    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 476.2k Views 108 Watching
    • sumasterS Offline
      sumaster
      HI,
      CHK the Combine each tool not working . . . . .
      thanks
      Thank you,
      SUmaster
        tak2hata
        @sumaster said:
        HI,
        thanks
        I see it.
        I will correct it tonight(so means 12 hour later).
        @sumaster said:
        can you tell me . . . .
        when i change wall width / height its re-create base face & push-pull ?
        This plugin regenerate the Profile when modifyin profile.(the case of width and height and etc.)
        I will add notice about never modifying inner Axis of the BST entities.
        In your case ,I think modifying the "align" to Center and bottom will almost well.
        I can not know where you modified the inner axis of BST entity.
        So there is no best answer.
        Please do not blame me.
        by TAK2HATA
          tak2hata
          Hi, I update to version1.5a in Nov 13,2012.
          Bugfix:Combine tool.
          Thanks...ZZZzzz...
          by TAK2HATA
          • sumasterS Offline
            sumaster
            @tak2hata said:
            @sumaster said:
            HI,
            thanks
            I see it.
            Thanks . . . . πŸ‘
            OK . . . .
            yes i CHK this "align" to bottom of center radio button πŸ‘
            No no no . . . .
            Thank you,
            SUmaster
            • V Offline
              victor hugo
              I updated the files to version 1.5 and when I check the version under the plugins menu it shows Version=1.4(Oct 14,2012. How do I know if it was updated?
              Thanks.
                tak2hata
                Thanks.
                Hi,Victor.
                It is my mistake.
                I will correct it strongly in next update. πŸ‘
                Thanks.
                by TAK2HATA
                • sumasterS Offline
                  sumaster
                  HI,
                  Please CHK the draw by clicks tool
                  its not work in group . . . .
                  (when draw on plan)
                  BST - 2.skp
                  Thank you,
                  SUmaster
                    tak2hata
                    Hi,All.
                    I update BTS version 1.5c in Dec.04,2012.
                    Add Showing "About this" and "About History".
                    Bug fix when Creating Walls in Group.
                    Thanks.
                    by TAK2HATA
                    • sumasterS Offline
                      sumaster
                      now BST Tool working GOOD
                      Thanks Tak2hata . . . . . πŸ˜„ πŸ˜‰
                      Thank you,
                      SUmaster
                      • F Offline
                        faluchdeviaro
                        Hy tak2hata I translate the lang.txt file but the plugin remains without translate.
                        How can I translate it?
                          tak2hata
                          Happy New Year 😍
                          I update this script to v1.6 in Jan 01,2013.
                          Improve the parts of translater.
                          So Translate will work fine ,perhaps.
                          And I add new words to language file.
                          I create the support script for tranlate file.
                          This script aims at the creating the corrected language file from older,if you have already created the language file.
                          Thanks.
                          by TAK2HATA
                            tak2hata
                            @hcltw1963 said:
                            I have found that your BST script is very helpful and potential. It's the beginning of the BIM in SKP. I think it might be useful for wood structure either, so I omit 'RC' keyword in the script. Here's the language translation of the traditional Chinese.
                            [attachment=0:3nwkabke]<!-- ia0 -->lang_zh_16.txt<!-- ia0 -->[/attachment:3nwkabke]
                            Hi,hcltw1963.
                            I'm glad to your translation! πŸ˜„
                            I add the link to here from the top of thread.
                            by TAK2HATA
                            • OxerO Offline
                              Oxer
                              Hi and thanks for the plugin!!
                              Spanish translation file.
                              lang_es.txt
                              There are some phrases that I can't translate for example these:
                              I have added some lines to the end of the lang_es.txt file with the phrases without translation.
                                tak2hata
                                Hi,All.
                                I update to v1.6a in Jan 05,2013.
                                Add translation words to lang file.
                                Add the menu about Athors of Translations.
                                I add link to translations in top of thread.
                                Thanks chon!
                                Thanks oxer!
                                I am very happy. πŸ˜„
                                by TAK2HATA
                                • H Offline
                                  hcltw1963
                                  lang_zh_16.txt
                                  • OxerO Offline
                                    Oxer
                                    Thanks to you!! πŸ‘
                                    • H Offline
                                      hcltw1963
                                      Dear Tak2hata,
                                      Is it possible to generalize the script to use for another kind of construction type like wood? I thought that if the class name "RC_GIRDER","RC_BEAM","RC_WALL","RC_SLAB" substituted by "GIRDER","BEAM","WALL", and "SLAB", they will not be represented as RC construction only.
                                      So, it will be useful for different kind of construction cause materials been assigned clearly.
                                        tak2hata
                                        @hcltw1963 said:
                                        Dear Tak2hata,
                                        Hi,htcltw1963.
                                        It is possible.
                                        But STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,RC_GIRDER,RC_BEAM,RC_COLUMN,WOODEN_GIRDER,WOODEN_BEAM,WOODEN_COLUMN.....
                                        I think it too many class to select.
                                        "ALL" CLASS with searching word can find by "TAG" and "PROFILE".
                                        I can add the new CLASS If surely required.
                                        But it will be very hard.I must change TABLE EDITOR,too.
                                        If there is the request same otherwise, it will inquire collectively.
                                        Thanks.
                                        by TAK2HATA
                                        • H Offline
                                          hcltw1963
                                          @tak2hata said:
                                          @hcltw1963 said:
                                          Dear Tak2hata,
                                          Hi,htcltw1963.
                                          It is possible.
                                          Thanks.
                                          Thanks for reply so quickly. I think the modification is as:
                                          STEEL_GIRDER,STEEL_BEAM,STEEL_COLUMN,GIRDER,BEAM,COLUMN,OTHER
                                          It is because steel material has special profile, it needs independent class. The prismatic member like concrete, wood, and other can be categorized as same class. They can be identified by materials. I had experienced modifying your scripts by deleting key word "RC_" where in rubies but failed to execute. I hope the idea works for minimum modification.
                                          • chonC Offline
                                            chon
                                            Hello,
                                            here a first french translation file. This is a first draft and may have mistakes, non-sences or else. This file is not my own. So frensh speaking, you can bring corrections as you want. πŸ˜‰
                                            2013/01/07 EDIT : File reloaded with 2013/01/05 V1.6a changes included.
                                            lang_fr.txt
                                            • 16
                                            • 17
                                            • 7 / 17
