it may come to past, that after doing an offset, no matter which tool is used, an individual will need to clean up the edges.
                                A side note, it would be nice if an offset could be made with guidelines, that way I would get my distance, and be able to delete the offset lines later.
                                Ken
                                • jeff hammondJ Offline
                                  @tig said:
                                  @Ken
                                  actually, that's pretty close to being right (aside from the whole arc offset business i got into earlier..)
                                  if that arc is a half circle then i offset the same distance as the two top squares are wide then the solution would be this: (the white is inset from the blue shape)
                                  [EDIT] -- i updated the image to include dimensions
                                  • simon le bonS Offline
                                    simon le bon
                                    mardi 01 Janvier 2013
                                    The following was I think a difficult exercise (;-)) but Smart_offset v2.1 20121231 has made the deal about 87% well and quick.
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-SmartOffset_HNY2013_01_zps973e8de7.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-SmartOffset_HNY2013_02_zpse0d2d1f2.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-SmartOffset_HNY2013_03_zpsef62cb93.jpg
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIG-SmartOffset_HNY2013_04_zps3d943985.jpg
                                    +++simon
                                      Happy New Year, Simon... ๐Ÿ˜
                                      I am working on an up date that should up the percentage of successful outcomes too ๐Ÿ˜‰
                                      • shuraS Offline
                                        shura
                                        Happy new year TIG!
                                        gosh, this plugin is something I've been wishing for at least a trillion of times. You are my hero Sir!
                                        • utilerU Offline
                                          utiler
                                          Just returned today from a few weeks holidays. Never too late to use your manners my grandma used to always say!!!
                                          TIG, Trimble needs you, really. Not to mention all the other programmers around here that produce everything from simple tweaks to full blown toolsets...
                                          A big thank you from me!!!!
                                          Just Curious...
                                          • john2J Offline
                                            john2
                                            wonder why sketchup guys don't have the normal and ordinary offset that you invented ๐Ÿ‘
                                            Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 โ€“ 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                            • 5 / 8
